Question about Electronics - Others
My conbivert F5 KEB on a construction crane in Venezuela Presents code error E.OS2 after a speed controler card replacement. What can i do ? The conbivert didnt last ten seconds started.
  • 3 Answers
SOURCE: Maytag Oven Error Code
main board bad or sensor .more likely board though
Posted on Jun 17, 2008
blueextc3221
  • 15935 Answers
SOURCE: E1 F5 Error Code RPD-305-PDS14 Whirlpool Double
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$RTYH
Posted on Oct 01, 2010
redds55
  • 2620 Answers
SOURCE: OBD2 code P0032 on 2004 Dodge Caravan 3.3L.
You have to reset the computer when ever you replace any sensor.Computer will not reconize new sensor unless its reset.
Posted on Apr 12, 2011
Testimonial: "Great! Thanks it is working."
rickead1
  • 1998 Answers
SOURCE: f5 error code
F5 = EOC electronic control failure replace electronic control is stated in the service manual. If you have any further questions message me them back. Thank you
Rick
Posted on Nov 29, 2011
joneapelcede
  • 41 Answers
SOURCE: Kenmore model 790.96113403 F5 error code
This same thing happened to our circa 1995 kenmore limited. It would flash the F5 code 30 seconds after I tried to use any oven function. I reset the the board by cutting the power and turning it back on. It lasted for another 6-8 mos. and then I ended up replacing the main control with a new one that I got off ebay for $45.00.
Posted on Nov 01, 2012
What Error COM KEB mean ????i have F5 version
The KEB inverter does not have a "COM" error.
Where is this error being displayed?
Check your inverter baud rate, inverter address, communications cables and device that is being used to communicate.
Feb 12, 2014 | Inverter KEB COMBIVERT F5
Tip
Hello the error code its E.OS2 said no comunications with speed card, it was...
When ever you have a questions about a KEB Combivert inverter, it is best to provide as much information as possible. At a minimum provide the following:
Part# or art-nr
Serial # or ser-nr
Fault codes
Type of machine
Machine manufacture
Problem description
KEB manufactures many different types of F5 inverters and each type has different hardware, software and functionality. With the above information it is easier to provide a better solution to the problem.
on May 20, 2017 | Inverter KEB COMBIVERT F5
Tip
E.puci error
E.puci = Power Unit Code Invalid.
When the inverter is powered up the power stage can not be identified by the control card or the power stage is the wrong type for the control card.
Typically can not be reset and unit needs to be repaired or replaced.
Contact OEM of machine or KEB for additioanl support
on Feb 21, 2014 | Inverter KEB COMBIVERT F5
Inverter keb combivert f5
What is the actual problem you are having?
Jan 31, 2014 | Inverter KEB COMBIVERT F5
Power unit not ready
hi,please you can show picture keb for power unit,or maybe you have another solutions
Oct 04, 2013 | Inverter KEB COMBIVERT F5
Keb inverter f5 error e.pu
General powericon1.png stage failure.
Most likely will need to replace the power stage or inverter.
Oct 03, 2013 | Inverter KEB COMBIVERT F5
KEB 07 F5 Error code E. Puch what will cause this error and how do i clear it
E.puch means that at power up the control card did recognized the power stage as different than last time it powered up.
This is normal when the control card is changed. If the control card has not been changed, there is a problem between the power stage and the control card.
Initialize the value at sy.03 to reset the error.
Apr 25, 2013 | Inverter KEB COMBIVERT F5
I use Keb F5 on lift, there is no error message but lift does not move
If there is no error, the inverter is doing what it is be commanded to do.
Check your control signals to verify that they are providing the proper signals to the inverter.
KEB sells inverters to many different type of lift manufactures. The lift manufactures themselves have good tech support for their equipment.
Apr 03, 2013 | Inverter KEB COMBIVERT F5
F5 keb inverter problem
i have a prblem in the F5 keb combivert it's show Error
E.OC & E.puci & E.Puch could you please advice us with the proper solution
thanks
Mar 10, 2010 | Inverter KEB COMBIVERT F5
Electronics - Others Logo
662 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
