Question about Electrical Supplies
Hi ineed to know where all plugs and conections plug into on 909 3000w iverter generator please thanks
3 Suggested Answers
  • 114 Answers
SOURCE: conecting to my pc computer with my psp
you can download with the PSP using wifi and don't need a lead to connect to the pc
Posted on Jul 31, 2009
SOURCE: hi, i have a clarke generator g900 ,no spark
this gen has a oil level sensor that will short the "primary" of the ignition coil as well as a spark enhancer that is called a CDI unit but the drawing does not show a Capacitor in or near it?
I hope this helps
Where did you get your replacement coil Colin?
Peter
Posted on Feb 14, 2010
I'm trying to drain the gas tank. I've disconnected the fuel ine, but no fuel flows from the tank? The tank is full.
Well, sounds like it is plugged up. Gas can jell over time. you can likely expect to find similar gunk inside the carb.
you need to completely clean it all out.
Mar 18, 2015 | Generac Generator 5997 4,000 PSI 4.0 GPM...
The 220 plug has 4 leads and my 220 compressur has 3 wires how do i make the conection
The four wire 220 twist lock receptacle Two hot wires, one neutral, and a safety ground. Depending on your generators setup the neutral and ground are bonded as one; unless, it setup for a floating neutral.
You would normally connect the two hots and neutral. and leave the ground open on the four prong twist lock plug. Just make sure the compressor is earth grounded on its end.
Feb 12, 2015 | Coleman Powermate Powermate 5000W...
Connect to PC
Any "plug-and-play" device with a USB interface should be supported by Windows XP/Vista/7/8.
Try it!
Jan 14, 2013 | IBM (10H3980) External Floppy Drive
I need a spark plug for a 5700 watt 11 hp generator, which one do I need?
Hi and welcome to FixYa. I am Kelly.
The standard plug is an NGK "BPR5ES" or Denso "W16EPR-U" There are a number of alternate plugs out there if you use the number above in a cross reference book.
One thing to note... the generator has a "Low Oil" sensor and if the oil level is low you will not see any spark. If after you install a new plug and you still do not have spark... un-hook one wire from the low oil level sensor and check spark again. If you unhook the sensor wire knowing full well the oil level is full.and have spark; the sensor is either dirty or bad.
Thanks for choosing FixYa,
Kelly
Feb 19, 2011 | McCulloch 13HP 338 Cc Portable Generator #...
I need to replace the power plug on my HPpavilion 9548us. Ineed disassembly instructions.
Hi
Do you mean the power plug unit that plugs into the wall at one end and your laptop the other end ??? if this is the case you can buy new replacement ones on ebay www.ebay.com
or do you mean the power connecter thats on the motherboard ??
if you dont have the manual for your laptop then you can download one from here www.hp.com
go to suupport/downloads type in your make and model then search for manuals
good luck
hope this was helpful
please let us know if fixya fixed it for ya
Jan 26, 2011 | HP Pavilion dv9548us PC Notebook
Replaced engin but no spark at plug
HI WAS THE ENGINE YOU REPLACED FITTED WITH THE GENERATOR ,OR HAVE YOU REMOVED THE 1 FROM YOUR OLD ENGINE, PRESUMNG YOU USED YOUR OLD 1 WHICH YOU KNOW WORKED BEFORE YOU REPLACED YOUR ENGINE, I WOULD SUGGEST YOU GO OVER YOUR CONECTIONS CHECKING THEY ARE ALL CORRECT, POSS, SIDE STAND SWITCH FAULTY: IS YOUR STAND UP IN THE HOME POSITION? IS THE ENGINE CUT OFF SWITCH IN THE CORRECT POSITION? DO YOU HAVE THE DRIVE CHAIN FITTED, IF NOT IS THE BIKE OUT OF GEAR WITH THE SIDE STAND UP THIS COULD CAUSE LOSS OF SPARK IF THE STAND IS DOWN WITH THE CHAIN OFF, THESE ARE A FEW SIMPLE CHECKS, THINK SIMPLE SOME PEOPLE THINK COMPLICATED REMEMBER IT SPARKED AND RUN BEFORE, WOULD LIKE TO KNOW IF YOU REPLACED GENERATOR WITH THE ENGINE.
Aug 05, 2010 | 1992 Aprilia AF1 125 Futura
Wire from generator not on plug
Hi and welcome to FixYa,
Per you need of "...wire diagram for generator area...", please see below. Should you be interested, the full wiring diagram for a Yamaha XT600E maybe viewed here.
Good luck and thank you for asking FixYa. Happy Holidays.
Dec 25, 2009 | 1991 Yamaha XT 600 E
Conecting to my pc computer with my psp
Jul 31, 2009 | Sony PlayStation Portable (PSP) Console
Hi, i have a clarke generator g900 ,no spark
I hope this helps
Peter
Jun 22, 2009 | Electrical Supplies
Gas Generator SPark Problem
Hi jeff best regards savumihai7
Inside of the rubber boot,at the plug wire terminal there is a spring making connection with the ignition coil(under the flyweel).Check the connection first.Try if there is a spark.If there is not,. remove the flyweel.You will see the coil and ignition wires.Check them by mearurement.Remove the spring and the cover and under it there are breaker points(they has not to be burned).The excentric on the crankshaft open the breaker points(gap) to have spark.Also clean the armature and the magnets from flyweel.Let me know.
Dec 15, 2008 | Electrical Supplies
Electrical Supplies Logo
23 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
