Question about Traulsen Freezers
Can a traulsen commercial fridge be changed to a freezer by changing out a thermostat or a set point somewhere?
  • Traulsen Master
  • 1,230 Answers
Probably not. you would need to change the expansion device. You could probably get as low as 15-20 degrees but I doubt you could do much more than that without some system changes.
Posted on Jun 19, 2017
  • 1462 Answers
SOURCE: Indesit fridge freezer (2 years old) not getting cold
if compressor is running, then you are correct in saying no point in replacing stat. by sounds of it you have a faulty compressor fault or a syatem fault - impossible to dignose by remotely. this is not a diy job i'm afraid
Posted on Jul 25, 2007
SOURCE: Indesit fridge freezer not getting cold (2 years old)
how to fix my indesit light inside the fridge reply asap
Posted on Sep 19, 2008
SOURCE: traulsen ur 48 dt freezer want go below 10 deg
The first place to look is to check the charge. Using guages check the low and high side pressures and their relationship to one another. I'm assuming your unit is a R-404 unit which, if fully charged and the condenser is clean, and the fan is operating, should have about 210 to 250 high side pressure. Other things to check: evaporator coil ice/frost free; defrosting properly to obtain a clean coil; all evaporator fans running. If low side pressure is above 30 PSI you have a weak compressor. Whatever, fix the Traulsen unit, its head and shoulders above anything else on the market today.
Posted on Nov 24, 2008
SOURCE: Weve lost the instruction manual for our Hotpoint Fridge-Freezer
Sorry, no secret. The fan wasnt working so we called an engineer who bypassed a sensor. Now it works perfectly again.
Posted on Mar 23, 2009
  • 7 Answers
SOURCE: Traulsen Commercial Freezer needs charging?
The refrigerant level is low. The only thing is that the unit may not have a low charge. There can be several things that cause the unit not to refrigerate properly. It could have weak valves in the compressor or even a bad TXV(thermostatic expansion valve). Have you had this box repaired yet.? I see that this is an old post.
Posted on May 15, 2009
Traulsen commercial freezer temperature cannot be set
Don't set hi and low. Set the "Set point" number. That is what it functions on.
Feb 25, 2013 | Traulsen Reach in Freezer - G22010
I need to set the temp and have no manual
Hi.
To download the manual Register with Hobart/Traulsen resources website.
Once you have an account sign-in and open the resources tab on this page.
Regards.
Ginko
Sep 08, 2011 | Traulsen 46 cu. ft. / 1303 liter...
The unit not rich temperature
Hi, This can tell us many things such us : -; Compressor malfunction - Low refrigerant level - Thermostat wrong setting or malfunction - Door ajar - etc.
My suggest go check and fix ( if any problem) with first 3 items above ( these item have potential problem that cause you never reach your intended temperature).
regards,
Dec 16, 2010 | Traulsen 24.2 cu. ft. / 685 liter...
Need manual for a Traulsen G12010 commercial freezer
try using manuals online or try this site www.commercialappliance.com
May 16, 2010 | Traulsen 24.2 cu. ft. / 685 liter...
Hi,i would like to know how to set the traulsen intela-tarul digital thermostat and how to put it in defrost mode
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Part 257 on this diagram is your defrost timer http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=TFX22JABAAA&productCategoryId=0165000&brandId=0432&modelName=REFRIGERATOR-B-SERIES&diagramPageId=00005&componentDescription=FRESH%20FOOD%20SECTION&documentId=E2134230&backToLink=Return%20to%20Sub%20Components%20list
Aug 19, 2009 | Traulsen 24.2 cu. ft. / 685 liter...
Very loud compressor in traulsen freezer
It's probably a hermetic compressor. Nothing can be done. It's got an internal rattle, possibly defective valves, or freon was avercharged.
Aug 02, 2009 | Traulsen 7 cu. ft. / 198 liter Commercial...
Dec 09, 2008 | Traulsen 24.2 cu. ft. / 685 liter...
Traulsen URS36DT:
checking a def system is kind of easy. if you have located the defrost timer just turn the little knob on the timer until the unit shuts off, shortly you should hear "hissing and pooping" from water dropping on the heater. this lets you know that the defrost thermostat is good. if you dont hear this noise check your def thermostat and heater for continuity. if you put it into def and the heater comes on then you have a bad timer..
Dec 11, 2007 | Traulsen 7 cu. ft. / 198 liter Commercial...
Freezers Logo
180 people viewed this question
Top Traulsen Freezers Experts
Dennis Boxerman
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Traulsen Freezer Expert? Answer questions, earn points and help others
