Question about Electric Garden
How do I remove the switch key from my homesite electric lawn mower (Model 13126)? It appears stuck in position. Can I still charge the battery with the switch key in this locked position?
SOURCE: Craftsman Lawn Tractor - Electrical
make sure you mower deck is not still engaged. that might make it not start with that safety switch.
Posted on Oct 04, 2008
  • 22 Answers
SOURCE: I have Black and decker electric lawn mower does not start
one of the problems i found with electric detectors was that they do not tell you if there is a break in the neutral cable so you could have a break there,another problem is that the levers can break inside the cover giving the impression that it should work but is not making contact with the switch ,hope this helps
Posted on Mar 30, 2009
  • 135 Answers
SOURCE: how to repair key stuck in ignition
yes the hhr has a recall on that ,take it to dealer and ask there to see if your is under that recall for that, hope to help
Posted on Jul 13, 2009
SOURCE: Murray Riding Lawn Mower won't start or move
The Drive Belt keeps coming off as soon as I engage the mower I replaced the Drive Pulley and put on a new belt but it still comes off. Any Ideas.
Posted on Aug 15, 2009
harlan301
  • 205 Answers
SOURCE: Toro Lawn Mower Electric Start Won't Engage
you'll need to pull the starter. It sound like your Bendick's is bad. that's the upper gear drive assay. the only other res ion would be, low power to the starter, and not receiving an acquit amount of amp to reach the rpm's it needs. good luck
Posted on Oct 23, 2009
Testimonial: "Thank you for the advice.... I will check out the Bendix to see if that is the problem. Jim"
Craftman 18 hp won't start with key
Check Battery. If headlight equipped turn key to headlight on position and see if headlights are lit. No light dead battery dead tractor,
Charge battery. If after charging weak or no start forget the battery and get new, Life of battery is two to three years,
If battery good make sure that parking brake set and blades are not engaged. Safety lockout will prevent tractor from cranking. The tracker has a safety interlock on the seat that requires a body warm or cold sitting on the seat if the parking brake is not set. The seat switch is known to fail. Try bouncing on the seat?
OK if battery OK and seat is sat or park brake set we can assume the safety interlock circuit is disabling the start circuit.
Need model to provide more answers
This website video shows how to check the component. Your model would be similar.
How to test lawn mower electrical safety switches
This electrical diagram is for a typical lawn tractor. Your model would be similar but different . This will give you an idea. The switch on the seat has two sets of contacts.26045611-oxnapdkevdwqbvzn03d44ye1-1-0.png
Jan 09, 2016 | Garden
With key my riding lawn mower does not start, not even crank. Nothing happened.
Are you positive that the battery is fully charged? If so check for current reaching the starter motor. If current is there then it appears that the starter motor is no good. If no current reaches motor it is possible the ignition switch is no good.
Aug 27, 2015 | Craftsman Garden
Why won't the starter motor engage?
Disconnect both ends of the wire and clean them with sandpaper. Also clean the battery (+ and -) starter and relay terminals. You may need to replace the relay.
Jul 05, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
Briggs and Stratton Troy Built 21inch 190cc 650 series Gas Powered self propelled Lawn Mower. I moved to new house and the movers lost the manual. I bought it last year so only one seasons use. How do I...
If how you described you unit is true you do not have an electric mower you have a gas powered mower, you DO NOT have a battery!!!??? Place the throttle lever to choke position and prime carb with primer bulb 3-5 times then pull cord. Wala!!!! It's running rite. That guy at Loews must have been smokin somthin. Good Luck...
Apr 22, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
Hello - I have craftsman 42 inch deck mower with a kohlar engine that does not start. Battery appears fine, when I turn it - it clicks with the head lights turning on. Ang ideas on how to get it started?...
With the key in the run position, using a jumper cable, jump from the positive post on battery to terminal on starter motor. If it runs you have a solenoid or ignition switch problem. (assuming all electrical connections are clean). If it doesn't crank the battery is the culprit.
Oct 15, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Battery drains with mower key in the off position (SCAG ZERO TURN )I changed the ignition and the positive and negitve cables. I also just rebuilt the starter.
how long does it take to drain battery,check to make sure battery is good,no bad cells,hold load after charge,check to make sure electric clutch is not staying engaged with switch off...
Oct 01, 2009 | Garden
I have a craftsman electric key start lawn mower. I used the key start twice and have charged it after each mowing, but now the key start won't turn it over.
the battery probably got over charge & shorted the cells the tractor should charge the battery as it runs if it was equiped with electric start the battery charger more than likely over charged it killing the battery
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Battery discharing light is on
Does your tractor have electric clutch ? With the switch turned off try removing positive battery cable you then try touching cable to post if you get a spark you have a short in system you could also charge battery and remove positive cable from battery over night to see if battery stays up to check battery,you also have a alternater under flywheel to charge battery you should be getting an output of about 14 volts most likely not the problem
May 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Oct 04, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
22 people viewed this question
Top Electric Garden Experts
dannydoesita
JohnPaul Robertson
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
