Question about Kenmore Sewing Machines
What is value of Kenmore sewing machine model 1240, slightly used, with case?
SOURCE: Kenmore Sewing Machine model # c877.15
I have an old Kenmore and here are the directions from my manual: 1. Draw thread from spool through bobbin winder tension discs. 2. Wind thread around an empty bobbin several times. 3. Place bobbin onto bobbin winder shaft with thread coming from rear of bobbin. Push bobbin winder latch against bobbin until it clicks. 4. Release clutch by turning clutch knob toward you. Start machine.
Posted on Aug 09, 2007
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Posted on Jun 05, 2008
SOURCE: Kenmore sewing machine manual for model # 148 12080. (older)
i have a older kenmore sewing machine model #148.19370
Posted on Sep 17, 2008
SOURCE: kenmore sewing machine model 385 16764
There's a website called which is sponsored by Sears. It's free to join. Go to the Home Manager column and choose Owner's Manuals from the drop down menu.
You can type in the brand name (Kenmore) and model number of your machine. Not all of them are in there but, I did find the one for the 1950280 question. It's a pdf file.
For the 38516764 question, please double check your model number. I received either no response or a Kenmore Elite dishwasher manual in response to my query.
Posted on Feb 04, 2009
  • 255 Answers
SOURCE: how to "tune-up" mechanical Kenmore sewing machine
Sure! Jenny at has several very good, in-depth articles about servicing your own machine, but here are the basic steps:
1. Take out the bobbin case and bobbin holder.
2. Take the needle plate off.
3. Brush out all the old lint in the bobbin area and under the needle plate. Remove any loose bit of thread.
4. Open the head of the machine (should swing open). Clean any lint or thread that's caught in there.
5. Locate your machine's oil ports and put one drop of sewing machine oil (only use sewing machine oil) in each of them. One drop is sufficient. General rule of thumb: Put one drop of oil wherever metal moves against metal.
6. Using unwaxed dental floss, floss the tension disks.
7. Put everything back together.
If you need a manual, I found one at
Hope this is useful!
Posted on Jul 30, 2010
Please show a list of kenmore sewing machine manuals
This should be most of the Kenmore sewing machine manuals.
385.1 521 2
SWA/RS 10101
SWA/RS 11101
SWA/RS 12551
SWA/RS 12621
SWA/RS 14401
SWA/RS 14501
SWA/RS 14502
SWA/RS 14571
SWA/RS 14572
Oct 02, 2014 | Kenmore Sewing Machines
Good Sewing Machine
Looking for a good, used, sewing machine? The Sears Kenmores from the 1970s are a good value. Even if you have to take it in to be serviced, you have an all metal machine that will last another 40 years. In addition to being solid, the Kenmore models had stronger motors, making quick work out of a project.
on Mar 05, 2015 | Singer Sewing Machines
What is the used value of a kenmore sewing machine model 38516227300?
It depends of the year and condition....and are you sure that is the model number? it seems wrong.....
Sep 16, 2014 | Sewing Machines
What is the value of the Kenmore Sewing Machine Model 117.581?
Depending on the condition and the cabinet style, about 50 bucks. Sorry. Really the only value is the sewing capability. No real antique or collectable value. Very good machine tho. Durable and sews like the devil when in good repair.
May 19, 2014 | Kenmore Sewing Machines
Kenmore contour No.3 sewing machine is what year?
Try the following: Http:// Note: Most antique sewing machines have value up to $35, and only have sentimental value. Jimmy
Apr 05, 2012 | Kenmore Sewing Machines
I have a Kenmore sewing machine - 12 stitch model which I bought in the 70's. I am having a tension problem and can't seem to fix it. What is the normal setting for the top, and bottom?
Load your Kenmore sewing machine with the right thread and bobbin thread for your project. If you use the wrong weight thread for your fabric or severely uneven weights of thread, this can cause the appearance of a tension problem when it is, in fact, a thread weight problem or a problem with your sewing speed. If you go too fast, you will break the thread. If you go too slow, you can cause loops. Uneven pressure can cause stitches to vary greatly.
Test your Kenmore sewing machine's tension by sewing on a piece of scrap fabric. If your tension is way off, then test on some basic cotton or a firm blend simply to get your tension right. Do not try to start adjusting your tension on silk or leather. Get a base adjustment on a more standard fabric first.
Look at the top threads and bottoms threads. If the tension is off on one side, it will usually affect the other side slightly. So select the side that looks more maladjusted to start adjusting the tension.
If the top thread is too loose or too tight, you will need to adjust the tension dial. This dial is usually located a few inches above the needle on the Kenmore machine body. Usually, your machine will have markings to indicate which direction tightens the tension. If these have worn off over the years, watch the dial as you turn it. If it appears to move toward the machine body, then it is tightening.
If the bottom thread is too loose or too tight, then you will need to open the door to the bobbin case. On some Kenmore models, there is a little screw near the bobbin case that can be adjusted slightly to adjust the tension. On other Kenmore models, there is a screw on the bobbin case itself--not on the bobbin, but on the bobbin's casing. This will also adjust the bottom thread tension. Adjust the bobbin thread tension to make slight changes.
If the thread is looping severely on one side, the thread weights might be off. For instance, look to see if you have a lightweight thread on the bobbin and a heavyweight one on the top. If the thread keeps breaking, the top tension or bottom tension could be too tight or the thread is too lightweight for the material you have selected. Check your combination of threads and material. Also make sure you are using the right weight needle and the right foot for the sewing step or project you are working on.
If your Kenmore sewing machine's tension is off severely or if you have not used your Kenmore in a long time, then you might need to take your machine in to be serviced. Sometimes, the inner parts need to be oiled or the entire machine might need to be cleaned and calibrated by a professional. If you sew a great deal or if your machine sits idle a lot, both situations will usually require some servicing to keep your Kenmore sewing machine and its tension in perfect working condition.
Jul 11, 2011 | Kenmore 15358
Could you tell me what the value of the Kenmore Sewing Machine Model E-6354, I want to sale it.
Your model number is not E6345, that is probably the cabinet number. Kenmore's have a nonclementure plate on the machine that gives the numbers. They start with something like 117, 158, 385 etc. then they have about 4 or 5 numbers after that.
Sep 17, 2010 | Kenmore Sewing Machines
Hi i want to buy a sewing machine wich one is best. kenmore or brothers sewing machine
I would prefer Kenmore, enmore makes perhaps the largest selection of mechanical machines. The very cheapest Kenmore sewing machines, like the Kenmore Mini (*est. $100) and Kenmore 15208 (*est. $120), stick with a four-step buttonhole, and have just six and eight stitches, respectively. The Kenmore 15212 (*est. $150) and Kenmore 15218 (*est. $170) both have a one-step buttonhole. The cheaper Kenmore 15212 has 12 stitches. The slightly more expensive model has 18 stitches, including a smocking stitch, overcast and elastic stretch stitch in addition to the basics. Both Kenmore sewing machines are good, basic models, say reviews. Both have just a 90-day warranty, however. Bear in mind that Kenmore sewing machines are made by different Asian companies each year, resulting in varying degrees of quality; this also explains the low prices. Some users report difficulty with tension and light fabrics.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 03, 2010 | Kenmore 19365 Computerized Sewing Machine
Kenmore model 158.17810 sewing machine noise
that is a fifty fifty chance you have to take. It may be something minor rubbing or you could have a slightly bent shaft underneath making noise
Dec 10, 2009 | Kenmore Sewing Machines
Sewing Machines Logo
61 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
