Question about Electric Garden
Task Force 12 Amp 20 in electric mower will not start when bail lifted. In starting assembly, a cylindrical piece has one of the side parts broken off. Want replacement part.
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Microwave vent fan replacement
(I'm assuming you're talking about the hood / vent / exhaust fan instead of the internal magnetron cooling fan).
The part # SMV-260UA-C will not be enough to go on, as there at least 3 variations on that number shown at Samsung parts.
These microwaves are made by Samsung, but you'd need the GE part number to replace the whole thing. They don't sell the blades separately.
The part # for the "ventilation motor" is WB26X10042 and you can find it for $97.11 here, which is about fifty dollars less than direct from GE.
I may have available a replacement flan blade off a used unit. If you'll send me the dimensions, I'll check. I need the length of the fan blade, the diameter, and the inside diameter / shaft size, and whether the shaft is round or "D" shaped.
Please feel free to contact me directly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 28, 2008
SolutionGuy
  • 331 Answers
SOURCE: Flint on the electric ignition of oven is broken, need to replace
Hey DM,
The part in question is called an igniter and can be purchased at your local appliance parts retailer.
It's not that difficult to replace the igniter. I can't give you an exact part number, but it'll be either the round style or the flat style. (You really don't need to know the part number, just ask your appliance parts guy for either flat or round igniter. They are both universal as far as brands are concerned. But if you're the curious type here are the numbers; Round= 4342528 and Flat= WB2X9998. Don't use the part numbers I linked to, above. The numbers there are specific to Repair Clinic, and NOT actual OEM part numbers)
Now for the fun stuff... the actual repair!
PULL THE OVEN OUT SLIGHTLY, REACH BEHIND IT AND UNPLUG IT!!!
Tools required:
1.) 1/4" socket or nut driver
2.) Flat or Phillips screwdriver
3.) Pliers
4.) Wire cutters
5.) Wire strippers
Remove the racks and then remove the "floor" panel of the oven. Then remove the diverter panel (might be a 3/8" nut or a wing nut... use the pliers here). Basically, you disassemble the entire bottom of the oven. You may need to pull the lower drawer out, as well.
After you have gained access to the igniter...you'll see that it's attached to the main manifold with two 1/4" screws. Word to the wise, here... use a little bit of liquid dish soap on the threads BEFORE trying to un-screw these. This will lubricate the threads and keep them from stripping. If you don't heed this warning and they strip? You'll have to grind them off in order to get the igniter removed.
Wire cutter time... snip the 2 white wires about 3" from the base of the old igniter. Wire stripper time... strip those 2 wires about a 1/2".
Now the old igniter is out. Pull out your new igniter. Cut any extraneous stuff off the END of the wires then strip them about a 1/2". Now mount the new igniter to the manifold (where the old one came from). Now take one wire (doesn't matter which one) from the new igniter and twist it to one of the wires you cut and stripped while removing the old igniter. Then use one of the ceramic wire nuts (included with your new igniter) and twist it on the exposed wires clock wise. Make sure there is NO WIRE EXPOSED after doing this. If there is, remove the wire nut and cut a small amount of you twisted wire pair off.
ALL OF THE EXPOSED WIRE SHALL BE INSIDE THE WIRE NUTS.
Do the same thing for the other wire. Now tuck all of the extra wire away. At this point, you're ready to test your handywork! Set it to bake and watch her light up!
All that's left to do now is rebuild the lower oven, grab a coolada and get some cookie dough. I'll be over at 6:00 for snacks :-)
SG
Posted on Mar 20, 2009
  • 62 Answers
SOURCE: Z force 48 in. cub Cadet mower starts but dies
Check the wires to the seat switch. Under the seat you should find 2 wires connected to the seat. Unplug them, and use a jumper on the end that goes into the body of the mower. Try it again, and if it works, replace your seat.
Posted on Apr 18, 2009
  • 41 Answers
SOURCE: turn the key for electric start,nothing happens
If you never used the starter,You need to have it checked, possible that it i froze up. Or brushes in starter arn't making contact. Also check connections. Good Luck
Posted on May 19, 2009
  • 5 Answers
SOURCE: Mower started smoking, then stopped working.
Try to see if there is any oil in it. Or maybe your belt is clogged. A good cleaning and maybe a change of plug may help.
Posted on Mar 02, 2010
How do I remove an item that is stuck in my toilet?
Depends?. (Think about it.... this is a bad joke)
- Sometimes you can use a short piece of wire like a bent clothes hangar.
- A Plumbers plunger (rubber force cup) will often work.
- Less fun but guaranteed:
- shut off and disconnect water supply
- bail out bowl and tank.
- remove bolts that secure toilet to floor.
- lift toilet off mounting flange.
- remove object
- re-assemble using new wax seal.
OR
Call a plumber
Dec 30, 2015 | Home
Task force electric lawn mower fix
Try Googling (task force)(25143)(manual) without parens.
Feb 21, 2018 | Garden
Electric Mower zapped?
They should replace it. They broke it. If it was just a cut in the cable it should work again, but they have probably burnt it out. Change the fuse first also as that would have popped.
Jul 13, 2013 | Garden
Neighbor mowed the extension cord and mower won't start
Check the cord has been properly replaced. Check circuit with a meter (NOT connected to mains) The live pin on plug should connect to live pin on motor switch etc. (need to take off cover on switch unit)
Cutting through the cord should not have damaged the mower.
Jul 13, 2013 | Electric Lawn Mower
Electric Mower electrocuted?
wire disconnect in lawn mower.
Task force 12 amp electric blower support
Check the plastic tab that should engage the red safety interlock switche near the inside of the hinge. Both the tube and impeller cover should have them tall enough so they push the red contacts up all the way.
Mar 19, 2012 | Garden
I pulled out the pug to recharge the starter for key start, and lost the outer plastic casing to plug it back in. Can I order the casing for the exposed prongs
The 10640 model does not have an electric start that I can see. Are you sure you have to model number correct? The 10642 and 10642C models are electric start. I will use the 10642 as a parts reference.
The electrical assembly is here:
http://www.partstree.com/parts/?lc=lawn_boy&mn=10642%2C+20in+Mulching%2FRear+Bagging+Lawn+Mower%2C+2009+%28SN+290000001-290999999%29&dn=3361337A-392215-0007
Where did you pull the wires out from? The battery box? The mower harness? The switch?
From looking at the parts available you should be able to figure out which part you need to replace.
Kelly
May 22, 2011 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
White LT-12 lawn tractor 139-656-190 Mower deck on right side is out of alinement. Rear tire rubs on deck when lowerd. How do I ajust the deck?
I have exact same problem with my 1989 built LT-12 White tractor ! I Discovered that the Right side connecting Link #14802A,that connects the lift handle shaft #17154A with the Stabalizer bar #16465A, was broken where it connects with the Deck Lift handle shaft.
May 07, 2010 | Oregon Scientific Electric PTO Clutch for...
I started mower in tall grass. It started up and immediately stopped. Could not get it started. Replaced battery. Charged 12 hours. Still will not operate. Green light is on. Noticed the blade seems to...
After charging the mower, you must place the safety key in the mower before it will start. On models that have a bail handle, be sure to pull the bail handle back to the mower handle before engaging the start lever. If your mower still does not start, remove the safety key and ensure the bail and start lever are in the "off" position. Then firmly re-insert the safety key, pull the bail handle to the mower handle and engage the start lever.
Note - It is important that the bail and start lever are returned to the "off" position before inserting the safety key.
Give it try, if it still will not operate you may have to take it in for service.
Good luck, let me know.
Regards,
Jul 30, 2009 | Black & Decker 19" Electric Lawnhog...
Garden Logo
23 people viewed this question
Top Electric Garden Experts
dannydoesita
JohnPaul Robertson
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
