Question about Vizio Computers & Internet
Vizio Model # L37HDTV10A - Are the inverter transformers the same on the master & slave boards?
The slave board is available, but the master is not.
rlamkin
  • 44 Answers
SOURCE: Replacing backlight inverter board
Not always but usually the inverter board is part of the display panel, way to much money to bother fixin.
Posted on Jul 03, 2008
circuitworld
  • 335 Answers
SOURCE: Vizio L42HDTV LCD
Be sure the inverter is getting 24vdc at the input first. Could be the DC supply too the inverter.......
Posted on Nov 17, 2008
  • 718 Answers
SOURCE: Vizio L37hdtv10a fails to fully turn on
You will have to isolate the main board and Inverters.
Unplug the inverters and turn on the set.
If it "turns on" then try re-connecting each inverter seperately to see if only one is causing the problem.
Posted on Mar 07, 2009
dsacco86
  • 1077 Answers
SOURCE: need inverter board for vizio L32 model an idea on
You can get a replacement inverter board at this link below:
http://www.shopjimmy.com/catalogsearch/result/?q=vizio+L32+inverter
Just make sure you match up the part number on the board.
Posted on Jun 10, 2009
  • 1039 Answers
SOURCE: Inverter Board
Disconnect the slave. If the set operates replace it. If not the main is bad.
Posted on Jan 23, 2010
My vizio when I turn the lights off and hold a flash light to it I can see the pic so I think the back light invert is no good but which the master or slave back light inverter?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jul 18, 2016 | Vizio Televison & Video
No picture no sound just a black screen
I just repaired this LCD tv exact same model.
symptoms- when the tv turns on, all I get is a black screen with blinking green light. No other error codes. It was crazy frustrating trouble shooting this. I measured the transformers on the master and slave inverter board with a multi meter. The resistance should be 1.31 k ohms. All but one measured within the specs except one. I get an OL reading. I took a chance to order this part on eBay for 13 dollars. After soldering it, the resistance for all of the transformers were back to specs. The tv powered on and stayed on. Works good as new. If anyone has the this similar issue I would advice testing the mini transformers on your master and slave inverter board. My email is normanw1@yahoo.com for help.
lcc5255u aquos fixed
lcc5255u aquos resolved
Apr 10, 2014 | Sharp LC-C5255U 52 in. LCD TV
My 42 inch lcd vizio tv flashes like a stobe lite after a minute of powering it on then goes black what can i do
That sounds like an inverter problem. Check the capacitors on the inverter boards. There will be two on each board. The master inverter will be on the far left side, and the slave will be on the far right side. You will have to remove the metal covers over the inverter boards. Should be 4 small phillips head screws. If the capacitors have bulging tops, replace them.
Jan 15, 2013 | Vizio VX42L 42 in. LCD TV
Strobe
Check the capacitors on the master/slave inverter boards. I just repaired a Vizio VW42LHDTV10A with the same problem. Cost to repair $2. The master and slave inverter boards should be on the far left and far right sides of the TV set. They both have metal covers installed over them so you will have to remove the covers to access them. I'm willing to bet the tops of your capacitors are bulged.
Sep 23, 2012 | Vizio VW42LF 42 in. LCD HDTV
Vo42l no picture. please help!
I had the same problem. No picture but sound. When I turned on the tv, and shined a flashlight around the screen from about 3 inches away, I could it was displaying something.
At first I replaced the main board which has 0171-2272-2604 stamped on it. You can google Vizio VO42L service manual and get a pdf which will show how to remove the back. I got the board from TSM www.tristatemodule.com3642-0482-0150 3642-0482-0150 Vizio TV Module, main unit, 0171-2272-2604, 3642-0482-0395, VO42LFHDTV10A 1 $88.95 $88.95
Order Notes: None
SubTotal:
$88.95 Shipping: USPS Priority $20.00 Tax:
$0.00 Total:
$108.95 However, after I replaced this board I still had the same problem. So next I replaced the Invertor boards. There is a Master and a Slave board to the right and left sides of the main board. I ordered these from Coppell tv.
on Ebay.
6632L-0470A & 6632L-0471A INVERTER REPLACEMENT SET - NEW, OEM, WARRANTY ( 110882329800 ) 110882329800_1.jpg Paid on Jun-08-12
$49.99 -
$49.99
USPS First Class Package Estimated delivery: June 13, 2012
These are compatible replacement inverter boards and work well. All I had to do was bend a tab on the aluminum cover that goes over the boards. After installing these inverter boards the Vizio display works. I started with main board replacement because from what I read online, the problem was either the mainboard (which had the most posts) or the inverter boards. So I picked one.
Install tips:
Download the PDF Service Manual VO42L FHDTV10A_LPL,AUO Service Manual.pdf for some help with the back cover.
When you take all the screws out, set them aside in the same pattern they were on the board for ease of putting the back in.
I was not able to remove the connector on the Ribbon cable between the master and slave invertor, so I left it attached and carefully undid all the tape and removed the boards attached. I plan to send the old boards to Coppell TV (really nice to work with) for their re-use.
I hope this helps.
Feb 27, 2012 | Vizio VO42L 42 in. LCD TV
I have a Vizio VX42LHDTV10a To fix screen that
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
May 08, 2017 | Samsung LN-S4041D 40 in. LCD HDTV
Picture goes out after about 10 minutes. Vizio L37HDTV10A
You need to open up the set and measure the DC voltage on the backlight inverter board to see if you have the 24vdc after the picture goes out, if you do have the 24vdc, then the problem is in the inverter board, if 24vdc is gone then it will be in the power supply. parts: http://www.shopjimmy.com/catalogsearch/result/index/?q=l37hdtv10a&limit=200
Jan 04, 2010 | Vizio L37 Television
Mar 04, 2009 | Vizio L37 Television
Vizio L42HDTV LCD
Nov 09, 2008 | Vizio GV42L 42 in. LCD Television
Jun 20, 2008 | Televison & Video
Computers & Internet Logo
Top Vizio Computers & Internet Experts
Jessi Singh
Level 1 Expert
ray gallant
Are you a Vizio Computer and Internet Expert? Answer questions, earn points and help others
