Question about Hunter Dryers
My hunter original does not spin clockwise after 15 years of working fine. Why?
Hunter 22272-001
If the oil is OK then check to see if it has a capacitor that might be going bad.
Dec 27, 2013 | Hunter 23852 Classic Original Ceiling Fan
2005 Honda XR 125 L speedometer cable spins backward
Hi, Chris you have the speedometer drive unit on the wrong side of the front wheel for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere $15 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
NEW HONDA XR125 XR 125 SPEEDO CABLE ALL YEARS eBay
Honda XR 125 Broken Speedometer Fix
Xr125l Bike 2003 2011 Workshop Service Repair Manual Download Manuals... $15
https://www.partsfish.com/page/oem-parts-for-honda
Honda XR125LK Owner Manual
Feb 21, 2018 | 2005 Honda XR 125 L
A customer of mine has a very nice Hunter original ceiling fan that she never oiled and now the fan just hums and wont spin. Is it possible to repair after no oil damage is done?
Put some oil in and turn blades by hand to lubricate the bearings. If the motor is frozen, then you would have to take it to a service center or send back to Hunter for repair.
Apr 17, 2013 | Hunter 23852 Classic Original Ceiling Fan
We got 4 HUNTER ceilin fans in one room. Model 27185-060 with remote FCC ID:IN2TX11 Two of them are runing clocwise another two in opsite side Wat can we do to run all in one direction?
Your Hunter ceiling fan is equipped with a small switch that changes the spin of the blades from clockwise to counter-clockwise. Regardless of the make or model of your ceiling fan, this switch is typically located on the center motor housing where the fan blades are attached. good-day!
Aug 19, 2011 | Hunter 52" Ceiling Fan With Light And...
In the summer, should ceiling fan blades spin clockwise, or counter clockwise?
Hello, in summer the fan blades should spin counterclockwise.
May 25, 2011 | Hunter Heating & Cooling
New Hunter fans installed, they operate for a period of time and then shutdown. Some time later they can be switched on from the power source. Is there an internally installed thermal device which shuts...
Howdy,
Assuming these ceiling fans are infact the 23827 Hunter Original, did you put the bottle of oil which came with the fan in them? The Hunter original requires this bottle of oil for lubrication. If you had them installed, the installer may have not put the oil in.
with the motor/s off, spin the blades. Do they spin for a long time, or do they come to a stop quickly? If these fans were just installed, the biggest likelyhood is that the bearings are seizing from lack of lubrication.
The oil hole may be on the switch housing, as in this .pdf http://www.hunterfan.com/uploadedFiles/Support/Owner_Manuals/41556.pdf
Or it may be on top of the fan, as in this .pdf http://www.homedepot.com/catalog/pdfimages/52/527f2153-5314-45aa-8cd1-310b94adc671.pdf
Jun 09, 2010 | Hunter 23827 Classic Original White 42"...
I am having a problem adding a hunter 28550 light to my existing hunter ceiling fan. The fan works fine but I can not get the light to work.
It's possible whoever installed the fan originally, did not connect the black/white striped wire to the electric box. Drop the ceiling canopy and let me know what you find.
Mar 31, 2010 | Hunter Ceiling Fan Control Switch
My Hunter (original model) fan on porch will not rotate. Can hear that the motor is running?
being on the porch humidity takes a toll on electronics..fan motor usually burns up
Nov 08, 2009 | Hunter 23852 Classic Original Ceiling Fan
Dryers Logo
19 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
