Question about The Computers & Internet
Ematic Digital Converter Box AT103B C005 How to reset programming search when the old password is forgot? Because restore to factory state can not work unless the old password is remembered. How?
4 Suggested Answers
gopakumarg43
  • 74198 Answers
SOURCE: I have a G.E. universal remote for my Ematic AT103B (4 program) converter box. Do you have a code for this????
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window " to get gathered related posts.
Posted on Apr 30, 2016
emissionwiz
  • 76070 Answers
SOURCE: I have ematic digital converter box hooked up to my tv Can i plug my lg phone into the usb port in front and play you tube videos if so how do i do this through my menu guide model is ematic at103b
I do not think that will work, but try it.
Posted on Nov 18, 2016
  • 5124 Answers
SOURCE: Is the Ematic AT103B Converter Box compatible with Suddenlink cable/digital service?
No, the Ematic AT103B is an over-the-air digital ATSC tuner and will also can convert the digital signal to analog NTSC for older TV tuners. It will not work with any cable service and is for "cord-cutters". The AT103B requires an antenna to receive your local OTA channels. Depending on where you live, you may get some channels with an indoor antenna. You will get better reception with an outdoor antenna. See http://www.tvfool.com or http://www.antennaweb.org for details on the channels you can receive with an antenna pointed in a particular direction.
The Ematic set top box does provide an HD signal output and a DVR (time-shift function) so it is more advanced than the first generation OTA converter boxes. The original (available with the government coupon) converter boxes only gave an SD output.
I hope this helps.
(antennaweb.org gives a very conservative list of available channels but assumes an external antenna. tvfool.com lists the channels that are likely to be received with a variety of antenna strengths. An antenna signal amplifier can improve the reception. (Digital stations will not be seen if the tuner can't lock onto the signal.) However, when the amplifier fails, you may find some channels will not be received at all.)
Posted on Dec 09, 2016
Testimonial: "Thanks for your info. I ordered this converter and never saw the antenna requirements until I received it and was reading the manual! Thanks for help."
Ematic AT103B manual
The manual is available from the manufacturer's support site: https://ematic.zendesk.com/hc/en-us/articles/220756147-AT103B . The direct link to the manual is currently https://ematic.zendesk.com/hc/en-us/article_attachments/208176947/AT103B_manual.pdf .
I hope this helps.
Feb 22, 2017 | Ematic Audio Players & Recorders
I hope this helps.
Dec 08, 2016 | Televison & Video
Connecting to old Sanyo single RF CONNECTION plug.Not able to view menu operation program from AT103B ematic.Do I need a adapter for this old Tv for connections.Now I'm using a cable and antenna only.
If it is not a flat screen TV yes all TV signals are now digital so even if you are doing the cable and antenna thing you need a digital converter box to convert the signal from digital to analog. Not sure if they still sell them at Wal-Mart, but I am sure you can find one on-line.
Nov 08, 2016 | Sanyo Televison & Video
Reset ewt716 forgotten password
Your Ematic tablet comes with a variety of Google services and business productivity apps. When a service stops working, the tablet might lock up or become unresponsive. If the Ematic tablet won't respond, you might need to reset it. You can perform a soft reset to reboot a frozen device or a factory restore to return the tablet to its original factory state.
Soft Reset Step 1 Locate the reset button next to the headphone jack on the side of the tablet. Step 2
Insert a paperclip or another thin object into the hole. Step 3
Press the reset button with the paperclip to reset the tablet.
Factory Restore Step 1 Tap "Settings" on the tablet's home screen. Step 2
Tap "Personal" and "Backup & Reset." Step 3
Touch "Factory Data Reset" to restore the tablet to its default state.
Oct 02, 2016 | Computers & Internet
My box keeps saying boot. When I channel search, no channels appear. How do get channels to watch?
Plug the antenna into the ANT IN input of the STB. Forget about the RF IN output of the STB. Plug the 3-way output of the STB into the corresponding 3-way input on the rear panel of your LG TV.
Sep 18, 2016 | LG Televison & Video
Cannot locate local channels from ematic model#AT103B
you hook to this a flat panel tv?
you don't need converter box with a flat panel
Mar 16, 2016 | Televison & Video
Program my g.e remote control to a A.T.103 gematic digtal box
Tv Converter Box Deals
www.bestdeals.today/tv-converter-box
Digital Converter, Ematic Digital TV Converter Box with Recording, Playback, ...Digital to Analog TV Converter DTV Tuner Box w Remote, Program Guide, PLUS MORE! ... GE Television Antennas Omni TV Indoor Antenna 24731 ... HDMI/HDTV/DTV/RF/RCA/USB Digital Converter Box TV Tuner With Remote Control PVR.
Ematic DVR Recorder Television HDMI Media Player ...
www.altatac.com/p-15751-ematic-dvr-recorder-television-hdmi-media-p...
Ematic DVR Recorder Television HDMI Media Player Converter Box w/ USB ... TheEmatic AT103B Digital Converter box allows your TV without a digital ... Features an electronic program guide, parental controls, and a USB ... Full function remote controlincluded. .... My Account My Account Order Status Track Your Order.
At103b Ematic Converter Digital Atsc
antennadisht.com/at103b
11 ozmiscellaneouspackage contents converter box remote control 1 x user ... Review (mpn:at103b for sale) Digital Converter Atsc Ematic At103b Box . ... You can find your tracking number by ing on my and scrolling down to your purchase with us. ... Features an electronic program guide, parental controls, and a usb ...
Jan 24, 2016 | Televison & Video
How do I get a passcode for a ematic digital converter box AT103B
Just use all zeros for the pass code which is the factory default.
Feb 21, 2015 | Ematic Audio Players & Recorders
Ematic 7" QUAD CORE TABLET EGQ307 FORGOT PASSWORD HOW TO RESET IT CANT GET ON ANYTHING WITHOUT IT
I have also take help from this helpline number 1-888-551-2881..
before sometime i have also same problem like you, i forgot my password of my Gmail account and that account contain important data,,I just call this number 1-888-551-2881..& get best solutions
related website: Gmail Password Recovery
Jan 08, 2014 | Ematic Eb104 eBook Reader
Computers & Internet Logo
253 people viewed this question
Top The Computers & Internet Experts
d3yavu3
kimblebear
Level 1 Expert
baklogic
Level 1 Expert
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
