Jul 25, 2017 | Facebook Computers & Internet
May 20, 2017 | Cars & Trucks
Feb 23, 2017 | Computers & Internet
Jun 23, 2016 | Computers & Internet
Aug 02, 2012 | 2001 Pontiac Aztek
Hi
It is a rich condition for both a and b banks, you need to look at things that feed both. That code is most often MAFS, but you need monitor fuel pressure. Even more important is your long term fuel trim may be still under old operating conditions. Disconnect the negative battery cable and momentarily touch it to the positive cable to provide a path to ground for the capacitors and erases volatile memory in the ecu's. Then you won't be dealing with past parameters the ecu.s use for performance changes...A fuel pressure reg. is a likely culprit too
Undo your negative battery terminal for 30 minutes then re connect it. This should clear any fault codes. the exception is if there is still a problem then it won't work.
Also check this link for more info:-
http://www.bba-reman.com/content.aspx?content=NEXT_DTC_P0172
Please get back to us if you have further query or else please accept the solution.
Sep 07, 2011 | 2000 Jaguar XK
Mar 13, 2011 | 2002 Honda CBR 954 RR Fireblade
Jan 20, 2010 | 2000 Dodge Intrepid
Sep 23, 2009 | Facebook Computers & Internet
May 27, 2008 | Nokia 7373 Cellular Phone
12 people viewed this question
