Question about Sewing Machines
Cannot get my needle threaded to work - Sewing Machines
  • Sewing Machines Master
  • 12,287 Answers
Don't understand your question. You don't know how to thread the needle?
Posted on May 21, 2017
Back of fabric is all balled with thread
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread the top thread.
Test straight stitch.
For fraying thread, there is either a burr somewhere in the thread path or the needle is not correct for the thread. Sometimes the needle eye is too small for the thread and causes the thread to shred. Changing the type of needle (an embroidery needle, top stitch...) may help. Certain brand name threads work better or worse on certain machines. You might try changing thread brands. Avoid old or bargain bin threads.
All About Needles SCHMETZ Needles
Sewing Machine Needle Troubleshooting Guide SCHMETZ Needles
Feb 03, 2018 | Sewing Machines
I am having problems with my Husqvarna Ruby De Luxe thread shredding and would be grateful to receive advice.
Hm, wonder if the tension is not stable that it is an intermittent problem or does it occur where there are points where there is more thread buildup than others? Do you raise the presser foot before threading the upper thread so it will seat in the tension disk properly?
The other things I would look at would be the needle and the thread. Some threads work better than others so you may have to experiment with brands. The same with needles--the thread and needle should be compatible. If the thread is shredding at the needle eye, then it is probably a needle issue. Are you using embroidery needles? Maybe try a different type/size of needle (perhaps a needle with a large scarf). Make sure the thread is not too big for the needle's eye--try a lighter weight thread or a larger needle. Sometimes the thread shreds because the fabric (or stabilizer) is actually cutting the thread strands every time the needle penetrates the fabric.
Different machines seem to favor certain needles and threads over others. Some sewists swear by Superior thread, other sewists have better luck with another brand like Floriani. Ergo, needles--some sewists use only Organ embroidery needles, other sewists will use only chrome plated needles.
It may be a matter of finding what works best with your machine.
What Causes My Thread to Shred
Embroidery Library Machine Embroidery Designs Inspired Project Page
Dec 22, 2015 | Husqvarna Sewing Machines
Top thread is shredding Automatic needle threader stopped working
If the top thread is shredding it is usually because the needle and thread are not compatible. If thread is too large for the eye and the thread groove, the action of sewing will cause the thread to shred as it pieces the fabric.
Try a different needle and thread. Here's an excellent web site:
All About Needles
Sep 27, 2015 | Sewing Machines
Brother exedra E-40 why it alway get tangle and brake the threat?
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Aug 05, 2014 | Brother Industries, Ltd Brother Sewing...
Janome j3 20
Mar 01, 2014 | Sewing Machines
Top thread is breaking on Janome 6600P
The needle thread breaks
Jan 16, 2013 | Sewing Machines
Always thread breaks
try these suggestions
Oct 30, 2012 | Janome 6019QC Mechanical Sewing Machine
My Pfaff 4.0 breaks needles and shreds thread when free motion quilting
a sewing machine I work on last week, I put a new needle in the needle clamp & thought I had it correctly inserted,, but it wouldn't work,, so I went back & checked the needle again & found I had to unscrew the needle clamp screw even more than normal to insert the needle then it work perfectly.
some needles & thread don't work togeather--here's a tip
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
also clean under the needle plate where the feed dogs are for lint
& also in the bobbin area for lint & loose threads
Nov 18, 2010 | Sewing Machines
My bobbin thread keeps breaking and the machine starts sewing then it slows down and the thread breaks. It makes a terrible noise.like a clunking sound.
rethread the machine top & bobbin
change needles
make sure the needle is inserted correctly
check the top thread tension--3 or 4 usually is good
some needles & thread do not work togeather-try this
if none of these suggestions work then you should consider taking it to a repair shop to be checked
Nov 17, 2010 | Singer 3116 Simple
The thread from the needle keeps breaking
check the top tension-try 3 or 4
change needle & make sure the needle is inserted correctly
some time the needle & thread don't work togeather--try this
Nov 17, 2010 | White Sewing 1418 Mechanical Sewing...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
