Question about Coffee Makers & Espresso Machines
I have a keurgi mimi and the water wont go down to brew
Why does the coffee maker cycle but water does not run over the grounds in the basket?
First I'm not a Brewmatic tech, but I have worked on this and other similar brands. You should call your vendor for service. Especially if this equip is on loan. *** the following is for information only.***
* This brewer has a multiple timer selection as well as multi function. (it can brew in different ways and sizes.)
* The batch selector determines the brew time. This is set up according to your needs and the pots you will be using. If you change pots then the machine needs to be re-calibrated to the new sized pots.
* Each timer setting needs to be individually calibrated and checked. This is usually done by the tech. Some brewers can be set without taking the cover off but most are locked out by the vendor to prevent tampering. You will need the operator/tech manual to make adjustments. (check your MFR online site)
* There is usually 2 tubes from the tank (top) to the brew head. The 2nd tube which usually branches off the brewing tube is a by-pass port which will trickle down between the wire basket and funnel. This is why it is important to keep the metal wire basket inside the larger metal brew funnel. Some may come with a separate by-pass solenoid but most have a needle valve. I usually set this needle valve by closing it all the way down (clock-wise) and opening it back up 3 full turn (counter-clockwise) I've found and average of 3-1/2 turns works for most 1 gallon brews. Opening it more will give you more watery brew and closing it down a stronger and sometimes bitter brew. It really depends on your grind size and brew amount. You will need to test it at least 3 - 5 full brews to find the sweet spot. But, stick with 3-1/2 turns if your not sure.
* If there is a 3d tube , it usually runs to the hot water faucet which is gravity fed so it does not need a solenoid valve.
* Some brands may have one more tube that has a solenoid attached which usually runs to the middle of the brewer near the top of the decanter. This is the water by-pass for Iced tea. Tea brews into the funnel the same as coffee but the funnel has a smaller drip hole. This allows the tea to steep longer in the funnel. This tea concentrate is then cooled down with the addition of cold water from this extra middle port. Most brewers with the tea option has a taller appearance to fit the tall Iced tea dispenser.
* Final; the brewing spray head should fill with hot water unless the timer or brew solenoid is not working.
* Short brews can also be caused by water probe or water control board problems. Check the water probe for crud or fixed too low in the tank. Low water in tank will lead to slower brewing and longer brew times.
* Brews are also affected by water fill valves. Not opening or intermitent operation. Note some valves are not rated for hot water feed. If your connected to a hot water line then the inlet valve needs to be rated for hot water.
* Final, check if your operators are pushing the right batch size button. Call your coffee vendor for help.
ukeboy57
Feb 10, 2018 | Brewmatic Coffee Makers & Espresso...
Why cant I get a full cup of coffee
Brewing a Partial Cup
If the brewer is not brewing the full amount selected, it may be caused by the following:
  • The exit needle is clogged by coffee grounds or cocoa mix. Please refer to the K-Cup Holder cleaning instructions.
  • The brewer needs to be descaled. Please refer to the descaling instructions.
  • The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup pack.
Jul 27, 2014 | Keurig B60 Coffee Maker
Mr. Coffee single serve brewer won't brew
First clean and please try again
Fill the reservoir with water.
Place your mug underneath the machine.
Add the K-Cup.
Choose your serving size.
Press the brew button to begin brewing.
Enjoy your delicious cup of coffee! .
Sep 25, 2013 | Mr. Coffee BVMC-KG6 Single Serve Coffee...
Water is hot but it does not brew the coffee.
Hi. How do you know that the water is hot if it wont brew coffee. They have different boilers to do each function. Hot water function. steam function and brew funtion. Sounds to me that you have a clogged brew unit. If hot water is coming from the water outlet, the you do have a fault with the brewing side of things. Dazza REPAIRER
Sep 23, 2011 | Keurig Elite B40 Coffee Maker
My krups 4055 that is less than 2 mos old suddenly wont brew. it brewed about 2 cups and stopped. water still in resevoir & turning it on & off & unplugging doesn't help.
Dec 13, 2010 | Krups KM4055
Keurig Special Edition that will not brew
all the lights are blinking its clean, descaled, filled with water and the power button and all the buttons just blink and it wont brew just had this machine less than 6 months and the machine will only quit blinking when i unplug it and yes ive tried different outlets when i plug it back in all the lights start blinking again and it wont brew i want a solution to this problem and i dont want to be sent to another site where they charge me to answer a question the $119 i payed for the thing should be enough im ready to throw it out the window im so frustrated with it
Mar 17, 2010 | Keurig Special Edition B60 Coffee Maker
Keurig b60 wont brew
The water reservoir tank probably isn't seated properly. Try wiggling the tank a bit and if that doesn't do the trick, completely remove the water reservoir and then replace it. Once it's seated properly, it should start drawing water and brew as designed. This seems to be a design flaw with this particular model, so periodic adjusting of the water reservoir may be necessary to ensure it is seated properly if your problem persists. Hope that helps! Best of luck...
Jan 25, 2010 | Keurig B60 Coffee Maker
Cuisinart grind and brew--water does not come down
If the water is not coming out of the filter basket, and is instead leaking over the edges, then replace the brew basket.
If there is no water at all, call Cuisinart - those coffee makers have a 3-year warranty.
Feb 25, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee Makers & Espresso Machines Logo
21 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
