Dishwashers Logo
A
Anonymous Posted on May 20, 2017
Asko d5223xxl the pump wont shut off. I replaced the micro switch and the control panel (repair tech recommended) with out much problem. switched it back on and the pump is still running
I haave tried all of the rests the MFG recommends, I have vacuumed and blown out the lines from both directions, nothing is stuck and there is no water left in the sump or the lines that I can see. What eles can I do?
5 Related Answers
Chris
  • 26 Answers
  • Posted on Mar 05, 2009
SOURCE: New water ace sump pump will run but willnot shut off
The higher you pump the water, the stronger your pump needs to be, or the skinnier your hose needs to be. A lower discharge point and / or a smaller diameter hose might help immensely.
Grubhead
Grubhead
  • 5755 Answers
  • Posted on Mar 25, 2009
SOURCE: Bryston 4b amp, left channel blows the back panel
I would check out whatever drives the left channel first. If it is a transistor, you can put a ohm meter on the terminals and see if it shows a short (amp turned off). If there are two transistors for the left channel, and you find a short on one only, replace the other to be on the safe side.
Anonymous
  • 7 Answers
  • Posted on Jul 29, 2009
SOURCE: 2H displayed and pump runs nothing else happens
I, along with many others online, are experiencing the same problem. The bottom line is the control panel needs to be replaced. Beware, though, that the replacement panel may also be bad as I've seen many reports that they are poorly designed and Bosch isn't doing anything about it.
There are 2 things I'd like to clarify...
1) The display "2H" is an error code which, according to Bosch, indicates service is needed on the unit. The code is different from "2h" (note the lower-case letter h), which is what would display when the delay start button is pushed.
2) The number 1 showing at the "end" of the cycle does NOT mean 1 minute left. It is a 2nd error code indicating the unit has "timed out."
I'm waiting to have my control panel replaced a second time. The first repairman from Sears replaced the control panel with a refurbished one, but the unit still showed 2H. He was about to leave when I told him the problem wasn't fixed. He tried to tell me that the 2H meant the cycle would be longer than 2 hours because my water temperature was too low (it is at 120 degrees, the proper temp per Bosch). He said I needed to increase my water temp or else live with the fact that the dishwasher would take a long time to run through the cycle. I asked him to call Bosch and he said they wouldn't talk to him (he really had an attitude). I asked for a receipt (on which he commented the "dw works fine") and, after he left, I called Sears back to get a "senior" technician out to fix it. They ordered another (new) control panel for me and they'll be out this Friday to (try) to repare the unit. Hoping this time it will work.
Anonymous
  • 8 Answers
  • Posted on Feb 28, 2010
SOURCE: 97 Lumina...Switch stuck on defrost vent and
I had same problem . There is a vacuum resovoir tank located behind the left front splash shield . The vacuum line behind the battery goes to it . I removed two 5/32 screws just in front of the tire that hold the splash shield to the fender , carefully flex the shield away from the fender and take a look . I found the vacuum line had come loose , plugged it back on and everything works . Hope this helps
Anonymous
  • 185 Answers
  • Posted on Jan 10, 2011
SOURCE: My sump pump wont kick
Hello, the pump motor is controlled by the float switch. If your motor is running constantly even when you move the float switch around, then I would say that either the switch is shorted internally, or the wires going to the switch are shorted, thusly causing the motor to run. Is the float on a separate adapter to the pump, or is it wired into the pump?
joe
1helpful
Pool filter pump won't shut off.
I'm assuming it continues to run when you switch the system to "service" mode. You probably have a relay stuck shut. Unless you are very comfortable with working with high voltage it's best to get a tech out to verify the problem and switch out the relay. If you are okay with it the replacement isn't very difficult. You'll have 4 or 6 wires to move from the old relay to the new one, and switch out the small black and red paired wires that go from the relay to the control board. Make certain that your breaker is off while changing it out.
1helpful
5answers
Sumsung MU3250W shut down
The problem is your magnetron tube is leaking RF. The mag tube comes on 2-3 seconds after you hit start, and the RF interfears with the board and shuts it down. Drop the front of the control panel down and watch, it wont happen.. Get a new mag tube put in and you'll be good to go.
4helpful
Our Asko dishwasher will not shut off when we open it. I have tried to hold the start button down to restart but nothing happens...what should I do?
Welcome to fixya. Based on your description and trusting it is indeed an Asko 1796, I'd suspect you have a door switch "accuator" sticking ( control pin as identified by Asko. pin part #80 575 42, switch part # 80 554 73 ). This has been a random occurrence with Asko dishwasher's since they went to this design around 1994 or so. If the dishwasher doesn't stop when you open the door as you stated, here's a possible remedy you can try on your own. Make sure the unit is off first. **Turn the breaker off at your home service panel before attempting any service suggested here on 'fixya"...safety first" This procedure I'm going to suggest can be done easiest and more accurately by removing the control panel for better access as well as to visually inspect other component. It can also be done without removing the panels by identifying the small round "pin" in the the door latch channel ( where the latch goes into the door when closed )...i.e. 94bd9a4.jpg ...with the aid of a small screwdriver, tooth-pick, ear swab etc. add some vasiline or grease to the top of the pin working it in via pushing the pin up & down...I recommend removing the panels though. To do this... Open the door and along the top you'll see "T20" torx head screws. Remove just the screws for the console/control panel, you must also be careful as the edges of these panels are sharp ( auto-mechanics protective gloves are good for this ). Once off you can see the micro-switch and the small "pin" I was referring to earlier much easier. cd7bb1b.jpg Tilt the entire panel towards you slightly, just enough to work with ( careful not to undo any wires, or take pictures as you go ). Apply some grease or silicone lube to the shaft of the pin/accuator and work it in really thoroughly. I find it easier to remove the plastic cover & micro-switch out of it`s bractket to allow a little room to work i.e. e09a335.jpg ...careful not to let the plastic pin fall out. Where I pointed my finger in the image below is where to apply the lubricant. 03cb0a9.jpg Re-attach the control panel and you can test it before itstalling all the screws. Let me know if you require further assistance. Thanks for coming to fixya, please take a moment to rate the help you received. Good luck. Regards, Macmarkus :)
1helpful
Dishwasher is not cutting off when door is opened during a cycle also is starting without door being shut. Catch on door seems sloppy and worn. Machine is about 8-9 years old.
Hello and welcome to fixya. Based on your description and trusting it is indeed an Asko 1776 I'd suspect you have a door switch "accuator" sticking ( control pin as identified by Asko. pin part #80 575 42, switch part # 80 554 73 ). This has been a random occurance with Asko dishwasher's since they went to this design around 1994 or so. If the dishwasher doesn't stop when you open the door as you stated, here's a possible remedy you can try on your own. Make sure the unit is off first. **Turn the breaker off at your home service panel before attempting any service suggested here on 'fixya"...safety first" This procedure I'm going to suggest can be done easiest and more accurately by removing the door panel & control panel for better access as well as to visually inspect other component. It is quite involved though so I recommend calling in an authorized Asko tech. It can also be done without removing the panels by identifying the small round "pin" in the the door latch channel ( where the latch goes into the door when closed ) and with the aid of a small screwdriver, tooth-pick, paper clip or hair-pin etc. Add some vasiline or grease to the top of the pin working it in via pushing the pin up & down...I recommend removing the panels though. To do this... Open the door and along the both sides and the top you'll see "T20" torx head screws, there are also two in the middle of the inside door panel near the bottom. Remove just the screws for the door skin/panel first, three on each side and the two in the middle as I mentioned. This next part can be tricky and you must also be careful as the edges of these panels are sharp ( auto-mechanics protective gloves are good for this ). Once you've removed the screws from the panel, it should create a small gap at the bottom of the door where the inner and outer panels meet. with a free hand reach in and push the plastic condensation vent away from the slot in the bottom of the door and then push up on the middle door panel attachment ( the piece with two screws removed ) up as you pull the panel away from the door. Now the panel should come off. Now you need to remove the control panel/user interface panel. This should be relatively easy after what you've just managed to do. Remove the remaining "T20" torx head screws for the control panel and it should come off with little effort. Once off you can see the micro-switch and the small "pin" I was referring to earlier much easier. Apply some grease or silicone lube to the shaft of the pin/accuator and work it in really thoroughly. Re-attach just the control panel part of the door and you can test it before putting it back together entirely. Let me know if you require further assistance. Thanks for coming to fixya, please take a moment to rate the help you received. Good luck. Macmarkus :)
Dishwasher was washing I opened door to add dishes
Hi, Thank's for your reply. If I where in your position I too would certainly weigh the comparison of repairing versus replacing however, if you are capable this one is worth inspecting. I would start by checking the breaker ( insure there's power to the unit ) door switch, insure the latch is making contact with the switch plunger,(tiny pin that actuates the door micro-switch) the wiring, etc. The timer being the least likely, so we'll cross that bridge if & when necessary. If you are not comfortable with the "do it yourself" idea, again you'll have to decide if the unit is in otherwise good enough condition to justify calling in a pro. If so I'd also suggest an authorized Asko servicer as these aren't like most other dishwasher's and I personally have witnessed many mis-diagnosis due to ignorance or un-familiararity, I don't know. I don't want to see you get "took" for unnecessary repair cost's. Let me know if I can assist you further and I'll watch for your replay again, keep me posted. Good luck. Macmarkus :)
1helpful
Machine not starting , door not closing well, no click from locking mechanism
The door latch and or door handle assembly which also holds the door switch may have brocken.
If the door latch does not shut properly, this will not close your door micro switch. And if the switch is not closed then the machine will not operate.
Turn off machine at the power source. Open the dishwasher door. You may want to put some weight on the door to stop it from springing back up.
If you have a star allen key or a star shaped tool, you can open the screws around the stainless steel plate of the dishwasher door. Start with the ones on top, which secure the control panel and door lock. See if you can remove the control panel gently without having to open the screws for the front door panel. Sometimes you may need to loosen the front panel screws to free the top control panel.
Once you remove the panel, you will notice a door handle assembly which also holds the micor switch. Take note of how it is set up. Also examie to see if any plastic parts are broken. You may need to order the complete door latch or door handle assembly and replace.
While doing this make sure the machine is turned off at the power source.
Good luck.
Ash
12helpful
2answers
Our Asko D3112 was not draining, so we had maintenance drain the hoses to clear any blockage but it did nothing. They said it must be our pump not working. I ran one more cycle to see if things went back...
Check your manual to see if you have a drain pan at the bottom of the unit, and a 'float' that checks for water collecting there. On at least some Asko models, water collecting in the pan causes the float to rise, which then changes the operation of the dishwasher. Once that float switch turns on, the diskwasher will always run the drain pump whenever power is applied.
If this is the case for your machine, remove the kick panel. There likely is another panel behind that which covers the 'internals', including the drain pan area. You'll have to remove all of the water in the pan, and that will lower the float and return the controller to normal operation. THen you will have to diagnose the cause of the water collecting in the pan.
Another possibility is damage to the float such that it has turned on it's switch despite no water collecting in the drain pan. I've heard that in some cases a mouse will chew on the float and damage it, causing such machine operation.
In another thread, I posted my solutions to one cause of water collecting in the drain pan. In that case the drain pump was no longer reliably moving water out of the sump area inside the dishwasher. I had thought it was the manual dial control on my d1706 unit, until I learned that the dishwasher has this 'special' drain pan mode.
Asko D3250 not working
If the first start button is blinking then there is a door error...the door switch is not closing... to repair
1) turn off the power at the breaker...
2 ) remove screws in the door T20
3) remove contol panel (slide up)
4) place wire tie behind micro switch on door latch...
5) replace door latch and door.
Hope it helps....If NOT let me know more about your problem ... I will Help
Pump continuing to run -Asko D3100
Micro switch was actually faulty,moisture had entered the switch and caused internal tracking and shorting out the micro switch ,making the pump run continually as it thought it was still in flood mode.
Flood appears to have been caused by a pin hole in the water fill hose in the base of the dishwasher,causing water to spray on the micro switch and eventually biuld up in the base of the machine.
Aug 05, 2008 • Dishwashers
2answers
F2 error message flashes, cannot reset.
Try to find out from where water leaking from (pump or inlet valve). The leaking one, should be replaced. Good luck !
Top Asko Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
