Question about Sander Tools & Hardware - Others
My D26441 sander stopped vibrating during normal use. Motor still on & getting hot.
    Top Expert:
  • Sander Master
  • 48,272 Answers
Motor /armature problem
could be worn out brushes
take it in for an inspection and quote
Posted on May 20, 2017
I have a Makita belt sander,just replaced belt tensioner system including springs and roller but belt drive roller still keeps stopping on relatively light load even though the motor is running
very good trade tool
how quickly is it getting hot
slowing motor could be the cause
motor bushes and bearings can be replaced
did the motor drive belt under the cover get replaced
Jun 02, 2016 | Makita 9911 Compact Lightweight 3" X 18"...
Where to apply grease
There are no parts in your sander to grease. The only place there is grease is in the three sealed bearings on the armature and in the platen. Everything should be clean and dry inside the sander to make it less likely for sawdust to stick inside the tool. Blow everything out and replace the bearings if they are not turning freely and smoothly.
Dec 01, 2012 | Dewalt D26441 - Palm Sander, 1/4 Sheet
I have a Dewalt sander I am using for wet sanding on a boat hull. I have already burned one sander out do to moisture I figure is there a way to protect the new sander from this happening again I am...
Impossible not to get water in the bearings and motor. It is vibrating too fast. You need air sander. Or sand dry, then wet sand the primer by hand.
Dec 17, 2010 | Dewalt DW421 5'' orbital sander
Porter Cable 7800 Drywall Sander ran fine, stopped and ate supper, went back to work and motor will not come on. Vacuum is working fine but cannot get motor to turn on when flipping the switch. Did not get...
Sounds like a problem with the ON/OFF switch. Hit it with a bit of contact cleaner or WD40 and work it a dozen or so times, it may just be dirty...... at least if you are lucky.
Sep 18, 2010 | Black & Decker Black Decker/ Porter Cable...
The vibrating plate stopped vibrating but the motor seems to be working ok. Either the plate is jammed or something broke. What do you think? This sander is probably 30 years old, very heavy duty.
check the bearing in the platen, it is probably seized up. you can go to and download a breakdown for this tool. Let me know and I will try and help further.
Aug 08, 2010 | Milwaukee Tool Milwaukee 6010 - 6 1/2...
The motor buzzes slowly, it seems to be labouring and the plate rotates very slowly. Its as if the motor is blocked up inside. I've taken it apart and removed as much fine dust as possible but this hasn't...
sounds to me like the bearings are locking up, you can go to and type in your model number and download a parts explosion for this tool so you can see the replacement part numbers. when you had it apart did you see any indication that the field was rubbing on the armature?? I would take a close look at the bearings though.
Jan 23, 2010 | Dewalt D26441 Heavy Duty 2.4 Amp 1/4 Sheet...
No sanding action and motor just buzzes
It will probably be the shaft from the motor to the orbital cam which is on the flat plate that you connect the sandpaper to , either the shaft or the bottom cam is broken [probably the shaft has snapped ] you can do a cheap repair with a good glue to reconnect the shaft [but you wont be able to push too hard again] or if you can get the parts just replace the shaft into the motor . they are really simple things to work on
Mar 30, 2009 | Dewalt D26441 Heavy Duty 2.4 Amp 1/4 Sheet...
I have a d26441 sander. No instructions. Are the
Do not break anything. Go to and type in your model number in the middle of the page at the bottom and download a user manual for the tool. It should have come with what is called a punch plate to perforate the sandpaper for dust pickup (such as it is) Go there first and you will find everything that you need to use the tool
Mar 09, 2009 | Dewalt D26441 Heavy Duty 2.4 Amp 1/4 Sheet...
Porter Cable 7800 Drywall Sander- Head overheating/motor laboring
the drive shaft is probably going bad. If all the greese is gone then it will cause it to heat up. you can find parts and diagrams to fix it at search for modle number 7800 under the parts section.
Mar 08, 2009 | Black & Decker Black Decker/ Porter Cable...
Sander failure when using honda generator
If you are using a 220 volt 4 hp floor sander, which is 95% of all floor sanders. you CANNOT use a generator less than a 25KV, which is about the size of a van. All Floor sanders draw over 80 amps at start up and during floor sanding all sanders run around 25 amps. If your motor is a Capactor style motor you can do detrimental damage to the motor. Many of my customers have done it in the past.
Dec 24, 2008 | National Tools & Hardware - Others
Tools & Hardware - Others Logo
52 people viewed this question
Top Sander Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sander Tool and Hardware - Other Expert? Answer questions, earn points and help others
