Question about Maytag Dryers
Paddle inside drum is falling off. Maytag MGD2600BWW hard to fix?
SOURCE: Dryer Paddle Loose
Take the four screws, out of the door and remove it. The front of the dryer will fold down and lift off, you will be able to see in side the dryer. If you want to lift the top remove the screws that are now exposed. Along with the brackets the top will now lift up.
This should allow you to access the tumbler.
Posted on Dec 19, 2008
  • 433 Answers
SOURCE: breadmaker paddle rotor falls out, letting liquid
Looks like you need a new bread pan. Try looking on Ebay. They are expensive. I just bought a new one at walmart instead.
Hank
Posted on Aug 07, 2009
barkencoa
  • 3463 Answers
SOURCE: drum paddle keeps coming off had machine blocage
Are you sure you have got the correct paddle, as there is more than one version, and also there is a right and wrong way to fit them.
Make sure you push it hard into the locating slots, you should feel it click into place, to be sure it is located properly, lightly pull it, and it should remain in position.
Hope this helps.
Posted on Dec 30, 2009
tzweeb
  • 318 Answers
SOURCE: One of the paddles inside the drum has come loose
you have to start by taking off the door at the hinges, then the front panel will twist off at the smaller raised portion, about 2 inches wide. once you have the front off, you will see the screws that hold the top to the front.
the drum baffles are held in with screws and if you can just use a bigger screw or just tighten the ones that are there.
Posted on Mar 14, 2010
SOURCE: Drum paddles keep falling out (Hotpoint BWD129 washer/dryer)
I had this problem, and I was advised by the guy who has apparently 'replaced hundreds of these bloody things on this housing estate' to never buy this machine because 'its cheap and ****'
However, if you bend the long central tab ,the one that looks like it does bugger all, upwards into the drum (carefully though, only bend it a little) this will increase the tab tension, and your lifters should last for over six months instead of the previous couple of washes mine was doing.
As for the comment on washing trainers, I put a single towel in my machine and the lifters broke...
Posted on Apr 01, 2010
Testimonial: "Yes, this was the correct solution for this particular model of W/M. Many thanks!"
Maytag dryer blade inside of the drum
Is blade loose or broken off? Either way, you must remove front panel (door panel) to expose the front drum end retainer brackets, which you must unscrew and remove to get at screws to tighten or replace missing paddle blade. You can get replacement part at www.repairclinic.com their very reasonable
Feb 13, 2011 | Maytag PYE2300AY Electric Dryer
Change has gotten in the drum and is making noise as it spins. How do I get to it?
Take the top off the dryer and remove (or loosen) the screws that hold the paddles in the drum
The change will slide out of the paddles inside the drum as you revolve the tub.
Questions go here
Leo Ponder
imufo2@sbcglobal.net
Jul 28, 2010 | Maytag 7.0 Cu. Ft. Electric Dryer
I have a Maytag MD55 dryter and one of the paddles
You remove the door screws with the triangular plastic plates and screws for the door on the opposite side. pull front forward and down. Remove the two bolts at top corners to raise top (unplug machine of course). screws are on outside of drum. When reassembling, make sure that the right screws go with the right area (The wider screws go in the triangular plates and the thinner go in the door) Make sure the door hinges are put in their grooves before reinserting the front.
May 14, 2010 | Dryers
I HAVE A MAYTAG NEPTUNE GAS DRYER MODEL 3MDE3000AYE. ONE OF THE THREE PADDLES INSIDE THE DRUM CAME OFF. I AM TRYING TO REATTACH IT TO THE DRUM, BUT THE SCREWS HOLDING THE PADDLE ARE INSIDE THE DRUM.
unplug the dryer,open the door,remove the two screws holding the door on and remove the other two screws opposite them,take off the door and pull the front panel off,spin the drum until the baffle you are trying to repair is in the bottom right hand corner and you can get at it like that
Mar 13, 2010 | Dryers
Jul 17, 2009 | Washing Machines
One of the paddles inside the dryer has come loose, how can I fix this?
remove door screws and screws on opposite side. pull front forward and down. remove two brackets at top corners to raise top (unplug machine of course). screws are on outside of drum.
Jun 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Drum paddles falling off
until you post the statement again and include such vital details like make model year type of equipment etc and photo then nobody has any idea of what you are on about
May 05, 2017 | Zanussi ZWF1420W Front Load Washer
Dryer Paddle Loose
Dec 10, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Paddle on inside of drum came off.
lift top turn drum to paddle position reinstall screws
Jul 22, 2008 | Maytag Dryers
Baffles
These are the paddle bits that are inside the drum? If so I had the same problem and I found that the lugs that hold them to the drum were broken.
I fixed mine by using plastic cable ties (=tie-wraps) passed through the slots in the paddles and through holes in the inner drum. It's fiddly getting the ends back out of the space between the outer and inner drums - I used another tie-wrap bent into a loop and stuffed into a suitable hole to "catch" the end of the tie I was fitting. It's not a pretty solution but it works and it is almost free!
If this "fixes ya", I'd appreciate a rating for my reply, If not, please delay the rating and add a comment with any extra info you have and I will try to think of something else.
Thanks, D
Jul 13, 2008 | EuroTech EWF172 Front Load Washer
Dryers Logo
16 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
