Question about Pool & Spa
Need shaft seal for everbilt 1 hp sprinkler pump
    Top Expert:
  • 42,026 Answers
Try pump retailer shops or irrigation supply shops for spares
Posted on May 20, 2017
How do I fix the seal?
please follow this steps . God bless you
  1. Turn off the pump motor and close the input and output valves.
  2. Loosen the fasteners that secure the tube connecting the pump and motor.
  3. Move the motor away from the pump housing.
  4. Remove fasteners holding the diffuser to the backplate.
  5. Inspect the diffuser and O-ring for wear, replacing as needed.
  6. As needed, remove fasteners attaching the impeller to the shaft. Alternately, the impeller may be screwed on to the end of the shaft.
  7. Remove the impeller and seal from the shaft.
  8. Inspect and replace the impeller and seal.
  9. Reassemble the pump.
Nov 23, 2013 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Moter leaks when filtering
Is it leaking at the motor shaft or where the filter gasket and pump housing bolt together? If between the two housings,then it may just be a matter of tightening the screws that hold them together. If it is leaking around the shaft, you will need to replace the mechanical shaft seal.
To replace the seal you will need to remove the housings and then unscrew the impeller from the shaft. There is a slotted end on the other end of the motor shaft for screwdriver. This will hold the shart still while you unscrew the impeller. The shaft seal is a precesion part so be careful when replacing it.
Let us know if this helps, Robert
May 16, 2012 | Craftsman 1 - 1/2 Hp Pool Filter Pump
STA-RITE 5P2R-125G with 0.75 HP motor. Had bearings in motor replaced and was advised that shaft seal is also replaced. Now have a leak from the motor side of the seal plate at the bottom. They replaced...
the absence of the copper cone will not cause a leak, however, there is a different shaft seal that needs to be used in lieu not having the copper cone installed.
If the impeller is damaged or cracked, that can cause a leak at the shaft seal. If you replace the impeller, the shaft seal will most likely need to be replaced as well.
Feb 23, 2012 | Hayward 1 Hp 2 Speed Super Pump Inground...
LEAKING A SMALL AMOUNT OF WATER COULD THIS BE A SEAL?
ON A HAYWARD IT'S A TOSS UP, COULD BE THE SHAFT SEAL OR THE TANKS ARE KNOW FOR CRACKING. FIRST THING YOU CAN TRY IS REPLACING THE SHAFT SEAL .. LOOK ON EBAY FOR HAYWARD SHAFT SEAL WITH HOW 2. THE SEAL YOU NEED IS A 201. AND SHOULD COST AROUND 10 BUCKS. FALLOW THE INSTALL INSTRUCTIONS. OR YOU CAN TAKE THE PUMP APART AS FALLOW HERE ..AND BRING IT TO YOUR LOCAL POOL PUMP REPAIR GUY .. JAY
Jun 17, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
How to separate motor from 1/2 HP sprinkler pump?
To do that you need to take the pump apart...take the bolts out that hold the motor to the pump and then unscrew the impeller from the pump shaft....
All this is not easy and will be very difficult if you are not experience and handy with your hands...
getting the impeller off in one piece can be the toughest part...
heatman101
May 10, 2011 | Sta Rite Industries Shallow Well Jet...
Pump is leekin water
there are a couple of places where the pump may leak. The discharge fitting, the seal plate o-ring, or the shaft seal. If the shaft seal is leaking, water will be dripping from the bottom of the pump where the motor mates to the seal plate.
Sep 16, 2010 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Looking for shift sell for Flotec: FP5162
I've never heard of a shift sell for a flotec water pump. That is if you are looking for a part for a Flotec sprinkler pump. Maybe you're looking for a shaft seal.If you need parts or a manual you can look at www.flotecpumps.com The flotec part number for the mechanical seal and gasket kit is:5PP5000. You can search their web site for local suppliers, I'd call first to see if they'd have part in stock. Follow directions when installing. Do not use oil or grease to lube new seal. Liquid dishwashing soap is best.
Jul 12, 2010 | Flotec 1 - 1/2 Sprinkler Pump Composite...
MAGNUM POOL PUMP 1-1/2 HP MAGNUM PUMP BY: how do i replace the shaft seal...
You should be able to remove the diffuser and then the impeller to gain access to the shaft seal on these pool pumps. Your users manual should have a diagram.
May 16, 2010 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
1-1/2 hp sprinkler pump hangs up and just hums sometime
The impeller and or bearings are seized. You may have to force the impeller loose (breaking it to get the unit apart). See if you can obtain the bearings and impeller and shaft seal before attempting the overhaul. Be aware that the hardware attaching the motor to the pump housing may need lubrication before attempting to remove.
Apr 06, 2010 | Pool & Spa
How do you remove the motor from a Flotec FPS5172, 1-1/2 HP.
The impeller screws on the motor shaft. First replace the through bolts in the motor. These are the long bolts, they will just cause headachs. On the back of the motor their will be a place to hold the shaft from turning, If you hold the shaft the impeller just unscrews. If you look in the center of the impeller it may have a set screw holding it to the shaft. If you have one of these it will be a left hand screw. Then you will need to break the impeller free as the brass that holds the impeller on will stick to the stainless steel of the shaft. Don't let how tight this is fool you when you put this back together it just goes on hand tight. Good luck
Nov 23, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
