Question about Cell Phones
I am trying to connect my echo dot to my wifi using the app on my phone and it's not working
rohansachar
  • 18 Answers
SOURCE: connecting using WiFi
Doesn't seem like a hardware issue..
I would suggest a Reset to your phone..
Just go to Control Panel > Master Reset..
Do take a back-up on your PC before as this process WILL ERASE data..
Regards,
Rohan Sachar
Posted on Dec 01, 2007
  • 22 Answers
SOURCE: My wifi keep saying disconnected this phone is not on I just let my son use the phone to download apps I reseted everything because it was not working right yesterday and now i can't get the wifi back
try this solution...
1. select "airplane mode" to disable all wireless connection then turn off your phone.
2. turn on your phone then disable "airplane mode"
3. turn on your wifi now.
Posted on Mar 05, 2013
SOURCE: Connecting my iPhone app to home computer wifi
iphon
Posted on Jun 12, 2013
wdjones817
  • 77 Answers
SOURCE: on my Huawei MyTouch Q phone the com dot huawei
Resolution Steps App previously worked
If the app that is showing errors has previously worked and not been updated, follow these steps:
  1. Think about the pattern of what you were doing when the device froze, and what programs were open in the background. Use the answers to focus on device functions or apps that are not working correctly.
    Note: If the problem is related to more than one specific app, see: Device is slow / freezes / restarts / or displays memory errors: Android
  2. Check the docs for your device to see if there are any specific instructions for it
  3. If the problem is related to contacts or an 'android.process.acore', back up your contacts:
    1. From the Home screen, press the Menu key.
    2. Touch Settings.
    3. Touch Accounts & sync.
    4. Turn off all synchronization to Google accounts and T-Mobile Contacts Backup.
    5. Return to the Home screen.
    6. Open the App menu.
    7. Touch Contacts or People.
    8. If there are any contacts listed, they are stored on your phone (because you turned off the ones synced). From the menu, export them to the SD card to save them.
  4. Clear the app cache and data:
    2. Touch Settings.
    3. Touch Applications.
    4. Touch Manage Applications.
    5. Touch All.
    6. Select the application that is having issues.
      Note: For the following errors:
      • android.process.acore: Select Contacts storage.
      • android.process.mms: Select Messages.
      • com.google.process.gapps: Select Download Manager or Downloads (At the bottom of the list). Make sure the Downloads Manager is enabled. If it isn't, enable it before proceeding.
      • TWlauncher process com.sec.android.app: Select TWLauncher.
    7. Touch Clear data and Clear cache if they are available. This resets the app as if it was new, and may delete personal data stored in the app.
  5. If you turned off sync, return to Accounts & sync and turn it back on. If necessary, import any contacts you exported to the SD card.
  6. Uninstall all third-party party task managers, battery saver, or apps that close programs. For information, see Manage Applications: Manage memory on Android.
  7. Restart the device.
  8. Open the app to test if the problem happens again.
  9. If the problem recurs, uninstall the app (if possible).
  10. Wipe the cache partition to clear system memory.
    Note: To find steps for your device, search Support Community for: wipe cache [device name]
  11. Open Play Store, and re-install or update the app.
  12. Open the app to test if the problem happens again.
  13. If the problem recurs:
App never worked OR app received update and stopped working
If the app that is showing errors never worked OR was updated and then stopped working, then follow these steps:
  • If the error is with a pre-installed app, then look for more content in your device space or user manual.
  • If the error is with third-party apps, then contact the app developer. T-Mobile does not support third-party apps.
Posted on Mar 20, 2014
knitsterlady
  • 20 Answers
SOURCE: does echo dot work without power connected
You could ask it, lol. Says it's battery powered.
Setting up echo dot
hi roger.
see if this helps you out.
  1. Turn on Echo Dot. Place your Echo Dot in a central location (at least eight inches from any walls and windows). ...
  2. Connect Echo Dot to a Wi-Fi network. In the Alexa app, follow the instructions to connect Echo Dot to a Wi-Fi network. ...
  3. Talk to Alexa. ...
  4. Optional: Connect Echo Dot to an External Speaker.
Amazon.com Help: Set Up Your Echo Dot
https://www.amazon.com/gp/help/customer/display.html?nodeId=201994280
or if you need more help go to this link.
Setting up echo dot Google Search
Nov 16, 2017 | Echo Computers & Internet
Need to connect echodot. How do I do
To connect to Echo Dot you have to go to the Alexa App on your phone or computer. Here is a page on how to set up. https://www.howtogeek.com/235653/how-to-set-up-and-configure-your-amazon-echo/
Oct 17, 2017 | Computers & Internet
My echo won't turn on, I've tried the fix on my app but the orange light doesn't come on
to restart your Echo device, unplug the power adapter from the back of the device or from the wall outlet. Then, plug the power adapter back in. To reset your Echo Dot that has volume buttons:
  1. Press and hold the Microphone off and Volume down buttons at the same time until the light ring turns orange (about 20 seconds). Then light ring turns blue.
  2. Wait for the light ring to turn off and on again. The light ring then turns orange again, and your Echo Dot enters setup mode.
  3. Open the Alexa app to connect your device to a Wi-Fi network and register it to your Amazon account.
You did not state if it is a dot or not if it is not a dot, there is a reset button that you can press in with a paper clip.
I hope this helps.
Aug 18, 2017 | Orange Computers & Internet
Alexa says try later can't connect to server
If you echo or dot is saying this, verify you WiFi is working. You can check your wireless to see if it is connected, but most folks don't have the access.
Try to do the setup from your handheld again. It connects to dot via Bluetooth and then you set up the WiFi connwction
I got this on my handheld app once and rebooting phone fixed that.
Hope this helps, if not tell us if it is the app or the device.
Mar 02, 2017 | Computers & Internet
Why can't I connect to home WIFI?
Firstly, I would reset the router by removing the power for 5 minutes and then try again.
Jan 21, 2017 | Samsung Computers & Internet
Do you need to keep0 echo dot connected to power line to work?
Yes it must be powered all the time. Amazon has
Evo - an intelligent Battery Base for 2nd Generation Echo Dot. ("Alexa" unlimited) (EVO 2 White) $35
This attaches to the Dot and plugs in to the power socket, then the power connect to the Evo unit. This allows you to use it not connected for up to 5 hours or longer on stand-by and you can easily move it from room to room without have to reconnect to the WiFi.
Jan 02, 2017 | Echo Garden
I bought 2 echo dots i was able to connect one but the 2nd one wont connect
Check and make sure you follow all the steps it took to connect the first echo dot
Tips:
1. If the setup process does not automatically start, press and hold the Action button on Echo Dot for five seconds. Then, open the Alexa app, and go to Settings > Set up a new device.
2. If Echo Dot doesn't connect to your Wi-Fi network, restart Echo Dot by unplugging and plugging the device in again
Nov 26, 2016 | Office Equipment & Supplies
I can't connect to wifi and when I can I can't setup my gmail account or any other apps I have try everything I know
I'll give you some help on ANDROID. Go to apps, settings\ WiFi. Turn it on at top of screen. Any available WiFi accounts will show up. Then go to top right push the three dots, click advanced and make your choices. Click back to WiFi screen and click the WiFi you want to connect with, enter the key that your WiFi needs to connect, or use the WPS option if available on you WiFi. If the WiFi has WPS, push the button on the WiFi and connect your tablet or phone by pressing connect.
Nov 29, 2015 | Tablets & eReaders
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
