Question about The Computers & Internet
HOW DO I GET TO SETTINGS ON MY ZTEN817?
MY PHONE NEED TO RESET MY OPTIONS. RIGHT NOW I HAVE TO ACTUALLY BANG ON THE SCREEN, THE CIRCLE THAT SHOULD COME ON WHEN YOU START IT IT GONE.
2 Suggested Answers
  • 49170 Answers
SOURCE: I need to find a case for my ZTEN817 cell phone and I don't know the size to get?
go to a phone shop or mall and there are shops that sell covers and cases to suit your phone
all you need is the phone as a sample
Posted on Sep 09, 2017
Sep 09, 2017 | Cell Phones
How to reset my Motorola blur
Factory Data Reset is a tool used to remove everything that was imported, added or installed on the device. Keep in mind, when using this feature; everything is deleted. Nothing stored on the MicroSD will be affected. Your information is automatically backed up to the MOTOBLUR server. Your information will be restored when you login with your user name and a password.
Factory Data Reset
  1. From the screen of your phone, open the Applications Tray. (circle located in the middle at the right of the display screen) Or press the Menu button on the left from your screen.
  2. Tap Settings
  3. Scroll down and tap Privacy
  4. Tap Factory Data Reset
  5. Tap Reset Phone
If you are unable to navigate through the menu to perform a factory data reset, you can follow the steps outlined below:
  1. Power off the phone, press and hold volume down button, press power button.
  2. Wait for the "triangle ! / Android" screen then release the volume down button
  3. Tap lower right-hand corner of Touch Screen
  4. Navigate on-screen menu to select "Wipe" (data/factory reset) and Press OK
  5. Navigate on-screen menu to select "Reboot System Now" and Press OK
  6. Wait for device to reboot
Apr 22, 2016 | Motorola Cell Phones
I don't know what part of the icon bar to use to connect to the internet through my router, can you tell me?
are you using pc of phone
on pc there will be a tool bar (line of icons) at the bottom of the screen one will be E in a circle that is the explorer browser that will connect to the internet.
Feb 11, 2015 | Computers & Internet
My Samsung Galaxy Light won't vibrate anymore. How can I fix it or get it to work again. Thank you
Setup the Vibration
This option allows you to set your device to vibrate and ring.
1. From the main Settings page, tap My device tab ?
Sound.
2. Tap Vibrations.
3. Select a vibration pattern and tap OK.
- or -
Tap Create to then use an on-screen touch circle to
create your own custom vibration pattern. Tap Save to
store the new vibration pattern.
Sound Settings
From this menu you can control the sounds on the phone as
well as configure the display settings.
 From the Home screen, press and then tap
Settings ? (My device tab) ? Sound.
The following options display:
Silent mode via Device Options Screen
Silent mode is convenient when you wish to stop the phone
from making noise, in a theater for example. In Silent Mode
the speaker is muted and the phone only vibrates to notify
you of incoming calls, or other functions that normally have a
defined tone or sound as an alert.
1. From the Home screen, press and hold
(Power/End) until the Device options screen displays.
2. Tap either Mute, Vibrate, or Sound from the Device
options screen to activate or deactivate these features
(the current mode displays).
You can download the User manual from the site below
https://support.t-mobile.com/docs/DOC-9140
Feb 07, 2015 | Samsung Cell Phones
Iphone 4 home button not working properly.. Its working when i press hardly , how to fix it
In this case, your home button's connectors may have been misaligned and would require professional repair.
The good news is, you can still use your phone using its on-screen home button. Normally, this is used as an accessibility option, but it's also a common solution for those with non-functioning home buttons.
To enable the on-screen home button,
go to Settings > General > Accessibility > Assistive Touch. Turn Assistive Touch on, and you'll see a small circle appear on screen.
Tapping that circle gives you four options: Home, Siri, More (for things like multitasking and playback controls), and Favorites. In your case, ignore Favorites, but tap this on-screen button whenever you need to access your home screen, activate Siri, or get all the options you'd normally see when you double-tap the home button.
If the on-screen home button ever gets in the way, simply tap and hold to drag it anywhere else along the frame of your screen.
Mar 31, 2014 | Cell Phones
Garmin nuvi 885t voice command address does not work. command where too, response choose option. command --address, response, use the keyboard, this option is not available on on this model. this...
It seems that it's a software problem ,. To software problem on your device , you need to reset it .
To reset your NUVI , please follow one of these procedurs :
1:Turn the Nuvi on.
2:Touch the tools icon on the main screen. The tools icon is represented by a wrench surrounded by a blue circle.
3:Touch the "Settings" icon which appears as a wrench.
4:Push the "Restore" button at the bottom of the screen. A confirmation message will appear asking to confirm restoring the Nuvi to factory settings. Push yes to restore the factory settings
Try this for hard reset .
Turn off Garmin device. Press down on bottom right corner of the touchscreen [ Don't let go ] , and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
PLEASE DON'T FORGET TO RATE !
Apr 20, 2010 | Garmin nuvi 885T GPS Receiver
I have a sidekick and when i changed it to spanish, now doesnt do anything at all it powers on and the rolling ball doesnt work and doesnt responds to anything, anyone knows something ?!
You may need to perform a Master Reset. This will fully restore your phone to it's factory settings.
To do this, remove your SIM card and follow these directions:
1) Flip the screen as if your about to close it.
2) On the upper right hand side look closely. You will see a little arrow pointing to a small circle.
3) Push in the circle with a paperclip and at the same time hold down the power button.
4) Remember to push both at the same time and keep them pushed in until the phone turns off.
5) Once the phone turns off you have done the hard reset successfully.
6) Then, turn your phone back on normally.
Apr 01, 2010 | Sharp Sidekick LX Smartphone
How do i reset my phone
Hi, On your home screen click on the blue square icon with the white dots, on the lower right, then click on the icon that looks somthing like this * it is the bottom icon on the right, then click on phone icon, the last option is reset settings, click on reset settings, then you have two options- master reset - master clear.
Sep 07, 2009 | LG Xenon GR500 Cell Phone
How do I forward call on my blackberry?
Open BlackBerry Call Forwarding Options
To access your BlackBerry call forwarding options screen, click the green Send key and then open the menu options by clicking the BlackBerry Menu key. Scroll down and select Options.
You'll then be presented with a list of your BlackBerry's Phone Options, which include Call Forwarding. Click on this option and wait a few seconds for the call forwarding screen to populate.
Enter a New BlackBerry Call Forwarding Phone Number
Before you can forward incoming calls via BlackBerry, you first need to enter the number you want calls to be forwarded to.
On the main Call Forwarding options screen, click your BlackBerry Menu key and choose New Number. A dialogue box will then appear asking for the number to which your calls will be forwarded. Type in the 10 digits and click the trackball to save the number.
If you mistyped the new call forwarding number and you need to correct it you can click the BlackBerry Menu key on the main call forwarding screen, choose Edit Number, scroll to the number you wish to modify, click the trackball again and choose Edit from the available options. From there, you can make your desired corrections. To save the changes, simply click the trackball one more time. You'll then be returned to the Edit Forwarding Numbers screen. You can reach the main Call Forwarding option screen by clicking the BlackBerry Escape key once.
Enable BlackBerry Call Forwarding, Tweak Settings
On the main BlackBerry Call Forwarding screen, you have two options for call forwarding: 1) Forward All CallsForward Unanswered Calls. Below the latter option, you have three more choices: A) If Busy; B) If No Reply; and C) If Not Reachable.
By default, your device is set to Forward Unanswered Calls to your carrier's voice mail box in all instances.
BlackBerry Forward Unanswered Call Options
Forwarding every call that comes in to your device is simple; you just fill in the circle next to Forward All Calls and then specify the number to which you wish to direct calls from the corresponding drop-down menu. To save any changes you make, click the BlackBerry Escape key and confirm the changes when prompted.
Forwarding calls in specific situations is a bit different, but it's no more difficult. The first thing you want to do is ensure that the circle next to Forward Unanswered Calls is filled in. (Again, this circle will be filled by default unless you modified your settings.)
To forward only the calls that come in while you're already on the line, click on the If Busy option to open the drop-down menu and then choose the number to which you want to forward your BlackBerry calls. If that's the only call forwarding option you wish to modify, click the BlackBerry Escape key and confirm the change when prompted.
If you want to forward calls that come in while you're, say, in another room and away from the phone, change the number associated with the If No Reply option and save your changes.
If you want to receive calls when your BlackBerry is turned off or you're otherwise unreachable, modify the number settings next to the If Not Reachable option and again save your changes.
When BlackBerry call forwarding is enabled, you'll see a small icon, which looks very much like the missed call icon, appear on your BlackBerry home screen.
Finally, if you wish to return to your device's default settings, simply fill in the circle next to the Forward Unanswered Calls option and set the number for all three options (If Busy, If No Reply and If Not Reachable) to your wireless carrier's voice mail digits.
May 11, 2009 | Google Android
Computers & Internet Logo
37 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
