Question about Vehicle Parts & Accessories
What do I need to charge my EverStart maxx jump starter 600 amp unit. I can't find whatever came with it to plug it in to an AC outlet.
  • 10,830 Answers
All you need is a charger that put out a few amps. nothing higher. youll have to shop around to find one that has the right end connector for the boost pack... maybe contact the maker on this issue??
Posted on May 23, 2017
2 Suggested Answers
ftw1952
  • 10319 Answers
SOURCE: I need a manual for a Everystart jump starter 400 amp
try this website and keep it as a favorite on you webpage if you have google
they have tens of thousands of free owners manual including for vehicles
http://www.manualnguide.com/
Posted on Mar 09, 2010
Can't charge battery for ever start plus 750 amps has air compressor. I have asked this question a lot but no good answer.
Your question isn't very well worded, so no decent replies. I have reworded it for you Bonnie.
This is a cheap unit from Walmart. 28 bucks will get you a new one.
So you try to charge it and it doesn't charge? It can only be three things.
  1. The internal battery has failed
  2. There is a loose connection inside
  3. The charger circuit is broken, faulty, shot.
I did a search and found I answered another post on these units it is a known problem and that is probably why Walmart were selling refurbished units. So many of them, they couldn't just write them off. They got the company to fix the issue and then offered them for sale as refurbished units.
everstart plus 750 won charge Google Search
Here is my other post
My everstart jump starter will not take charge have to pull the fuse for...
Nov 07, 2017 | 08118-77-58 10-Gauge Top Post and Side...
Need Manuel for the ever start 750 a amps jumper starter with air compressor. I already have purchased the item.
https://dogdowndingper.files.wordpress.com/2015/07/everstart-jump-starter-300-amp-instructions.pdf
Nov 02, 2017 | Air Tools & Compressors
I have an Everstart Jump Starter hp250,no AC adapter or manual. Not sure it even works. Is there anyway I can test it myself at no cost?
If the battery is discharged and been so for several months the battery is certain to be useless or nearly so. Lead acid batteries need to be kept fully charged or they die quickly. The standing rule for jumpstarters is to recharge monthly and after every use.
A cheap low powered jump starter will be cheaper to replace than to obtain a replacement battery but a replacement battery will be cheaper for a medium duty upwards and they are mostly easy to fit.
It is impossible to test a discharged lead acid battery or indeed a jumpstarter. A manual shouldn't be needed as they are intuitive to use and the safety precautions are generic.
The charger is also a fairly generic 12 volt charger (actually 13, 14 or 15 volts) as supplied with many appliances and accessories of all sorts and in addition the unit would be supplied with a fused lead to charge the unit from the cigar lighter socket, also generic.
If it charges successfully after you have borrowed a charger or connected it via the jump leads to a low powered, 0.5 amp, charger, the battery voltage should be at least 12.7 volts after standing idle for 24 hours.
Sep 12, 2017 | Computers & Internet
What does the flashing FL mean?
When the Jump-Starter is fully charged, the display will read FL. Disconnect the AC extension cord from the 110/120-volt AC outlet, and then disconnect it from the Jump-Starter AC charging plug. http://www.carid.com/images/peak/info/pdfs/pkc0j6-manual.pdf
Mar 29, 2015 | 600 AMP Jump Starter
How do you charge the 600 itself?
should have an AC power cord to plug into wall outlet and to a charging plug on battery pack unit
Sep 26, 2014 | 600 AMP Jump Starter
How do I recharge a Motor Trend jump starter
Get a recharge cord for the unit, plug it in and recharge.
Jun 28, 2014 | Power Center Jumpstart 11-411
My Everstart Maxx Jump Starter 500 amp will not charge and it beeps every 5 seconds unless I pull out the fuse? What is the problem?
I don't think they read the problem right. His charger will not hold a charge, not the car. I'm having the same problem. My charge will not charge when I plug it up to a outlet.
Dec 02, 2012 | Cars & Trucks
Mar 08, 2010 | Black & Decker Jump Start System 450 Amp...
Vehicle Parts & Accessories Logo
179 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
