Question about Home
How to replace broken 1222 cartridge for tub
The brass shaft pulled off now I'm stuck with plastic head and cartridge still inside hole?
snakehead
  • 1074 Answers
SOURCE: Food processor blade stuck on motor shaft
my friend if you had not removed that blade for a while it will certainly stuck due to the moisture that forms on the shaft of the blade holder causing it to have corosion you will have to carry that item to be removed by a qualified tech by you doing it your self could cause damage,which could cost you more.good luck
Posted on Jun 19, 2007
SOURCE: Terrible noise on spin Cycle
Just had the same problem 1 month ago. My Whirlpool Duet front load made that terrible noise. 2 of the 3 spider arms were cracked. I hade a new hole tub with the spider arm and the shaft , because it is 10 years limited waranty . But if it is not under waranty it costs about 270$ for that tub you can buy it from many appliance parts web sites on the net. Good luck, huge job to all remove that thing
Posted on Dec 19, 2008
  • 94 Answers
SOURCE: New MOEN 1222 cartridge leaks
remove it and carefully inspect it, you might have scuff'd up the rubber's on the cartridge when you inserted new one.clean out,look in hous'ing for any foriegn mat.etc .you may need another new cart.
Posted on Apr 24, 2010
  • 81 Answers
SOURCE: Looking for cartridge for Tuscany Brass Tub
While there are several cartridges that look similiar to what you have posted, Danco it self is an aftermarket parts replacement business. From my point of observation, your posted pic is of a Delta stem which visually has some distinctive attributes. Most every thing Danco makes is a copy or OEM replacement part packaged under their name.
Posted on May 29, 2010
kapishtech
  • 2272 Answers
SOURCE: how remove the broken bathtub cartridge(Moen 1222)
The exact procedure to remove the old cartridge is with a plastic removal tool.With replacement cartridge you have to buy this plastic removal tool.Also there is same metal removal tool available.With the help of this tool you can easily remove the old cartridge.
Moen Cartridge Replacement Instructions
Moen shower faucet cartridge replacement is a project that will take some time to get done right. When is it time to replace a Moen cartridge? If you are like most people, you won't want to replace your old Moen cartridge until your old cartridge is starting to show its age.
Replacement is necessary, usually, once the old faucet starts to drip. Thankfully Moen faucet cartridge replacement is not difficult. However, if you are uncomfortable with doing the repair yourself, do not hesitate to call a professional plumber to do the job for you. This will guarantee that the job is done right.
If you follow these Moen faucet cartridge replacement instructions you will be able to replace your old cartridge by yourself. First of all, as with any plumbing repair, make sure that the water supply is turned off. Open the faucet to remove water pressure from the lines and let the remaining water drain from the pipes. You will then need to remove the faucet's handle by removing the decorative cover and removing the retaining screw. This will allow you to remove the handle.
Once the handle has been removed, work on releasing the splash plate from the wall. Generally there will be one or two screws to remove and the plate should release from the wall easily. From here the process begins to get a little trickier. Insert a shower stem socket onto the faucet valve's retaining nut and release the nut. Your Moen cartridge removal will be complete once you grab the cartridge with a pair of pliers and pull straight out to remove the old cartridge.
Clean any surfaces that you have access to and replace with the new cartridge. Follow all of the previous instructions in reverse order to re-assemble your shower faucet. Check to make sure that all the connections are tight before turning the water back on and testing the system out.
Now in your case the broken/cracked while removing the old cartridge so try this procedure carefully to get the stuck -up old cartridge out.
TAPPING the Threads into the Cartridge:
Carefully  hold one tab on the cartridge tight against the brass lip on the faucet body with needle nose and try  to drive the 1/2" tap into the smaller bore of the cartridge. It will take  about 15 minutes to slowly work the tap in all the way (maybe 3 turns?). Then  back out the tap... remove needle nose. [remember to turn the tap 1/4 turn back, for each 1/2 turn forward ... this clears the metal particles from the tap and makes the next 1/2 turn forward go smoother].
Next, assemble a 1/2" x 4" threaded rod, so it had threads all the way to the two jam nuts on one end)... If you use a bolt, get one with threads all the way up to the head. you may find it hard to find - so try a carriage bolt and spin a nut all the way up to the head .... continue:
next on the bolt goes a 1/2 nut (this is the "jacking nut") and a flat washer so the jacking nut can spin easily against the next piece, a 1/2 drive socket (7/8" ) with the square hole toward the washer and jam nuts ( bolt head ).
The open end of the socket faces the brass body of faucet and rests on the round brass lip... having the same inside diameter. This allows a space for the cartridge to be pulled into ( a cavity). Thread the bolt into the tapped cartridge and snug it up so the 7/8" socket is aligned with and resting against the brass body. If the cartridge spins smooth, the threaded rod is GREAT. You can just work with the 1/2" rod and use needle nose (or similar) to stop the  cartridge from spinning, to get the rod threaded into the tapped threads in the cartridge... then, slip on the socket, washer and nuts.
Now snug it up tighter. Check socket alignment. Then begin turning the jacking nut ( the "extra" nut) until it contacts the flat washer and 7/8" socket. Now, as you continue to tighten the jacking nut, it will pull the 1/2 bolt (threaded rod) away from the faucet... and the cartridge will come along too. [You have to prevent the 1/2 rod from spinning while tightening the jacking nut. put a wrench on the bolt head.]
This procedure is bit lengthy and requires some appropriate tools,but this will release the stuck cartridge out.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jun 07, 2010
How do I remove the old one
First you must determine if your shower faucet is posi-temp or if it has a separate balancing spool. The posi-temp takes a 1222 cartridge and the other type takes a 1225 cartridge. Remove the handle. There is a horse shoe clip which is removed from the top of the cartridge. A cartridge puller is highly reccomended. There are two different kinds. On the brass stem inside the cart. there is a notch. Make note of its position as this determines which side hot and cold are on. Pull the cartridge by twisting back and forth while pulling. Lubricate the inside of the cartridge barrel with faucet grease. No motor oil, vaseline or WD-40! They all eat rubber. Insert cart. and retainer clip. Install handle.
Jun 07, 2014 | Moen & Replacement Cartridge
Moen ca87553
You need a #1225 replacement cartridge. Pop the cap off of the handle. Use phillips screwdriver to remove the handle screw. Pull the handle off. Next, unscrew the two screws holding the cover plate on. After removing plate, there should be two integral stops, one on each side of the valve. Close the valves using a straight slot screwdriver. Pull on the brass cartridge spindle to ensure that the water is off. Remove the stop tube, which is a chrome cylinder at the center of the valve body. Look for a brass retainer clip at the top of the cylindrical portion of the valve body where the handle connects. It has a small hole and after you pull it out, you will see that it horse shoe shaped. Use your pliers or an awl stuck through the hole to pull the clip out. Note the position of your cartridge. There is a notch on the end of one side of the brass spindle at the center of the cartridge. Make note of its position. If you install it and get hot and cold reversed, just take the handle back off, and spin the brass spindle 180 degrees. The replacement cartridge comes with a white plastic tool designed to make removal easier. Use it. After loosening with the plastic tool, take your pliers and grab the brass stem. Pull as straight as you can. If cartridge will not budge, you might need a Moen cartridge removal tool. Do not spray with WD-40 or Liquid Wrench unless you like that taste in your water. If your clip won't go back on, it's because you didn't align the two ears on the cartridge. The ears should be at three o'clock and six o'clock. The cartridge must also be pushed in all the way. Good luck!
Dec 08, 2013 | Moen 3175 Legend One Handle Shower Faucet...
Removing Moen Cartridge with BROKEN shaft
Alan, I'm a certified plumber for over 30 years specializing in service. I hate telling you this but what you have is a Moen posi-temp and there is no tricks or easy way to remove it other than a cartridge puller which won't help in your case since it's already broken. Just break out your drill and carefully have at it, BUT don't leave the water on it won't help and may be dangerous and/or ruin your drill. For some reason on all Moens cartridges the rubber grommet tend to adhere themselves to the brass valve body's. Sorry, wish I had better news...
Jun 05, 2013 | Moen & Replacement Cartridge
Fridge washer GLWS1349AS0, have inner tub out, trunion lifted, not off yet due to slight rust. How do I change spin bearing and tub seal? thanks.
To remove the trunion totally reattach the inner tub to it and twist the inner tub,with the tub attached it gives you much more leverage to twist and pull the trunion off. After its off pull the small brass ring with the O seal in it up the transmission shaft and pop the tub seal off. To replace tub bearing remove the bolts on the side of the side of the outer tub off from the tub support and pull tub off of trans. shaft. to remove bearing flip tub upside down and remove the 2 screws from the tabs on bearing and turn tub back right side up and use a screwdriver on the top of bearing and knock it out of outer tub,push new bearing in by hand most of the way,being sure the tabs on bearing is lined up w/notches on tub and use old bearing placed on top of new one and drive it down all the way,reinstall screws into tabs. All the surface rust should be sanded off of trans shaft. Re install outer tub and secure with the bolts into tub support. push main tub seal into flange with normal palm pressure,install new brass ring and MAKE SURE O RING DOESNT POP OUT OF IT ( a little dawn,palmolive joy liquid dishwashing soap around inner part of o ring inside of brass ring will help it slip on easily) I use the old brass ring and press it over new brass ring to assist in o ring not popping out,once new brass ring is inserted ok and oring in place remove and discard old brass ring. Reistall trunion and inner tub ECT ECT ECT
Gene
Aug 12, 2011 | Frigidaire GLWS1349A Top Load Washer
How do you remove the old cartridge pn# 1222 after you have removed the temp. limit stop kit?
If you are referring to a Posi Temp cartridge they can be tough to remove from the valve body but there is a specific Moen 'puller' tool available. Basicially, once the 'U' shaped brass clip, which holds the cartridge on place is removed, the old cartridge (including the brass stem) will pull out completely. However they are frequently stuck in place and require some force to break free. A small plastic tool is included with the new cartridge - it isn't worth much, IMO but at least try it. Slide it over the stem so that it fits snuggly against the old cartridge and twist it with channel locks or crescent wrench. You may be successful in getting the cartridge to turn, one it does it will usually then pull out. Grasp the brass stem with vise grips/channel locks and pull the cartridge straight out. If it doesn't budge, you will likely need the specific tool mentioned above which screws into the stem (where the screw for the handle would normally fit) and is tightened down against the valve body. The pressure applied is similar to an auto. brake puller, pulling the valve out. Be careful in exerting any pressure against the valve body because it may not be adequately fastened to blocking inside the wall cavity and too much or excessive pulling may cause damage to the water supply lines.
Make sure before the install the new cartridge the valve body is clean and free of any build up. I usually take a little emery cloth and clean it out then flush the valve with water. Also use plenty of additional silicon/plumbers grease on all the black rubber seals before inserting it . Make sure it is not upside down and fits into the valve body all the way. The brass retaining clip is then re-inserted. Be careful not to lose it as a replacement is not included with the new valve and may not be easy to come by. Good luck!
Oct 25, 2010 | Moen & Replacement Cartridge
How remove the broken bathtub cartridge(Moen 1222)
Jun 05, 2010 | Moen & One Handle Tub & Shower Faucet
How do I remove the cartrige from the valve?
Assuming you have a single handle valve, Moen has 2 types of cartridges. The Posi-Temp (replacement cartridge # 1222) turns on and off simply by turning the handle left to right and right to left. The Moentrol (replacement cartridge #1225B) turns on by pulling on it. Handle style does not aid in identification.
Buy your new cartridge before you start and buy genuine Moen! OEM cartridges can give Moen a bad name.
Once the water to the valve is off, remove the handle.
The procedure is the same for either type of valve so use the link below as a reference.
Firmly grab the temperature limit stop and pull it off the valve body. Using pliers, pull out the brass retainer clip. Place the notched end of the white plastic tool that came with your new cartridge onto the old cartridge and rotate as needed until completely seated on cartridge. Put a wrench onto the squared end of the white tool and turn back and forth several times. Remove the tool, grab the brass center of the cartridge with pliers and pull the cartridge out.
Briefly turn the water on ond off to flush the valve of any possible lingering particulate.
Insert new cartridge and use white tool to assure cartridge is all the way in then use the squared end to rotate the cartridge as necessary into an alignment position to reinstall the retainer clip.
http://www.moen.com/shared/pdf/3170pt.pdf
Jun 03, 2010 | Moen & One Handle Tub & Shower Faucet
Removal or moen shower cartridge - plastic tab seems to be keeping the cartidge from being removed -- only get cold water, no hot
Once you have removed the U shaped cotter pin whis is brass in colour. Use a pair of plyers and hold on to the brass stem. you will need to pull fairly hard to remove. If you have the white or black stem loosening knob which comes with the replacement cartridge you can insert that into the brass cartridge where the plastic sides of the cartridge are showing. Turn your plastic konb clockwise to loosen the cartridge and then pull out.
Feb 13, 2010 | Moen & One Handle Tub & Shower Faucet
Moen monticello shower control, remove handle
If your Posi-Temp has no water coming through the valve my first step would to replace the cartridge (Moen pn 1222). The valve as a simple one. Get the part first so you can ues the plastic tool that comes with it if you need to. Beneath the actual lever insert on the handle hub you will notice a small hole. this is to gain access to the allen head screw which holds the handle in place
Feb 07, 2010 | Moen & Posi-Temp Single Handle Shower Or...
Faucet is leaking. Can you tell me if this is a
yes it is a cartridge replacement,the cartridge is,should be all that you need to replace.you did not list what kind of faucet. so here is a few number's. some bath/shower valves' take#1225-(plastic) this is also use'd in some kitchen,lav, model's.two handle faucet's#1224,the "posi-temp"#1222 is a tub shower only,there are cartridge puller's available,and recomened them,one is made by moen,another by brass craft,i have pulled cartridge's with out,so it is up to you.hope this help's.
Nov 03, 2009 | Moen & Replacement Cartridge
Home Logo
22 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
