Question about Building Materials
The garage door just stopped working. Is there a reset button or a fuse?
SOURCE: i have a pmx300IC genie
palm treo 700w off no open
Posted on Jan 19, 2009
Doorguy27
  • 30 Answers
SOURCE: 1.3HP CRAFTSMAN CHAMPION GARAGE DOOR OPENER-NEW IN 2004
Well sounds like its a pressure setting. you said you open the door by hand? Was it easy to do? Ask your self this can a 15 year old kid open it and close it? If so then it sounds like its a presure setting There should be two blue slots on your opener with numbers 1-9 says up and down force. Turn the up force towards the bigger number. Just a little bit. But before you do that as the other guy stated make sure that your cables and springs are working. Spring depending on your doors can be in three places but we going to assume you has the most common set up so look over the top of your door (with it closed) you should eb able to see a tube running across there. and somewhere in the in middle a set of spring look at the spring to make sure that you dont see any of the tube showing in the springs. Becare not to touch the spring as they are under a lot of stress.
Posted on Feb 10, 2009
  • 3197 Answers
SOURCE: Code reset button for garage door opener
The button is just to the left of where all those white wires go. You may have to remove a light lens to get to it.
Posted on Jun 08, 2009
  • 3197 Answers
SOURCE: Remote control for garage door suddenly stopped working.
Press and hold for 3 seconds the button on the wall control with the lock icon. There you go.
Posted on Nov 21, 2009
swolfinor
  • 504 Answers
SOURCE: Homelink garage door opener
GOTO HOMELINK.COM
THEY MAKE THE SYSTEM AND HAVE INSTRUCTIONS YOU CAN DOWNLOAD.
ALSO GOOD GUIDE FOR TROUBLE SHOOTING.
HOPE THIS HELPS
Posted on Jun 15, 2010
My remotes will not activate the opener from anywhere but inside the garage. Worked fine the first month then stopped
2 possible solutions; #1) unplug the motor for 3 mins then replug (resets memory) #2) on back of motor is a "learn button" - press learn button for 3 sec, then press your remotes for 3 sec.
Feb 19, 2011 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener has stopped working. No
There isn't a reset but make sure the trolley isn't jammed against the bolt just in front of the motor unit.
Mar 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Hi, My garage door stopped working when I tried to close it. I have Craftman 1/2H HBW0777. The Fuse went OOS. I turned it back but the opener doesn't work
sounds like the motor turning and overpowered the circuit. first you should unplug the opener test for power at the recepticle. if you have power you know its the motor. or something is caught in the track preventing the door from coming down. after you test for power.pull the release that attaches the opener to the garage door and try to manually move the door up an down. with the door still unattached look for a reset button on the back of the opener and try it without the impedence of the load of the door
Sep 30, 2009 | Electrical Supplies
Garage door motor reset button must be pressed to work again
It sounds like you have a bad wall control. You can check this out by replacing it with an inexpensive door bell button.
Sep 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote Control closes garage door but does not open
It sounds like a case of your keypad losing signal strength enough that it cannot transmit through the closed door. If a new battery doesn't do the job a new keypad will.
Sep 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to change the freqency on a lift master garage door
Chance are they set there remote when you were using yours. To reset your opener you need to clear all the codes on the back of your opener itself there is a square button purple or red depends on how old it is. Press and hold that button until the LCD light turns off. Press your remote to make sure it has stopped working. Then press the button again only for a sec until the light comes on and starts to flash then press your remote button. Repeat for each remote.
Feb 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener stopped working, I hit the reset button and it started working again, the wired remote on the wall works, but my 2 wireless remotes do not work, I have followed directions to...
IS THE LED FLASHING ON THE WALL BUTTON??
IF THE LED IS FLASHING THE LOCK FEATURE HAS BEEN ACTIVATED. PRESS THE LOCK BUTTON ON THE WALL CONTROL AND THE LED SHOULD STOP FLASHING.
NOW YOU CAN REPROGRAM REMOTES AND YOU ARE ALL SET.
Sep 09, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
29 people viewed this question
Top Building Materials Experts
hpgwva
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
