Question about Kitchen Appliances - Others
Why does hi-rice sd808 display low p? - Kitchen Appliances - Others
When I push the white rice button to cook no time is displayed. The cooking light is lit but there are only flashing lights going around the perimeter of the display.
It will judge when the rice is cooked successfully, don't worry. Leave the lid closed for at least 15 minutes after the light goes out to finish steaming the rice to make it fluffy.
Jan 05, 2015 | Aroma Kitchen Appliances - Others
Hi I by mistake dropped my nokia c3 in water. There wasnt much water but it did get wet. All functions are fine except the screen display. It shows nothing other than white light. Please help
You did get moisture in there...
Place the phone in a bag of rice.. for a couple of days... it may pull enough of the moisture out so that it will work again...but you may have already ruined it by turning it on...
Try the rice trick... it may help you out...
heatman101
Jun 25, 2011 | Nokia C3 Cell Phone
Hello, I have a Sanyo ECJ 18F Micom Rice Cooker, and today when it was cooking vegetablaes rice the display desappear, only appears half a seven, I unplugg and now on the display doesn´t appear...
Hello I had a similar problem with that same cooker, there is a power IC with readings AC05E that controls the screen and the power of the rice cooker. Get a replacement of that ic and you are good to go.
Oct 15, 2010 | Sanyo Kitchen Appliances - Others
My LG Chocolate touch got a little wet and now it just will not work. i have it in a bowl of rice with the hope that it might work. I am worried that it is just completely broken and i wont be able to take...
If you have dropped the phone into water you can keep it on bowl of rice because it will make it dry else there is no need.First
Is your phone display only broken.can you switch on/off your phone.Then you have to replace the display alone.If phone doesn't work you have to open the phone and rehot it accordingly.if any of the Jumper Ic is damaged you have to replace it.Please do continuity testing to find out which Ic is damaged or loosened.If you don't have hands on in it take it to the nearest service centre and repair it.It will cost very low don't worry if the IC is loosened..
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Aug 15, 2010 | Cell Phones
LCD display has water crystals inside. I dropped in water and immediately took off. But still display is blurred.
take off the battery cover and remove battery. Fill a bowl with 1" on uncooked rice, Place phone on top and cover with another 1" of rice. The rice will drawn the moisture out of the phone.
Oct 14, 2009 | LG Vu CU920 Cellular Phone
Need directions for Comet stove top rice cooker
Fill the bottom to the line with water. Put two cups of rice in the top and two cups of water. Put on stove top on high until lower water is boiling, turn to medium heat. For white rice check after about 20 minutes, if water is assorbed and rice is tender, fluff with a fork...eat. If it needs a few more minutes of cooking, no problem.
Brown rice will take about 45 minutes.
I have used my stove top cooker for at least 35 years...ordered it with box top and some money from Comet Rice.
Pat
Mar 09, 2009 | Kitchen Appliances - Others
Sony Ericsson W8580i half screen is black HELP
First you have to put out the battery, second you put then both separetely into a box with rice; you must be sure that both be covered into the rice, leave them to 48 to 72 hrs. This should dry completely the cellphone, i hope this may help you
Jul 22, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Hs2000
hi!
you put the rice inside and just add water the same place where the rice is.
just remember that the ratio for rice is 1:1.
1 cup water = 1 cup rice. make sure you use the same cup.
for brown rice 1:2. 1 rice: 2 water
hope this helps
cheers!
Dec 17, 2007 | Black & Decker HS2000 Flavor Scenter 7-Cup...
Kitchen Appliances - Others Logo
18 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
