Question about Garden
Have 10ft by13ft gazebo can't find black removeable spring buttons to pull up middle to top button
3 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: The follower spring is broken, this pushes the
what is the exact model number on the framing nailer you have to pry the push nut off the shaft and on the finish nailer you remove the screw and then the handle. let me know and I will try and help
Posted on Jan 28, 2010
SOURCE: "Guide" button makes Sony Bravia TV go to black screen
I am having the same problem with my newish Sony Bravia. There is only a black screen when I use the "GUIDE" button. And individual channels show "No program description".
Did you ever figure out the problem?
Thanks.
Posted on Jan 05, 2011
Need a replacement canopy top for model #LP-70008
talk with an upholsterer and get a new one made
Jun 06, 2016 | Garden
Replace power button gateway sx 2311
Computer unplugged from power, FOLLOW Anti-Static Precautions.
1) Remove the Side Panel.
Viewing the computer from the Front; the Right Side Panel removes. Remove screw, pull Side Panel to the rear of the computer.
http://www.newegg.com/Product/Product.aspx?Item=N82E16883113140
Click on the large main photo.
There are 9 smaller views shown. 3 across, and 3 rows.
Bottom row, click on the photo in the Middle.
Shows Rear view of computer.
Along the back edge of the Side Panel, is a finger pull handle formed out of the Side Panel. There also looks to be two screws. One above the pull handle, one down towards the bottom.
2) Remove the Front Bezel.
Click on the Middle row/middle photo.
Also look at Middle row, 3rd photo. (Photo all the way to right)
There are 3 Black tab locks, formed out of the plastic of the Front Bezel. One towards the Top, one in the Middle, and one towards the Bottom.
If memory serves these tabs are gently pulled to the outside, to release the Front Bezel. Ease the Top tab out a little, and Middle tab.
Start easing the Front Bezel away from the metal framework, of the computer case, a little. Then release the Bottom tab.
Front Bezel should swing, and then come off.
Not your Gateway model of computer case, but this Gateway model shows the plastic Tabs to release,
http://support.gateway.com/s/CASES/3501975/3501975faq6.shtml
The Power On Button is an assembly. The plastic housing of the Power On Button assembly, has a Power On switch inside.
I gently heat the plastic with a hair dryer, moving the hair dryer back, and forth at it.
Once the tabs of the plastic, of the Power On Button assembly, is softened; then I remove the Power On switch.
I have found this ATX power on switch, fits a LOT of desktop computers,
http://www.directron.com/atxswitch.html
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 19, 2012 | Computers & Internet
How to start it up
Hold down the middle button on the left arm until the green light on the inside right arm comes on...to pair the glasses to a device,hold down the middle button on the left arm until a solid red light comes on the right arm on inside of the arm if your device asks for a code its 0000 that's all zeros
Jul 05, 2011 | Oakley O Rokr Pro Sunglasses
How do i replace front dash power point in my f-150 2005 model
You will need to pull the center trim panel from around the radio.
Open the ash tray, and pull on each lower corner to release the spring clips. Once the 2 bottom clips are released, work you way up to the top, there are 3 spring clips on each side ( circled in black in the picture below ).
Be cautious when you get to the top of the center trim panel, the Passenger Airbag Deactivation ( PAD ) indicator has very small AWG wire on it, and if you pull too hard they can be damaged ( circled in Green )
Once you have the released from the spring clips, you can jsut set it off to the side or remove it ( HVAC clamp over connectors and the cigar lighter circled in blue, could also have the Park Aid button and traction Control button if equiped ). The Power point can be reached from the area below the radio, tabs lock it into place.
Mar 10, 2011 | 2006 Ford F-150
The swith is not working and no light is coming in the cook or warm mode.
first try to remove the pot, then push the button in middle of the ricecooker..if th cooker light turn on then the problem is the spring..try to open your rice cooker, you will see the spring inside, try to stretch the spring
Aug 30, 2010 | Black & Decker Black Decker RC3406 6Cup...
I am looking for instructions to a simona collection gazebo I purchased at menards, help.
I am looking for instructions to a Garden Treasures Living 10ft x 12ft steel Gazebo Model #S-1210GZ item #126382. Thanks for your help.
Aug 15, 2010 | Garden
How do I replace a battery?
Remove upper plastic panel by grasping sides near the bottom. Pull hard, rocking a bit. Replace 4 AA batteries (smooth negative end of battery should touch each spring). To set up codes: Press black button on electronic panel, enter first code (4-8 digits), then press lock button to set code. You should hear a 2-second beep. Press black button twice, enter second code, then press lock button. You should hear a 2-second beep. To test codes: Press lock button, then enter code. Lock should retract. Repeat for second code. If both codes are working, replace plastic cover over electronic panel. Position top of cover, then snap bottom of cover into place.
User manual is here:http://www.weiserlock.com/PDFs/install_sheets/pb_eng_install.pdf
Jul 15, 2009 | Weiser Lock Powerbolt 1000 Lock
LA PAVONI PISA
Ah ha! I just fixed the problem.
The black steam knob is bonded to the shaft. The shaft/knob assembly is removed by rotating the spring keeper on the brass housing the shaft fits into by 90 degrees to allow the shaft to be pulled out once the knob is rotated enough to disengage its thread from the brass housing.
Once the cover over the boiler is removed you will see three thermostats mounted on top of the boiler.
The middle one has the reset button located between the two power connectors. Push it down and you will hear a metallic snap as it resets.
I now have a working La Pavoni Pisa Espresso Machine again and it was free to fix it!
Wooo Hooo!!!
Jan 25, 2008 | La Pavoni Pisa PA-35 Espresso Machine
Garden Logo
19 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
