Question about BOX Computers & Internet
Oblong box in middle of screen keeps flikering like a bubble
When i turn my computer the screen stays black and flikers for a bit
The problem is in the inverter board located below the LCD screen, or the built in backlight behind the display. I would hook a monitor to the video output to rule out the video graphics chip.
Jun 24, 2012 | Lenovo Computers & Internet
My ipod screen guard has air bubbles in it how to get it flat on the scree of the ipod
Sir use a hard cardboard and press it hard with that and then push those bubbles to the nearer side of that paper it will remove that bubbles otherwise replace it with a new one .
Thank you.
Mar 29, 2012 | Apple iPod touch
1995 Golf: dash lights flikering and wont get power to the st...
Check your battery cables and connections. Especially the negative cable. Clean all your battery terminals and connections.
May 17, 2010 | 1995 Volkswagen Golf
I have a new flat screen monitor, thats oblong in shape and my eyes are going nuts because its all stretched out and i want it square looking.how can i change it?
This is common with wide screens and the screen resolution needs to be adjusted to keep the correct aspect ratio.
My method, open MS Word - new document then Click on Insert - Picture - Autoshape and select a circle and place this shape in the document. Then if you wish to make the shape larger, then hold down the Shift key and drag the corner box to make the shape larger.
NOTE by holding down the Shift key, the circle will keep its shape and not distort.
Now Click on Control panel - Display - Settings and adjust the screen resolution and then view the Word doc with the circle, if it is not a perfect circle then, adjust the screen resolution again until you see a perfect circle. I suggest you start at the highest resolution that suits you and work down.
Mar 21, 2010 | Compaq Computers & Internet
Can't find fuse box that is supposed to be located in the trunk.
The fuse box is under the steering wheel. There will be 2 or 3 screws to remove a large panel, (about 2 feet wide). The other box, (relay center), is next to the battery. First you have to release the little box on top of it. Do this by pushing a tab in the middle of the little box. Then pull the little box up. Now you can remove the oblong-shaped box to reveal the fuses/relays. Release tab is in the front.
Dec 14, 2009 | 2000 Cadillac Catera
Black square in lower part of tv screen
Turn off the text box function of the closed captioning.
Jul 14, 2008 | Curtis-Mathis CM27101S TV
Display problem
the adjustment box for colour, brightness and contrast stays fixed on the screen. i tried pressing the exit button.... after a few times it disappears only to reappear within a few minutes. also the auto adjustment option, for which we are supposed to manually press the i button, keeps auto adjusting the screen whenever it feels like it. the box appears right in middle of the screen and is a real nuisance as it blocks out the main portion.
Jun 28, 2008 | BenQ FP547 - 15" LCD Monitor
Computers & Internet Logo
15 people viewed this question
Top BOX Computers & Internet Experts
ray gallant
Paul Chapman
Paul Chapman
cnedanny
Level 1 Expert
Are you a BOX Computer and Internet Expert? Answer questions, earn points and help others
