You can activate it online instead of calling - here is the link;
https://mysky.sky.com/portal/site/skycom/support/contactusguest?setaction=reinstateSky
Hope this helps :)
Go to settings, then prepaid, then airtime info. That will tell you how many minutes you have & when your next card is due.
If you go to settings, then airtime display, then make sure that 'on' is checked, this will have your minutes & date due scroll across the bottom of your phone whenever you have your phone on.
Sky put the USB ports on the boxes in case they wanted to use them in future. They are there but not active. Bit like the eSATA socket on the back, it isn't used yet but they had ideas to use it!
I guess if they had to replace boxes all over the country to put a USB in would have been a bit of an issue for them, so best they fitted one from the start...
Turn Off the SKY box power and leave it off for 30 mins. Put the card back in to the box and turn it back on. Also make sure your phone line is connected OK. If this does not cure the problem contact SKY for assistance and possibly a new Card. They are also replacing all the viewing cards at preasent.
When you take Freeview from Sky its called FreeSat. You have to order the card from them by phoning them (click on link below for more info) and when you get the card follow the steps they give you to have it activated which takes around 30 mins to do.
Hi there. Look at the front right hand side of the laptop for the wireless activation switch, when you turn it on a light will come on. If you need more help on how to connect to your wireless network please post back.
there was a gadget on unlocking password in memory card, it was called unlock medial card, you can buy it in some computer accesories cnts, y can s t t sty mmy cad, bt mmb, all y fls n mmy card ill be lost. good lack......
Hope this helps :)
