Question about Clothing
I have an older(circa 2005) llbean mountain light 3. The velcro tabs sewn on the inside of the fly have separated from the fly. How can i get replacements, or if not, what is the recommended repair
    New Friend:
  • 13 Answers
A simple quick fix may be to apply some tailors liquid hem. Be sure to pin it in place and let it dry 24 hrs.
Posted on May 29, 2017
These are to prevent the umbrella from flapping in the wind when it is down. When you lower the umbrella, simply wrap the velcro strap around the entire circumference of the lowered umbrella, then attach it to the other tab. That's it!
May 11, 2015 | Hampton Bay Patio Umbrella. 11 ft. dia....
Ripped tent bag
Annoying but not a big deal. The bag is just for storage and carrying, so it can be sewn with nylon or similar thread and it will continue to serve.
Aug 21, 2013 | L.L.Bean Mountain Light Xt 3-Person Tent...
How do you attach the bag to the barracuda 2595 blower
The motor housing has a spring loaded, hinged cover over the fan blades (so you don't chop your fingers off when using it as a blower). Open the cover using a screwdriver or narrow tool. Holding the cover open, attach the vacuum tube. Attach the collection bag to the discharge port (same place you attach the blower tubes) and secure in place using the velcro strip sewn onto the bag. Adjust the ******** the bag to fit your shoulder, turn power on and go. To empty the bag, just unzip the bag completely. Make sure you tighten the velcro strip so the bag doesn't come off while you are sucking up leaves.
Oct 11, 2011 | RTO Weed Eater Electric Barracuda 2595...
1999 Mercury Mountaineer Mass Air Flow likely causing check engine light to come on., Where is it located?
the mass air flow sensor is inside the plastic housing that the air filter ins installed in. The housing separates with a metal band and the rear half contains the sensor. there should be 3 or 4 tabs that have to be depressed with a screwdriver to open the rear half of the housing.
May 31, 2011 | 1999 Mercury Mountaineer
Motor runs top turns but dasher does not turn
We have used White Mountain 6 quart freezers for over 20 years and have experienced this problem with 4 separate malfunctions causing it.
1. For some reason the square shaft at top of dasher does not penetrate far enough into the motor assembly. this allows the dasher to hang free while everything else seems to function properly. We learned that if you have everything ready and want to make sure the outer freezing doesn't occur, place a 3/8 inch slice of a potato over the male spindle in bottom of wooden bucket. This jacks the can up with the dasher inside and causes the shaft to go up into the motor and work.
2. Some cans had a female plate attached to the bottom on the outside to fit down over the male spindale in the wooden bucket. This plate has been known to become detached and lost allowing the can, dasher, and everything to drop down far enough to disengage the square shaft from the motor. The potato slice will usually resolve the problem.
3. A more permanant fix is to remove the male spindale from inside the bottom of the wooden bucket and place stainless steel washers under it to jack it up, and screw it back down with stainless screws.
4. Even if the entire male spindle becomes detached and lost from the bottom inside of the wooden bucket, we have found that a healthy potato slice works as a temporary fix. While the spindle is designed to keep the can centered in the wood tub, once the ice is placed around the can, it seems to stay centered and makes ice cream.
5. We think we have improved the situation on several occaisions by tightening the screws holding the wood scrapers to the metal dasher. We try to leave a little looseness in the screws--about 1/4 inch of free play. The scrapers are designed to pull out against the inside of the can as they turn and resistance to the mix occurs, but we think it is possible for them to be so loose that they get hung slightly away from the edge of the can and once freezing starts, it continues to multiply and creates a layer of insulation leaving the inside liquid.
6. At one point some of the lids were made of a very light aluminum type material. A tab on the inside of the rim of the lid was also light metal and attached in such a manner that they could become detached or distorted so that it failed to mate up with the tab inside the can. Current models have a heavy molded lid with the tab molded into it. We never had a problem with the molded lids, but practically all the light weight ones eventually failed. As the lid turns it's tab engages the tab inside the can and turns the can with the mix in it. If the tab becomes distorted or broken, the lid will turn normally and everything looks great, but the can of mix is standing still with no stirring. Therefore a film of freezing mix forms around the inside of the can.
7. Sorry about overloading you with information, but you probably can resolve your problem with one of these fixes.
Jul 18, 2010 | White Mountain F69206X 6 Quart Ice Cream...
Proceedure for removal of factory radio on '05 Mountaineer. Will replace with JVC model #KDHDR20
You will need to release the tabs on the inside of the radio. You can do this with anything about 3 inches long and the diameter of a paperclip. Insert what you are going to use in all four holes on the edges of the face of the radio to release the tabs. Next you will need to pull two 9/32" hexhead screws from the underside of the trim panel surrounding the radio. after removing the screws the trim panel will unclip with a little bit of pressure outwards and the radio will slide out. unpluge the wiring harnesses on the rear of the radio and you're good to go.
Dec 14, 2009 | 2005 Mercury Mountaineer
Need to change the brake light bulb. Behind the velcro door, where are the 2 places to pinch to pull the bulb holder?
With the velcro door open, you now have access to the tray that holds all of the tail light bulbs. There are two tabs on each side of the tray that secure it to the tail light. Carefully reach inside of the tail light and lightly squeeze on the outside of each tab, releasing the tray from the tail light. See pics.
Thanks for using Fixya and please do rate this answer.
Tabs highlighted in red.
Nov 03, 2009 | 2005 Volkswagen Jetta
Driver side sun visor will not stay in up position on my 2006 toyota rav4
I have fixed this at the mexican way, but really cheap and effective, I had same issue with my rav4 2006, and the velcro magic fix it, let me tell you that u need to obtain the one from lowe's/home depot original "velcro" strip 4"x 2" industrial strenght. stick both part separately and let them cure for 24hrs, without being together, 24hrs later, close the visor, as you normally do, that is the only way it will have the contact force enuff to keep visor up. I tried before with cheaper velcro alternatives, and did not work, hope this helps
Oct 26, 2009 | 2006 Toyota RAV4
Need to change Cabin air filter in 2006 Acura RL
Hi,welcome to fix ya. its behind the glove box . Just open the top compartment inside the glove box (button in the middle) and pull the compartment out it has velcro and plastic snaps on the back side > Then grab the compartment by the outside and push the lock tabs in and pull the tray with the cabin filter out and change the filter.31ffbbc.jpg
Feb 24, 2009 | 2005 Acura RL
Clothing Logo
1,390 people viewed this question
Top Clothing Experts
ray gallant
Da Doc
Are you a Clothing Expert? Answer questions, earn points and help others
