Question about Coffee Makers & Espresso Machines
I have a beko condenser tumble dryer with a strange sound all of a sudden which became persistent. Sound like it is grinding on something. The inside spins and it does get warm.
Filters have been cleaned and water container is empty.When the I manually turn the inside it Feels heavy as expected.does anyone know what the grinding sound is and how do I fix it? Thank you
  • 55 Answers
SOURCE: hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Posted on Mar 10, 2008
Benimur
  • 6966 Answers
SOURCE: Bosch WTL5200SN/04 condense Tumble Dryer
Most Bosch WTL models to my knowledge has a small drain pump at the back of the bottom base underneath a lip top cover. If you would follow the condensation drain hose after the hose connector, the other end would be attached to the said pump. When you force air back and you hear air bubbling, that would be on the pump that has some water still in it.
Rather than kinks or blockage, pls check for any hairline crack or split on the condensation drain hose.
As to "red light indicating that this container is full" pls check if your "water container at the top" "which pulls out for emptying" has some sort of waterlevel detection (a pair of wire attached to a float mechanism. Otherwise, that red light is not indicating that the top container is full but rather that red light is indicating that the bottom base container is full and that the drain pump is not running. There is a float very near the drain pump that activates it. Having said this, then perhaps what the manual is referring to as "safety container for run-over water" is actually the "water container at the top".
Then it would either be the drain pump or the float switch that would have to be attended to.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 07, 2008
SOURCE: indesit condenser tumble dryer water
Maybe trapped water in the dryer. Switch off and remove power from wall. Remove condenser unit from the dryer (clean the condenser while you have the chance with plenty of water and an old toothbrush - it will probably be filthy). With the condenser unit removed stick an old tea towel in the hole where the condenser was and then tip the dryer on its side. If there is water it will either run onto the tea towel or onto your kitchen floor OR into the water container!
It worked for me, honest...
Posted on Mar 13, 2009
apart4u
  • 213 Answers
SOURCE: Problem with Indesit tumble dryer
could be a switch in there or one of these This sounds like the thermostats
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "6x3oXHgPLDg" placeholder (do not delete)
Posted on Jan 10, 2010
SOURCE: Condenser tumble dryer water problem
Took advice...isolated from electricity supply...removed left side panel (side with condenser tank), to access the pump. Cleaned it all out (masses of water and grey lint!) and put it all back together again. Bit fiddly getting the panel back on...no screws left over...result!
All working great now.
Simpler solution maybe...There is a 'trap door' that can be removed, which gives access to the area where the water and lint accumulate.
1) Isolate from electricity supply.
2) Take out the condenser unit at the bottom LHS front of the machine (routine maintenance).
3) Underneath of where the condenser unit usually lives..at the back...reach in and open the 'trap door'. This needs a flat head screwdriver and you must release the two plastic clips holding the trap door.
4) You can now access the area where the water and lint accumulate...which makes the 'float' give a false container full fault.
5) Clean out this water and gunk regularly (once a month)!
Hoping this will avoid taking the side panel off again...
Posted on Oct 12, 2011
I am trying to replace a belt on a Beko Condenser tumble dryer DRCS68W. I cannot find any instructions or videos online , surely this is something i can do without having to pay someone else to do it.
not same model number .but on my beko....i had to remove side panel.........remove element cover remove motor fan inside fan opening is 4 small bolts,. remove them..... ,.they hold motor to back plate...on front of machine.remove front fan.....then from side panel..remove plastic motor covering and wire harnes...then the motor just pulls forwards remove back plate...and machine bearing...put new belt on.... manover motor back inti place then refit as you took apart..........
chers
Nov 30, 2016 | Dryers
THE RUBBER RING IS MISSING OFF THE WATER CONDUCTOR ASSEMBLY ON MY BEKO DRCT70W CONDENSER DRYER, WHERE CAN I GET ONE
Take your pick :>)
  • Beko DRCT70W Tumble Dryer Spares ' eSpares www.espares.co.uk/search/mo1539505/tumble-dryers/beko/drct70w?page=2 Beko DRCT70W Tumble Dryer Spares. 11 to 20 of 110 items. 1; 2; 3; ... Genuine Beko spare part for select tumble dryers More information . In Stock . Stock Number ...
  • Freestanding 7kg Condenser Tumble Dryer DRCT70 ' Beko UK www.beko.co.uk/7kg-condenser-tumble-dryer-drct70-white
    • 8.9/10
    • 16 RATINGS
    Freestanding 7kg Condenser Tumble Dryer DRCT70. Toggle navigation. ... Beko freestanding products are guaranteed against the cost of ... please visit our spare parts ...
  • Beko DRCT70W Tumble Dryer Spares ' BuySpares www.buyspares.co.uk/tumble-dryer/drct70w-7186281200/...shop=beko... Buy your Beko DRCT70W Tumble Dryer Spares at BuySpares ... Beko DRCT70W Vent Kit Condenser Box (2m / 4" Hose) BuySpares Approved part. Suitable for: Beko DRCT70W.
  • Beko DRCT70W Tumble Dryer Spares www.bekospares.co.uk/tumble-dryer/drct70w-7186281200/catalogue.pl?... Buy Genuine Beko Tumble Dryer Spares with confidence at 4Beko ... Beko DRCT70W. If your tumble dryer is showing that the tank is full but it is infact empty, ...
  • Beko DRCT70W Tumble Dryer Parts ' Partmaster www.partmaster.co.uk/tumble-dryer/drct70w-7186281200/...shop=beko... Get the Beko Tumble Dryer parts you need at Partmaster. Our Beko Tumble Dryer parts range is available for delivery worldwide and for UK customers there is the option ...
  • Beko DRCS76W Condenser Tumble Dryer - Parts/spares ' eBay www.ebay.co.uk/sch/sis.html?_nkw=Beko+DRCS76W+Condenser+Tumble... Beko DRCS76W Condenser Tumble Dryer - Parts/spares 0 ... BEKO Tumble Dryer DRCS68W DRCS76W DRCT70W DRVS62W DRVS73W ... Beko Condenser Tumble Dryer ...
  • Beko DRCT70W Condenser Process Fan Assy. ' bekospares.co.uk www.bekospares.co.uk/tumble-dryer/drct70w-7186281200/condenser... Buy Beko spares for your cooker, dishwasher, fridge, freezer, tumble dryer and washing machine. Authorised Beko Dealer & Next Day Delivery available
  • BEKO DRCT70W MANUAL - mfg8a.probooks.no-ip.org mfg8a.probooks.no-ip.org/beko/beko-drct70w-manual.pdf time dryer beko pdf '' download beko drct70w tumble dryer spares espares pdf ' ... how to mend it com beko condenser dryer drct70w free pdf '' download beko drcs68s
  • Amazon.co.uk: beko tumble dryer spares www.amazon.co.uk > Search > beko tumble dryer spares Amazon.co.uk: beko tumble dryer spares. ... Universal White Knight Beko Tumble Dryer Indoor Condenser Vent Kit Box With Hose. by Lazer Electrics. £6.22. More ...
  • Beko DRCT70W Tumble Dryer Spares www.bekospares.co.uk/tumble-dryer/drct70w-7186281200/catalogue.pl?... Buy Genuine Beko Tumble Dryer Spares with confidence at 4Beko - Beko Approved Dealer and Next Day Delivery available!
  • wa+cwowlplelaaaaaasuvork5cyii=
  • Jul 21, 2016 | Dryers
    Hi I need to fit a small pulley belt on my BEKO condenser tumble dryer need any advice on how to fit please.
    why do you need to add a pulley would be my question here they usually work when new without adding anything else .
    Mar 06, 2015 | Dryers
    My beko condenser tumble dryer is drying fine but is making a loud scraping noise. When I took out the clothes there was a strip of white felt in the washing
    Looks daunting to start with but just done mine,
    remove top and all rear covers and rear panel after removing drum split washer, pump hoses, belt and elec connection, remove the drum and you will see where the felt seal goes. i had some felt i cut to 12mm wide and siliconed it in place, left to dry for 6 hrs, now runs fine.
    Feb 07, 2011 | Dryers
    I need to clean my filter on my beko tumble dryer!
    I usually just stick the shower on it to clean out all the bits of fluff that gets gathered in there, but remember to give the inside of that hatch u brought it out of with some kitchen towel before u put the condenser filter back in.
    Feb 23, 2010 | Dryers
    Coffee Makers & Espresso Machines Logo
    Top Coffee Makers & Espresso Machines Experts
    Colin Stickland
    Colin Stickland
    Kolbrun...
    Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
