Question about Garden
My lawnflite 404 starts but when i engage cutter the engine dies
  • 16 Answers
SOURCE: my mtd pinto mower engine cuts out when cutters engage - why?
it sounds as if your carb is dirty remove bowl on carb i"ll bet it's it's dirty if so you will need to remove the carb and clean it
Posted on May 30, 2009
  • 66 Answers
SOURCE: my 603 lawnflite ran over a man hole cover and
Should be just behind the dash
Posted on May 30, 2010
Testimonial: "Hi thanks will check it today,i also need a workshop manual for the 603 lawnflite 30" cut,would a manual from another lawnflite model be the same?,also has anybody else heard of the lawnflite 603 model or others, sucking manhole covers into its cutter deck,beware all lawnflite owners,this has happened to me on its second cut from new,i have cut our lawn with a westwood tractor for the last 26 years,and never had any trouble with manhole covers!!!!!!!!"
SOURCE: I have a 903lt Lawnflite and the engine stalls
use higher revs,
ensure you are not in reverse
get mower moving first then once driving forward then engage blades
Posted on Jun 07, 2010
SOURCE: My countax C300H starts OK but when I engage the
Just got one of these mowers myself - accidentally got a large stone caught in the blades which caused the same problem. It looked to me that there's a sensor on the flywheel that cuts the motor if the blades aren't rotating freely. You might find either that the sensor is broken (check it by pulling off the connectors and connecting them together) or that the blades aren't rotating for some reason.
Posted on Apr 21, 2011
perkins48
  • 14406 Answers
SOURCE: What is the cutter belt length for a lawnflite 904 ride on mower?
Is this your belt,they won't say how long they are for some reason. http://www.ebay.co.uk/itm/MTD-LAWNFLITE-904-906-920-940-MOTION-DRIVE-BELT-/230594980574
Posted on Aug 03, 2015
I would like a manual for a Lawnflite 404 please can you help?
Try Googling (lawnflite)(404)(manual) without parens.
Apr 24, 2017 | Garden
How to replace cutter belt Lawnflite ride on mower 903 auto drive , it came off and don't have operator manual for configuration
There are idler and tensioner pulley's, you sould maybe go to a dealer they could maybe help with the proper routing.
Apr 18, 2015 | Garden
Mower cuts out when cutter engaged
Check your blades for turning. A OTHER REASON COULD BE THE AIR FILTER GOT WET. If got wet. Put in the sun for a few days.
Mar 03, 2012 | Garden
Hi, I have a westwood t1500 with B & S engine which starts fine also runs fine with cutter disengaged,when cutter engaged it sends out clouds of white smoke and idles to a halt. Any ideas Regards ...
Sounds like the cutter is not turning free causing the engine to drag down and stop, I do not think the B&S engine is the problem. I have rebuilt dozens of these engines and most of the problems with a Briggs engine was dirt in the gas or carburetor that needed needle valve cleaned . If the cutters turn free, check for a bad or out of adjustment safety kill switch that engages and stops the engine as the cutters are engaged.
Sep 06, 2011 | Garden
I have an MTD lawnflite lawnmower but I don't know
That handle is probably what engages the blades Try SearsPartsDirect.com the may be able to tell what modrel it is
May 31, 2017 | Mtd Garden
My 603 lawnflite ran over a man hole cover and
May 29, 2010 | Garden
My mtd pinto mower engine cuts out when cutters engage - why?
May 23, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
