Question about RCA Televison & Video
My rca hdtv model number m61wh74s has no sound..no picture..power light blinks 5 times..fan comes on..i just replaced the lamp.
  • 1153 Answers
SOURCE: rca 50 dlp hd50lpw175
Yes but did you find a fuse open and changed it?
Posted on Jan 08, 2008
  • 3 Answers
SOURCE: no picture
Sounds like it could be the entire light engine.  The part is available on the Internet, but it runs $700 - $1200 without the lamp (although it sounds like you could use your existing lamp without a problem). These parts, however, are notoriously hard to find and may be backordered for months.
May not be worth the cost, but that's up to you.
welcomejee
  • 10594 Answers
SOURCE: No picture, no sound, power button blinks 47 times, then lamp flashes 134 times, then shuts off
It is symptom of weak Lamp in your TV, replace Lamp with following part number..
A1606034B LAMP BLOCK XL-2100U
It is available in Sony Accessories for $200
Always buy Sony Original Lamp for your Sony TV and avoid aftermarket/ cheap lamps.
Posted on Apr 22, 2009
welcomejee
  • 10594 Answers
SOURCE: TV powers off after 10 seconds of powering on....
Thats great, Please rate solution.
Posted on May 19, 2009
SOURCE: no picture good sound good lamp can change channel
I have the exact same TV and have had the exact same problem. I talked to a TV repairman who said it has to be my deflection board. I just found this out today so I am looking all over the web for a deflection board. I hope this helps! Tyson
Posted on Oct 07, 2009
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
Rca lamp replacement, still no picture, power light still blinks.
Ballast Board #261629 Ballast is what turns Lamp on, Also Check your Lamp Fan if it is defective Lamp will not Light!
Jun 04, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
NO PICTYURE OR SOUND LIGHGTS ON FRONT COME ON BLINK FIVE TIMES THEN GO OUT
Thats a common problem with the RCA ATC336 Power supply when the capacitors fail on the AC in power board. You can get the repair kit at the following link which will usually repair that symptom.
http://servicemanuals.vstore.ca/product_info.php/pName/rca-atc336-dlp-power-board-repair-kit/cName/repair-kits
May 23, 2009 | RCA HD61LPW175 61" Rear Projection HDTV
RCA SCENIUM HD50LPW166 worked fine, then "POP!!" has power
you lamp is bad. even if it looks good, its not firing (you're seeing the spark gap fire, indicating this). the lamp is customer replacable and roughly $200. the 5 blink error is a general shutdown error
Dec 08, 2008 | RCA HD50LPW175 50" HDTV
Dlp 50 inch
sounds like the DM3 isnt powering up the ballast to light the lamp or the ballast may be faulty. i would suggest trouble shooting the DM and ballast voltages.
May 28, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
No Picture, already replace lamp. model RCA HD50L PW62AYX6
What model set do you have. I also work as a tech at another place that probaly has your troubleshooting guide for your light engine
Jan 17, 2008 | Televison & Video
No picture
Oct 25, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
Televison & Video Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
