Question about Epson Stylus C88 InkJet Photo Printer
C88+ tries to pick up paper but won't. No jams,
C88+ tries to pick up paper but won't. No jams, etc.
  • Steven Ford May 11, 2010
    Open the cover and clean the pickup rollers with a non lint cloth LIGHTLY dampened with alcohol. Let dry and try again. Reply if it does not help.
  • Epson Master
  • 511 Answers
Probelm with pick up rubber. Replace paper feeder or just replace the rubber. Or add thickness of rubber by adding flexible double tape (about 1 mm). Add just for upper rubber.
Posted on Jul 26, 2009
Canon Mp550 paper jam
If the paper is not being picked up from the tray assembly try applying mild soap to a soft cloth and clean the paper pick up rollers. Do not use rubbing alcohol because it will dry the rubber out so later they won't pick up at all
Sep 18, 2012 | Canon Office Equipment & Supplies
There's no foreign objects in my printer and I also put the paper in properly... I have ink, etc... My paper gets jammed immediately on the right side when trying to print. Help!
85% of paper jams are caused by worn rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
Jul 23, 2011 | Office Equipment & Supplies
Paper feed issues when there is no Paper jam. All the rollers move when the printer tries to feed paper. It'll feed about and inch and a half of paper and then stop showing a Paper Jam.
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 19, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Epson C88 shows red alternately blinking lights
the problems are :-
  • cartridges are not recognised or installed
  • there is a paper jam.
Feb 05, 2010 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88 plus
Make sure that the head can move on the carriage bar as this indicates a head assembly lock or jam. Make sure all the paper paths are clear and there is no tiny piece of paper stuck. Power it back on. If this does not resolve then you will need a visit to the repair shop or buy a new printer which is probably cheaper!
Sep 11, 2009 | Epson Stylus C88 InkJet Photo Printer
I can't find a paper jam
There's a possibility the paper sensor is stuck up,check if there's piece of paper between the sensor.or the sensor is out of position.
Jun 30, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson stlus C88+ printer: paper pulled to one side during printin
Hi
Chances are the sensor for grabbing the paper on the left hand side is defective. Try to check if there are obstructions as well
Hope this helps
May 13, 2009 | Epson Stylus C88 InkJet Photo Printer
Says paper jam no paper jam will not print. Have tried restarting etc..
it is possible that a sensor is stuck or that the rollers cannot pick up paper and would need to be replaced
Apr 29, 2009 | Office Equipment & Supplies
Epson Stylus C88 says paper jam but there is no paper in it.
e-mail the company and request help or call, they usually post a phone number you can call for assistance.
Jan 05, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus C88 InkJet Photo Printer Logo
132 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
