Question about Speed Home Security
My aero cool trophy series evap cooler runs ok on high cool,but when switched to low cool remains at high cool speed
The original white/Rodgers thermostat was replaced with same,seemed to work,but only for a while
mikedurland
  • 481 Answers
SOURCE: Whirpool Ultimate Care II washer Imperial Series spins at low speed
Posted on Aug 12, 2008
Fixe_You
  • 1800 Answers
SOURCE: Only have 2 speeds on a 3 speed ceiling fan- replaced switch, no
no no the problem is with the switch u need to re programm the wires check the old switch
and make the same conection.
Posted on Feb 08, 2009
  • 38 Answers
SOURCE: trouble code "malf" on my white rodgers thermostat 1F89-211
you need a new thermostat
Posted on May 07, 2009
  • 127 Answers
SOURCE: a duo therm thermostat (p/n 3105058) was removed
a. Remove the cover of the thermostat.
b. Connect the RED wire from the air conditioner
to the “RC” terminal on the thermostat.
c. Connect the “YELLOW” wire from the air conditioner
to the “Y” terminal on the thermostat.
d. Connect the “BLUE” wire from the air conditioner
to the “H” terminal on the thermostat.
e. Connect the “ORANGE” wire from the air conditioner
to the “G” terminal on the thermostat.
f. Push the thermostat wires into hole in wall and
fill excess hole with insulation.
g. Mount thermostat base to the wall with screws
provided.
h. Check all thermostat wires on base to ensure
they are completely clear of the bimetal coil of
the thermostat. Adjust if necessary.
i. Replace thermostat cover.
If nothing operates on the air conditioner, remove the
return air grille assembly and verify the red, orange, yellow
and blue wires are properly connected (red-to-red,
orange-to-orange, etc.).
Next, disconnect the red wires and check for 12 volt
DC between the red wire from roof section and the orange
or blue wire from roof section. If no voltage received,
refer to Section F2. If voltage is received, the
problem lies with the thermostat or thermostat wires.
Next, disconnect all 4 wires (red, orange, yellow and
blue) from the thermostat. With the thermostat set on
COOL mode, FAN mode set on AUTO and HIGH, and
temperature selector set lower than the room temperature. Check for continuity between terminal RC (red wire)
and terminal G (orange wire); and RC (red wire) and
terminal H (blue wire). If continuity is achieved on each,
proceed with the next step.
Set fan switch to LOW. Continuity should NOT be present
between terminal RC and Terminal H, but present between
the other terminals (Y & G) and terminal RC.
If all of the previous checks are good, the thermostat is
good, do not replace it. If any one of the previous checks
are not correct, replace the thermostat.
Posted on Jun 29, 2009
liteswink
  • 99 Answers
SOURCE: No Heat with new White Rodgers 1f85rf-275 Thermostat
The only way to resolve this problem and to distingush if its a thermostat issue on the system is to by pass the thermostat by putting a jumper between the hotwire and the heating wire if the system did run which happen most of the time. Call the HVAC technician to check your heating unit. Or call the White- Rodgers technical line at 18887259797 choose contrator division.
Posted on Oct 20, 2009
How to replace coolig fan sending unit on a 2008 chevy uplander
Why ? Did you test ? Hook up a scan tool to see if the PCM/ECM - engine computer is reading coolant temp. ? Testing not guessing ? Do you even know how the system works .
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the engine control module (ECM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood fuse block.
During low speed operation, the ECM supplies the ground path for the low speed fan relay, which is Fan 1 Relay, through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from Fan 1 Fuse 29 through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the Series/Parallel relay, which is the Fan 2 Relay, and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. The ECM supplies a ground path for the high speed fan relay, which is the Fan 3 Relay, and the Series/Parallel through the high speed cooling fan relay control circuit. This energizes the Series/Parallel relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the Fan 3 Relay coil is energized, the relay contacts close to provide battery positive voltage from Fan 2 Fuse 33 on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have their own ground path. The result is a parallel circuit with both fans running at high speed.
When the request for fan activation is withdrawn, the fan may not turn OFF until the ignition switch is moved to the OFF position or the vehicle speed exceeds approximately 10 mph. This is to prevent a fan from cycling ON and OFF excessively at idle.
Feb 27, 2017 | 2008 Chevrolet Uplander
I have 2007 Suzuki XL7. I replaced radiator and fan assembly. Fans do not work. Is there a relay? If so, where is it?
Most fan and Ac relays are located in the under hood fuse and relay box. Adequately marked in owners manual or on plastic cover
Sep 03, 2016 | Suzuki XL7 Cars & Trucks
FANS WONT COME ON ,,ALL FUSES,RELAYS AND ELECTRIC FAN MOTORS ARE NEW,,THERMOSTAT IS GOOD,,WHERE IS ELECTRIC FAN TEMP SENSOR LOCATION
op
why not post symptoms first and not a barrage of parts.
must we decode that to a symptom,. kinda hard right.
I will not guess. what is wrong, nor what is not working on your car. now what fans you are talking about, up to 4 fans on cars.
cab blower fan (wild guess blower is ok) and so is HVAC, ?
radiator fans
Condenser fan.
my wild guess to , engine over heats?????????
if yes, the scan it first. no not last FIRST.
it dont work like you think its not a 1988 Samurai.
sorry,
on modern cars, they got smarter, the engine goes
gee the PCM knows water temp why have a fan temp regulator.
hark , now it dont. (saves cash on useless parts)
but has a relay , (well until you have my car and the relay is now 100% electronic, called a huge transistor)
we've used this tech in industry for years, but car makers just learning how still.
i digress. but evolution and history helps diagnosis.
what is there?
Ill look for you, ive posted this 100s of times
the book is 4 bucks to see online. the real deal
lets look now.
XL-7 (the dash matters big time)
answering for , overheats engine, and fans on RAD dead.
(some are staged, PCM brains... now. and also chain ops based on if A/C is on or not) facts.
first I see 2 fans... ok.
the next page shows nice block diagram of the fan system
yup, NOT Simple.
ill post those words for you.
"The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the engine control module (ECM) to operate both fans together at low or high speeds. The cooling fans receive positive voltage from the cooling fan relays which receive battery positive voltage from the underhood fuse block.
During low speed operation, the ECM supplies the ground path for the low speed cooling fan relay which is fan 1 relay through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from the fan 1 fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the series/parallel relay which is fan 2 relay, and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. The ECM grounds the high speed fan relay, which is fan 3 relay, and the series/parallel relay, which is fan 2 relay through the high speed cooling fan relay control circuit. This energizes the series/parallel relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the high speed fan relay coil is energized closing the relay contacts and provides battery positive voltage from the fan 2 fuse 1 on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have their own ground path. The result is a parallel circuit with both fans running at high speed.
When the request for fan activation is withdrawn, the fan may not turn OFF until the ignition switch is moved to the OFF position or the vehicle speed exceeds approximately 16 km/h (10 mph). This is to prevent a fan from cycling ON and OFF excessively at idle.
end quote.
i bet you didnt scan it , like 99.9 % of all posters here dont.
DTC Descriptors
DTC P0480: Cooling Fan Relay 1 Control Circuit
DTC P0481: Cooling Fan Relay 2 Control Circuit
DTC P0691: Cooling Fan Relay 1 Control Circuit Low Voltage
DTC P0692: Cooling Fan Relay 1 Control Circuit High Voltage
DTC P0693: Cooling Fan Relay 2 Control Circuit Low Voltage
DTC P0694: Cooling Fan Relay 2 Control Circuit High Voltage
Diagnostic Fault Information
is the ECT showing overheat, yes no?
if yes, it must operate a fan or 2.
the book even covers all tests for fans dead, in a large truth table.
both the FSM and alldata.com have that, its no secret ,its published in 4 major places.
lets back up
if the engine coolant is low (no that side tank the engine and rad)
the ECT will lie. if that happens the fans may not come one
that is because the ECT is useless measuring air, for water.
that water must touch ECT for ECT to work.
this is FIRST
then scan the ECT does it show overheating, IT must if it IS overheating. fix that next if it lies to you,(IR gun in hand)
The system has staged fans.
i cant find the trip points in my crappyy online pages.
but is like 225f then 250f trips. is my guess...
about. if the engine over heats, check fuses first then scan it.
it will simply tell you why its bad.
eg, fan1 output dead.
or if you hot wire a fan and its dead, then it is.
(only on cars with non modulated fans,,hot wire them,else not.)
now the link to the 4 buck real book.
the non dash XL7 (my guess) you this pick yourself... cant see car.
https://suzukipitstopplus.com/Products/10182-2007-xl7-service-manual.aspx
this is how it really works
the ECU has software that decide trip points for fans.
hard coded, this is. based on how hot it is and if A/C is on not.
its way smarter than 1988 and better.
the DTC errors can see an open line, shorted to ground or stuck 12v.(runs all time error)
(tells you relay is good or not)
25839272-0kjd5huq4lpr130nt243wle5-3-0.jpg no scanner no joy , sorry, tis a fact.....
Aug 27, 2015 | 2007 Suzuki XL-7
My car 2008 Chevy Uplander warning light came on stating A/C shut off for engine protection. My question exactly as 1posted 2011. Gauge not Reading. Fan running continuously. Doesn't seem hot.
What gauge not reading , Temperature ? you posted back in 2011 ? You did feel you should take it to the repair shop ? You need to take this to a ASE certified repair facility ! This is a complex electronically controlled cooling system , Three relay's controlled by the ECM -engine control module turn the fans on in two different speeds ! There could be DTC'S diagnostic trouble codes stored in the ECM, HVAC module , BCM !
Circuit/System Description
The engine control module (ECM) commands the fans ON in high speed or low speed. In low speed, the fans are configured in series. In high speed, the fans are configured in parallel.
In low speed operation, the ECM applies ground to the coil side of the low speed fan relay, which is the Fan 1 Relay. Voltage is applied directly to the left cooling fan through the switch side of the low speed fan relay. The right fan is connected in series to the left fan through the de-energized Series/Parallel relay, which is Fan 2 Relay, so that both fans operate at low speed.
In high speed operation, the ECM applies a ground to the coil side of the low speed fan relay, the Series/Parallel relay, and the high speed fan relay, which is the Fan 3 Relay. Voltage is applied directly to the right cooling fan through the switch side of the high speed fan relay. The left cooling fan obtains voltage through the low speed fan relay and ground through the Series/Parallel relay.
When the ECM is commanding a fan relay ON, the voltage of the control circuit should be low, near 0 volts. When the ECM is commanding a fan relay OFF, the voltage of the control circuit should be high, near battery voltage.
One of the relays could be stuck on ! An for the gauge you have to have it removed an fixed , there is a stepper motor behind the gauge needle an they go bad ! Or replace the instrument cluster !
May 14, 2015 | Cars & Trucks
How do I wire blower moter
Black- high speed Red- low speed Blue- med. high Yellow- med. low White- neutral Usually black on "cool" terminal on board, red on "heat" terminal on board, and remaining 2 on the "park" terminals on board. White goes to the neutral terminals. Hope this helps!
Nov 14, 2012 | Goodman GMS90703BXA Heater
Motor does not go from low speed to high speed If the motor is set to low speed it does not turn on until the high speed range is hit then it tries to go from stop to high speed and throws thw belt
MOST OF THE TIME IT IS THE DIGITAL THERMOSTAT OR LOOSE TERMINAL AT THERM. THESE STATS ARE TRICKY TO CHECK. LIKE WHITE ROGERS 4 WIRES CONTROL WITH A RED WIRE TO GREEN YOU GET PUMP WHITE YOU GET LOW YELLOW YOU GET HIGH AND SO FORTH. MASTER COOL DOES IT DIFFERENT SO YOU BUY THEIR TSTAT
Apr 21, 2010 | Mastercool 67680 Evaporative Cooler Air...
Fan will not run on high. Compressor runs fine but the fan will not run on high. Works fine on low and med.
It's the mode switch contactors for the high setting just overview the wiring of the high cool or high fan contactors if it's not there check all leads for the high fan or high cool circuitry.
Aug 01, 2009 | Coleman Mach III Air Conditioner
Fan is slow
I dont have a solution, but I have a similar problem with a Bonaire evap rooftop cooler which only started after a tech came to look at the unit when it stopped operating properly last summer. He said it uses less water now, but the issue is that it doesnt cool any where near as effectively with the fan speed so low. I am located in Melb Australia, and wonder if you are in the same area. I am going to call service AGAIN & get the minimum fan speed returned to what it was previously. I wonder if my original unit is too small for the house - but nevertheless, it used to work beautifully and now is a very poor example of evap cooling. The service guy said the base fan speed could be altered from the controller, but we dont know how to get into the setup menu.
Jan 30, 2009 | Dometic Rooftop RV Air Conditioner
Home Security Logo
Top Speed Home Security Experts
Are you a Speed Home Security Expert? Answer questions, earn points and help others
