Question about Cub Cadet Garden
Cub cadet model LGTX1050 blows 20 amp when key is turned to start position.
  • 93 Answers
You will have a short that is causing it to blow the fuse. Check and make sure the battery is correctly installed. Red + and Black -. Other than that you would need a ohm meter to track it down. It can be several things. Hope this will help ya
Posted on Jun 01, 2017
Where is the 20 amp fuse located in a cub cadet ltx 1040?
The manual for the Cub Cadet LTX 1040 is posted at
On page 28 under "Fuse," it says that the 20-amp fuse "is located under the hood, mounted behind the top of the dash panel on the support bar."
Nov 09, 2015 | Cub Cadet Garden
Is there an ignition fuse for the cub cadet ltx 1050
There normally only one fuse is 12 or 20 amp for all power. The only exception is the main power for the starter which is un fused.
If you getting anything worjing when the ignition is turn to the on position then fuse is okay.
Mar 22, 2015 | Cub Cadet Garden
I have a 2006 Cub Cadet RZT 42 Zero Turn Mower that keeps blowing the fuse. It would blow the fuse after long periods of use but it's gotten shorter and shorter between fuse blowing. Now it blows the fuse...
you have a wire that is grounding out, I would check the wire coming from the connector on the voltage regulator to the battery. This is the one in the middle position, look for a rub through and tape it up.
Nov 02, 2010 | Cub Cadet Garden
Cub cadet lawn mower won't start and i have changed everything
What have you changed?? What model lawn mower is it? Is it a riding lawn mower or a push lawn mower? Does it turn over(engine turning with the starter), or does it do nothing when you turn the key over? I have serviced cub cadets for almost 20 years, from the very first model(1959) to present, and i own 13 different tractors myself. if anyone can help you, i should be able too. i just need more info about the unit and its problems. i look forward to helping you.... -Brian-
Oct 25, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 2160 when turning ignition switch in second position, starter motor starts spinning. blows 20A fuse
You have either a short in the solenoid trigger circuit, and a faulty solenoid. To check, disconnect the small trigger wire on the solenoid. Turn key to 'START'. If fuse blows, there is a fault in the wiring. If not, the solenoid is faulty.
Oct 31, 2009 | Garden
Cub Cadet zero turn:Engine starts and runs about 5 seconds before blowing 20 amp fuse.
You may have a faulty voltage regualtor that is blowing fuse. Have you tried a fuse that is 5 more amps?
Aug 24, 2009 | Mtd Gold 42" Zero-Turn Mower -
I have a cub cadet 1550, Blew fuse and wont disengage from gear
You have a bad wire which rubbed on the plastic housing to the engine block near the starter mower which causes a short and blows the fuse. I have the same tractor and this happened to mine also. The wire is red.
Jul 28, 2009 | Cub Cadet Garden
Garden Logo
29 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
