Reset my forgoten password to my iPod touch - Audio Players & Recorders
SOURCE: Dp301p+ psadmin password was forgoten
Problems with your D-Link DP-300U LOST IP If you’re like me, you have a ton of computer **** laying around your house. Today I found an old D-Link DP-300U print server laying around and thought that I could put it to good use. The bad thing about these things is the fact that they do not have a hardware reset button on them, so if you forget the IP or the Password, you’re pretty much hosed… or so I thought. After doing some google searches for how to find a lost IP, I came back empty. The PS Admin program that D-Link publishes for use with this thing couldn’t find it on my network either. After some thinking, I came up with an idea.
If you know anything about networking and how networks work, you should have thought about this too. Get a Wireshark capture running. Unplug the power from the print server and then replug it. It’s going to send out an ARP on the network looking for it’s gateway which should be picked up by Wireshark. It should look like this:
capture.jpg In my case, it came back as 192.168.1.253. After changing the IP on my laptop to fit that subnet, I was able to log into it via it’s web interface (there was no password on it thank God!) and put it back to factory settings. Voila! What once was a brick is now a working print server!
I Copied it!
Shafiuddin Russel
infoshafi@gmail.com
+8801714073692
Posted on Jul 01, 2008
  • 4 Answers
SOURCE: ipod touch password
connect to itunes hold the power button and the home button until screen on ipod goes black keep holding the hme button until itunes says that it detected an itouch in restore mde then you have to do a system restore n itunes
Posted on Feb 01, 2009
Thermo King
  • 593 Answers
SOURCE: ipod touch wont let him put in password
I had this same problem, found this tip posted here on this site, Check it out, hope it helps you. .iTouch pass code forgotten?
Posted on Feb 09, 2010
SOURCE: forgot password
There are two options by which you can unblock the code on your ipod. Follow any of the procedures below to unlock your ipod.
Unlock with primary computer
  1. Plug the iPod into the primary computer linked to that iPod, the first computer you synchronized it with unless you have designated another computer as the primary computer.
  2. Open itunes and sync the iPod as normal.
  3. Remove the iPod, following the normal removal procedure. The iPod unlocks automatically as you remove it.
Unlock by restoring
  1. Restore the iPod to factory settings if you do not have access to your primary computer. This erases all of the data you have stored on the iPod.
  2. Plug your iPod into the new computer you want to be the primary computer. Open iTunes and click on the "Restore" button.
  3. Reload your data, if it is available and sync your iPod. Remove it following normal procedures.
Take care.
Posted on Jul 18, 2010
walesarumi
  • 6993 Answers
SOURCE: how do you unlock your ipod touch when you have
The iPod lock is a four-digit code that prevents unauthorized users from changing settings and configurations on your device. When your iPod is locked, it does not display contents onscreen and is unusable until your enter the code. If you have forgotten your code, you can unlock your iPod in one of two ways--by connecting it to the computer you used to set it up or restoring the iPod's default factory settings.
Connecting to Your Computer\Launch the iTunes program on your computer and click "Help" on the main menu. Scroll down and click "Check for updates." Close iTunes.
Connect your iPod to the computer using the supplied USB cable. Launch iTunes, which will display your iPod on the left panel.
Right-click your iPod in the iTunes program and click "Eject." Close iTunes and detach your player from the computer to unlock it.
Restoring your iPodConnect your player to the computer and launch iTunes. Click your iPod on the left panel and click the "Summary" tab. Click "Restore."
Click "Backup" to save your current settings and select the restore option you want to use. Select Option 3 or 4 if you want to install the newest iPod software.
Follow the prompts to finish the restoration and rename your iPod to restore the default factory settings.
Good luck.
Posted on Feb 17, 2011
Login my itunes account
Do you mean the password for your iPod or your apple account? If it's your apple account you can go through apple's website and retrieve your username and/or reset your password
My Apple ID
If it's your iPod password you forgot, then unfortunately you will need to reset your device and delete everything on it to get it working again. Here's a link to do just that:
How to Reset Forgotten Password on iPod touch
Aug 16, 2014 | Apple iPod touch
Tip
How to Reset an iPod Touch if I Forgot My Password
The iPod Touch has a feature that allows you to create a 4-digit password.You cannot enter the home screen of the device if you don't provide the correct password. You may, however, have forgotten this password, Fortunately, your iPod Touch is not rendered unusable. Your only course of action if you've forgotten your password is to reset the iPod Touch to factory settings. This can be done using iTunes. You'll need to place the iPod Touch in receover mode before it can be recognized in iTunes.<br /> <br /> Instructions:<br /> <br /> 1. Turn of the iPod Touch.<br /> 2. Press and Hold the Home button on the iPod Touch. This is located at the bottom of the device. While still holding down the button, plug your iPod into your computer or laptop using the USB cable.<br /> 3. Hold the Home Button until you see the "Connect to iTunes" screen. Release the Home button when this screen appears. Click "OK" when you see the "Recovery Mode" alert.<br /> 4. Click the iPod in the left column under "Devices".<br /> 5. Click the "Summary" tab located at the top of the main viewing pane in iTunes.<br /> 6. Click the "Restore" option. Click "Restore" from the dialog box that appears.<br /> 7. Click "OK" in the dialog box that appears after the iPod Touch has been restored. You have now successfully reset your iPod Touch and it is now usable again. Enjoy playing your iPod Touch!<br /> <br />
on Feb 27, 2011 | Audio Players & Recorders
How to unlock ipod touch 4th generation if I do not know password
Sorry but if you've forgotten your password, you will need to reset it and lose all the contents on the device. Here is a link with instructions on how to reset your iPod:
Aug 14, 2014 | Apple iPod touch
Ipod is disabled
Please contact me directly: service@gps.pol.plI will help you.
Dec 25, 2011 | Apple iPod touch
Forgoten password for ipod touch
contact me at: service@gps.pol.pl
Dec 18, 2011 | Apple iPod touch
Ipod touch is locked forgot password cant unlock
plug it into your computer and through itunes on your original computer you will be able to reset it. If it is not the original computer that you are using you will be able to reset it but will probably lose the information on it.
May 05, 2010 | Apple iPod touch
FORGOT iPOD PASSWORD
connect it to itunes and do a reset and then restore your music etc and it should be fine - there is no way that I am aware of to recover it aside from resetting / restoring your ipod
Jun 02, 2009 | Apple iPod touch
Password
what you want to do is, make sure you have a copy of all the music on your computer, then plug the ipod into the computer and when it detects it as a drive, you right click on the ipod, through start - my computer - ipod (g:) or w/e drive it is, and click "Format" ipod, have it do a quick format, restoring the ipod to factory mode, once you do that, unplug the ipod then it will ask you to set which language you want, then you set it, then plug it back onto the computer reupload all your music, then you got a unlock ipod.... :)
enjoy
Apr 16, 2009 | Apple iPod touch
Forgotten password
First reset the device
To reset iPod touch, press and hold the Sleep/Wake button and the Home button at the same time until you see the Apple logo.''
Then restore it.
Restore
Try restoring iPod touch using iTunes.
Connect iPod touch. When it appears in the Source list, click on Restore in the Summary tab.
Apr 01, 2008 | Apple iPod touch
 Grubhead
Grubhead
