Question about Garden
My pear tree is 6 years old this year it has scabby leaves and have now turned black, the fruit that had grown has also gone black and scabby
  • 1153 Answers
SOURCE: hitachi 51g500 screen gone black
Yes worth repairing but not a crt problem. the crt's are powered by a high voltage transformer and sometimes it's caps that goes bad and in turn knocks out the crt's. but they are ok, it's in the high voltage line.
Posted on Aug 12, 2007
  • 67 Answers
SOURCE: air conditioner keeps tripping breaker
Every air conditioner has a motor called a compressor. The compressor provides the cooling capacity for the air conditioner. If the compressor or its electrical controls are defective the compressor may try to start, fail, and create an electrical overload. If the unit does create an overload, every compressor circuit is also equipped with an overload safety switch. The safety switch is designed to protect the compressor from burning out. The safety switch will cut the power to the compressor for a certain length of time and then reset itself. When it resets it will allow the electricity to flow to the compressor once again. If the compressor then starts, the unit should function normally. If the compressor doesn't start when the overload resets, the overload will again cut the electricity to the compressor. This cycle will continue indefinitely. (Always allow three to five minutes before restarting the compressor.) If this situation is occurring, unplug the air conditioner and get help from a qualified repair technician. This problem is often fatal to the air conditioner because the cost of repair often exceeds the price of a new air conditioner.
if this helps please vote me a fix ya
Posted on Jul 18, 2008
  • 35 Answers
SOURCE: The screeen has gone black. The TV is only 2
Check the U24 (CPU reset IC) on the "A" board. It may be burned. If you have a DVM (voltmeter) check for 3.3V across SW1 connections near this device. If you don't have 3.3V, U24 is bad. This part is not available from Sony. The TV may work if you just remove U24 from the board. I posted this fix on Agoraquest also, you can read more there (I'm "Roundabout" on that forum). Hope that helps.
Posted on Jun 25, 2010
  • 44 Answers
SOURCE: Dryer is leaving black, grease-like marks
I know, this is a common problem with side loaders. I have an old fashioned top loader myself to avoid this trouble. First check that the seals on the door haven't come loose (around the glass window). Keep the seals cleaned out regularly, so grimy, icky, muck doesn't build up inside. When the unit is not in use, leave the door opened!
This will allow unwanted moisture to escape instead of building up in the dryer, to smelly muck.
It probably smells pretty bad too.
Hopefully this will fix your problem.
If left untreated to long this can be a very hard problem to fix. However fortunately it sounds like your unit is still under warranty. If the above fixes don't work, I would seriously recommend you have your unit professionally serviced and cleaned.
Posted on Jun 30, 2010
  • 5425 Answers
SOURCE: 3 year old LG model
It's probably a backlight or backlight inverter issue if the problem occurs on all sources and the onscreen menus. (The backlight itself usually fades or makes the on-screen image change to pink/red.) With a bad backlight, you'll usually see a very dim image if you look at the monitor from an inch from the screen. Block the room light from overwhelming this image (sometimes a carefully positioned flashlight will help you see something). If the inverter or video board is bad, you will see nothing. For an out-of-warranty monitor, open up the back of the monitor and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.) The scorch mark and smoke may indicate a resistor or zener diode that had been used as a fuse and is now gone.
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the inverter board and power up the monitor. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most monitors). These are sandwiched on the perimeter of the monitor (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your monitor size. Separate the panel from the bezel. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. See http://www.lcdparts.net/howto/default.aspx for more information but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx. Then push the new backlights into place, reconnect the wires and close up the sandwich of tape and other parts around the screen. Then replace it in the bezel.
With a good spare backlight, you can test an inverter for condition (plug together and turn on the monitor while the box is open). Similarly a good inverter can test the backlight.
I hope this helps.
Posted on Feb 22, 2011
What causes fuzzy orange berries on my aristocrat pear trees?
Hello, Richard -
The Aristocrat pear tree is an ornamental pear tree. The "fuzzy orange berries" on your tree are the fruit, which are edible by birds, but not humans..
You can read a bit more about Aristocrat pear trees here:
https://www.gardeningknowhow.com/ornamental/trees/ornamental-pear/growing-aristocrat-flowering-pears.htm
and here:
http://www.wisegeek.com/what-is-an-aristocrat-pear.htm
Best wishes.
May 21, 2018 | Garden
Leaf curl on my Meyer lemon
Generally Meyer Lemon Trees need water every one to two weeks. ... If the leaves are drooping like they're too heavy for the branches, and turning dark brown or black the tree is getting too much water. If the leaves are crispy and dry or curl upwards this is a sign of under watering.
Meyer Lemon Trees: 7 Secrets for Loads of Fruit ' Fast-growing-Trees ...
Citrus Leaves Are Curling - What Causes Citrus Leaf Curl
https://www.gardeningknowhow.com/edible/fruits/citrus/curling-citrus-leaves.htm
Dec 29, 2015 - As far as fruit trees go, citrus tend to be the low-fuss member of the team; but when curling citrus leaves appear, you'll need to intervene. This article will help that. Click here for more info. ‎Citrus Fruit Brown Rot · ‎What Is Horticultural Soap · ‎What Are Psyllids: Tips On ...
Leaf Curl - Four Winds Citrus Problem Solver - Four Winds Growers
https://www.fourwindsgrowers.com/solving-common-problems/leaf-curl.html If the leaves on your dwarf citrus are curling, there are three common possibilities: Some insect pests will cause some leaf curl. In spring, aphids might do this on soft new leaves. ... Overwatering can cause leaves to curl or cup INWARD.
Why Are the Leaves on My Meyer Lemon Tree Curling? ' Hunker
https://www.hunker.com > ... > Garden & Lawn > Pests, Weeds & Problems May 6, 2010 - Pests. A number of insects can cause leaf curl in Meyer lemons. The most common and likely is the everyday whitefly, but aphids, citrus leaf miners, and mites are also common culprits. Insects are a larger challenge to manage than over-watering.
Meyer lemon Leaf curl Google Search
Jan 29, 2018 | Garden
My bradford pear tree has those black spots on many of the leaves.....some type of fungus....should I have the tree sprayed yet this year?
Yes that is likely a fungus. You can get do-it-yourself sprays, or have it done. They might also suggest that you pull all leaves that are affected and dispose of them in order to stop it from recurring or spreading.
Sep 21, 2017 | Miscellaneous
What is the best plant to graft fruit trees to
Another fruit tree. Apples grow well on pear trees.
Aug 01, 2017 | Garden
Why is my pear tree leafs curling inward
A common pest of pears, leaf midges are tiny black grubs that cause the edges of the leaves to roll upward. Young foliage is more likely to be attacked than older leaves. The affected leaves may turn red and drop. Control is difficult, as the grubs are protected from spray by the curl. Any affected leaves should be picked off and burnt.
Apr 08, 2017 | Garden
Peaches with black spots and leaves that have a Lacey look to them.what can I do about it?
The tree may have "bacterial spot", but "Captan" fungicide can also cause the same symptoms. You should probably get help from a professional on this one, especially if other peach trees are anywhere nearby - bacterial spot is contagious from tree to tree, and can ruin whole orchards in a short time.
A professional may be able to apply a copper compound spray until nearly leaf-drop time, then switch to an antibacterial spray. The fruit from that year should not be eaten, but if the problem is mitigated, the fruit from subsequent years can be eaten again.
Aug 10, 2014 | Washing Machines
The leaves on my apple and pear trees are going curly and tuning black the trees are only young and were planted last autumn
Fruit trees need adequate water - especially if young and in spring and summer. They may also be susceptible to bugs or disease. You can take a leaf to your local nursery for specific advice.
Jun 07, 2014 | Garden
Citrus tree diseases
It could take up to 7 years in some climates to fruit. It's self pollenating but likes a Ph level of 6 to 7.5. Get a soil Ph tester & check your soils Ph levels and maybe fertilize it with a fruit tree fertilizer. That's the best I can tell ya. Hope it helps
Nov 02, 2013 | Pool & Spa
Our navel orange tree froze up last winter,,we cut back as much as we could,,this summer got like 10 oranges,,and tree looks awful,,hardly no leaves,,should we cut it back more? is there a life span of...
I would cut it down and burn it, after a freeze trees go to bearing a sour fruit that only a pig would eat. it sounds like your tree might need to be replaced. sorry
Sep 10, 2013 | Pool & Spa
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
