Question about The Health & Beauty
Power light will not come on the joy stick batteries fully charged all plugs connected Maybe a fuse?
johnr1959
  • 56 Answers
SOURCE: Burgman AN 250 sccoter - battery fully charged, but no power
Have you checked the fuse box yet?
Posted on Jan 29, 2009
SOURCE: Jet 7 chair stored in warehouse for two years. attery kept charg
Looking for free information.
Charles
Posted on Feb 09, 2009
centurion_BB
  • 83 Answers
SOURCE: I have a toyota corolla and battery is fully charged no power
Sounds like a bad connection with one of the battery cables check the connection to both cables at both ends and I personally would make sure that i cleaned the main engine ground (where the negative wire from battery connects to engine). Good luck!
Posted on Aug 13, 2009
Testimonial: "okay "
  • 347 Answers
SOURCE: The battery charger does not work. The red light
SEEK AN ELECTRICIAN WITH HIS METER WHEN SOMETHING GOES WRONG WE TEND TO THINK OF THE WORSE THINGS RATHER THAN THE BASICS,IM DISABLED MYSELF,THE BATTERIES ARE TO BE TREATED WITH RESPECT,I DONT KNOW WHAT CHARGER YOU ARE USING BUT PLEASE ONLY USE WHAT IS ADVISED BY MANUFACTURER,NOT ONLY THAT IF YOU DONT YOUR WARRANTY WILL NOT BE VALID.HAVE A NICE DAY COLIN.
Posted on May 20, 2010
HoverTech
  • 232 Answers
SOURCE: the battery wont stay charged
If the charger is automatically giving you a green light when you plug in the charger, the batteries are most likely damaged and will no longer take a charge. This can happen when the power chair is stored and the batteries are not charged for a while. The green light on the charger indicates the battery is full, but instead of being full of power, its full of crud. Try to replace the batteries and see if that will solve the problem.
Posted on Oct 04, 2010
I have a jazzy Select GT power scooter, on the charger I have a red light and green, I put it on charge and have both green lights on now but the controls near the joy stick and on and off light nothi
need more info on equipment to answer ,scooters dont have joystics powerchairs use joysticks if you have a powerchair that has not been charged for over two weeks the batteries have probably died
in this state the charger will not go into charge mode only the power light and poss the fully charge lights will light
as a quick test a 24 volt bulb from a scooter or lorry with 2 wires attached pushed into the two outer holes in the joystick charge socket should light up if it wont batteries are totally dead
Nov 21, 2014 | Health & Beauty
When plugged into charger both lights show green but chair not fully charged
First measure the voltage of the batteries at the charging socket of the joystick.
Sep 28, 2014 | Pride Jazzy Select Elite
I have a metro 500 and it is about 14Yrs old i never had a problem. After i put the new batterys some thing went wrong with the cnnector cable . My batterys are fully charge but on the joy stick within 15...
loose connection on battery? if new batts then you must charge them for a full 24 - 48 hours before using. but posts must be tight. they never fully charged if connections were loose to start check all connections on chair
Oct 27, 2012 | Everest & Jennings Health & Beauty
I have a blue jet 3 ultra n i just put 2 new batterys on it and all it will do is flash a red light in the top left corner of the battery light on the joy stick and the horn works but will not move what...
Check your battery wiring on the Jet the wires from the circuit breaker need to connect the positive of the front battery to the negative of the rear battery and the other wires connected to the positive of the rear battery and negative of the front battery putting the batteries in series to generate 24+ volts. If you have a voltmeter before you check the wiring set it to 200 volts dc and plug the leads into the 2 outter holes of the charger port located under the front of the joystick. If your batteries are wired correctly you should be reading 27+ volts without the charger plugged in and your batteries fully charged. If you are only reading 12 volts then the wiring is wrong and needs to be fixed. Leaving the voltmeter in the charger port plug in your charger and you should be reading 27 -30+ volts at the charger port anything less than 24 volts indicates your charger is not charging Hope this helps
May 22, 2011 | Jet 3 Ultra Power Chair
I had not used the chair in 2 months, when i charged the battery in my electric wheelchair, the lights near the top of the joy stick shows its fully charge, but when i unplug the cord, it go's...
Yep It sure does Why didn't you charge the chair for 2 months? Charge at least once a week if you don't use it daily. Always break in the new batteries by using the chair daily for 10-15 days charging everynite then charge once a week if it sits for that long without use. Always put up fully charged. Do this and your batteries should last 3 -4 years Charge overnite if you use daily and never charge more than 24 hours Good Luck
Nov 15, 2010 | Electric Jazzy 1115 Power Wheelchair
May 19, 2010 | Pride Jazzy Select 6 Indoor Power...
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Battery is fully charged but it still wont power up no lights when plugged in to charge
Hook up only the ac adapter to the DS to see if it turns on. If it does then we know the ac adapter works. We know the battery got fully charged but the system isn't turning on with the battery that is fully charged up.
I would say your battery is defective but you won't really know until you fully charge up a known good working battery and test it out.
Jun 29, 2009 | Nintendo DS Lite Console
Panasonic vx37
My old Panasonic Palmcorder IQ shows a red light in both switch positions-camera and VCR. Maybe yours has red for camera and green for VCR so you could tell them apart. I found that the Panasonic battery that came with the camera was the cheapest kind with the least charging time. I bought other batteries, they were good for a while, but now, many years later, they won' t hold a charge. Since I am only recording inside of my house, I have resorted to using the AC wall socket for power. I have to take the battery out of the camera. I found a power plug-in hole (like ones on cell phones) in the battery compartment. I also found one of these holes on my battery charger. My camera came with a double ended power plug. I plug one end into my camera and the other end into the battery charger. I plug the charger power cord into the wall outlet, and I have power to my older camera. Maybe you can find this double ended power cord at a store or on line.
Did you know that there are 2 kinds of batteries? Some have memories and others do not rely on a memory. The ones with memories have to be fully discharged or they will only charge a little, and keep charging less and less each time they are charged. The ones without the memory can be charged fully without being discharged fully. Check into battery information on line to get more information. Maybe you can get the non-memory kind.
May 18, 2009 | Panasonic NV-VX37 Mini DV Digital...
Unit wont power up
Have you tried the wall charger to charge the device...maybe the battery is just dead.
Jul 11, 2008 | Garmin nuvi 350 GPS Receiver
Health & Beauty Logo
18 people viewed this question
Top The Health & Beauty Experts
Terry Kitt
Terry Kitt
Level 1 Expert
Elliot Kelly
Elliot Kelly
Level 1 Expert
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
