Question about Select Health & Beauty
How do I tell year of jazzy select 6 wheelchair with my serial number?
  • 175 Answers
SOURCE: What kind of Jazzy select 6 power chair does my
Here's a link to Pride Mobility, maker of the Jazzy wheelchairs. This takes you to the Select 6; there's also a Select 6 Ultra. Just click on models and it will display all of their line of equipment.
Posted on Oct 03, 2009
  • 61 Answers
SOURCE: Somehow I have locked my Jazzy 6 Select Electric
Try This:
To unlock the power chair.
1. Use the on / off button to switch the control system on. The maximum speed / profile indicator will be rippling up and down.
2. Deflect the joystick forward until the control system beeps.
3. Deflect the joystick in reverse until the control system beeps.
4. Release the joystick, there will be a long beep.
5. The power chair should now be unlocked.
Hope it works.
Posted on Mar 29, 2010
  • 175 Answers
SOURCE: Jazzy Select 6 Indoor Power Wheelchair: how to charge...
The Jazzy Select 6 requires an off-board charger. Plug the charger into a grounded outlet; preferably one that doesn't have other large loads on the circuit like refrigerator, freezer, microwave, etc. The male 3-prong XLR connector coming off the other end of the charger plugs into a female XLR connector which is on the joystick control's bottom-rear. Charge it overnight after each days use, and at least once each month overnight. You should get 2-4 hours of use from the chair at top speed with a 200 pound driver, depending on terrain and climate. If it isn't holding a charge, you will probably need two new U-1 type gel sealed batteries that run about $120.00 or so each. Make sure you test the old batteries first at a knowledgeable battery shop. These are deep cycle batteries and require a special testing. If the batteries are good, then your charger isn't charging. Search EBay or other online sites for a wheelchair charger in the 4-6 amp range. They can be found for about $45.00 or so. Pride will charge you a lot more.
Posted on May 23, 2010
HoverTech
  • 232 Answers
SOURCE: replaced battery in jazzy 600
Make sure that your drive wheels are engaged and the power chair is not in the freehweel position (so it can be pushed).
Posted on Oct 29, 2010
SOURCE: My Jazzy select wheelchair does not run
According to the troubleshooting sheet, the parking brakes have a bad connection.
"9 Flashes:
The park brakes have a bad connection. Check the left and right motor connections and
wiring.
Check to make sure that the power chair is
not in freewheel mode."
Pride Mobility Troubleshooting Sheets
Posted on May 19, 2013
What batteries do I need for a jazzy select6 pride
information and batteries for sale.
info
Jazzy Select 6 - Specifications, Owner's Manual, Features & Benefits
www.pridemobility.com > Jazzy Power Chairs > Models
  1. Cached
  2. Similar
In-line motor technology for increased efficiency, torque and range. Built with ease of service in mind. Easy side access batteries. Tool-less front panel access to ...
[PDF]Jazzy Select Series - Pride Mobility
www.pridemobility.com/pdf/owners_manuals/us_jazzy/us_select_series_om.pdf
  1. Cached
  2. Similar
6 www.pridemobility.com. Jazzy Select Series. II. SAFETY. Do not connect an extension cord to the AC/DC converter or the battery charger. Removal of ... Batteries for Sale
Pride Mobility Jazzy Select 6 Ultra Wheelchair and Mobility Batteries at ...
https://www.batteriesplus.com > Batteries > Wheelchair and Mobility > Pride Mobility
  1. Cached
  2. Similar
If you rely on a Pride Mobility Jazzy Select 6 Ultra powered wheelchair or personal mobility scooter to get around, Batteries Plus Bulbs can help you find the ...
Pride Jazzy Select 6 Power Chair from Pride Mobility ' 1800wheelchair ...
www.1800wheelchair.ca > Brand Showcase > Pride Mobility > Pride Powerchairs
  1. Cached
The Jazzy Select 6 Power Wheelchair from Pride Mobility is the ultimate ... Easy side access batteries; Full-length, flip-up armrests; Solid flat-free tires; Foot ...
24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger: Amazon.ca ...
https://www.amazon.ca/Jazzy-Select-Scooter-Battery-Charger/dp/B00CIZ1GW6
  1. Cached
24V 3Amp Jazzy Select 6 Ultra Scooter Battery Charger: Amazon.ca: Sports & Outdoors.
Pride Mobility Jazzy Select 6 12V 35Ah Wheelchair Battery
https://www.amazon.com/Mobility-Jazzy-Select-Wheelchair-Battery/dp/B009DKGCC8
  1. Cached
Rating: 5 - ‎1 review Buy Pride Mobility Jazzy Select 6 12V 35Ah Wheelchair Battery - This is an AJC Brand® Replacement on Amazon.com ? FREE SHIPPING on qualified orders.
ALL THE INFO HERE BELOW
Google
Nov 24, 2016 | Pride Health & Beauty
How to stop squeaky wheels
My tires squeak how can i fix the problem and what ... - Fixya
www.fixya.com > ... > Pride > Jazzy Select 6 Indoor Power Wheelchair
Apr 14, 2012 - my tires squeak how can i fix the problem and what can i use - PrideJazzy ... Question about Pride Jazzy Select 6 Indoor Power Wheelchair ... I have a mpv 5 hoveround wheel chair and I now have a flat on the front left tire.
[PDF]Jazzy Select Series Owners Manual - Pride Mobility Products
www.pridemobility.com/...jazzy/us_select_series_om.pdf
Pride MobilityJazzy Select 6 with Power Seat. JAZZY. SELECT SERIES. Including Models: Jazzy Select, Jazzy Select 6, and .... Battery charger for indoor use only. .... Take wide swings with your power chair's front wheels around any tight corners. ... desired, allow it to come to a complete stop by releasing the joystick, then push the ...
[PDF]Jazzy Select Series - Pride Mobility Products
Dec 28, 2015 | Pride Jazzy Select 6 Indoor Power...
Whre do I find the model no. n my jazzy selet
It is usually on the serial number sticker, which can be hard to find or have been removed/fallen off. If you can find the serial number, your vendor or the Invacare Co. can tell you the model, etc.
Aug 23, 2014 | Invacare Supply Group Invacare Pronto M91...
Why does my jazzy select six lights blink but wont go
The number of flashes indicate the problem. Go to Pride's website to download the service manual. It will tell you what the flashes mean and how to fix it.
Jul 20, 2014 | Pride Jazzy Select 6 Indoor Power...
How do you turn on a jazzy select lift chair?
I have no idea as I don't have a jazzy select lift chair. Sorry
Jun 12, 2014 | Pride Jazzy Select 6 Indoor Power...
My jazzy wont turn on
call 1-800-800-8586 jazzy tech support they will tell right off whats wrong
Nov 13, 2012 | Pride Jazzy Select 6 Indoor Power...
How do I tell what year my Jazzy is with my serial number ?
call 1-800-800-8586 tech support will tell you from the serial number
Sep 21, 2012 | Health & Beauty
Jazzy Select 6 Indoor Power Wheelchair: Hi! I just inherited a used Pride Mobility Ja...
There should be a place to plug the charger in on the front of the joystick. It is a round three pin connector
May 17, 2010 | Pride Jazzy Select 6 Indoor Power...
What kind of Jazzy select 6 power chair does my Mom have? Serial number J92037090688C30. We live far away from each other and I need to know what she got.
Sep 30, 2009 | Select Products Power Chair Pride Jazzy...
Health & Beauty Logo
37 people viewed this question
Top Select Health & Beauty Experts
wcdoc1953
wcdoc1953
Scooter Doctor
Scooter Doctor
Colin Taylor
Are you a Select Health and Beauty Expert? Answer questions, earn points and help others
