On the timer it says E 25 and will not wash. - Washing Machines
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
HI I HAVE A GREAT ILIVE INTERGRATED DISH WASHER, BUT NO MATTER WHAT SETTING I PUT IT ON TO WASH IT WASHES FOR 88 MINS, IT DID NOT COME WITH A BOOK AS IT WAS LAST ONE ON SALE CAN YOU HELP WHAT DO I HAVE TO...
Is your display faulty?
Does the timer count down?
Does the run time of the dishwasher change even though 88mins is displayed?
if all else fails run the dishwasher from a plug in timer, turning it off after 25 mins :-0
Dec 17, 2010 | Dishwashers
My ge nautilus kept stopping during wash and now will not start at all.
This is quite likely the timer or the cam. It can be replaced. Since they use a mechanical timer it can simply be off track. If you aren't afraid of disassembly I would take the timer panel apart and have a look. You may be able to fix it quite easily. Otherwise the timer is about $50. The cam is only $15.
Jan 09, 2010 | GE 25 in. Nautilus GSC3400J Free-standing...
Everything works...cam timer moves drain opens but wash motor does not turn on
could possibly be a bad micro switch, a bad contactor or even a bad capacaitor on the motor
Dec 22, 2009 | Jackson 25 in. Conserver XL Free-standing...
Washer stops during rinse cycle and isn't easily restartable....
Sounds like the contacts in the timer has a problem. Unplug washer. Remove the back of the washer and spray WD40 in the timer. Put towels around and under to to collect excess runoff.
Rrotate washer dial 25 times and spray some more wd40. Rotate 25 times again. Do a wash load. If it works put everting back together.
May 04, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Sensing light comes on and then the timer stop going down
I do nto have a solution- just the exact same problem. My machine gets stuck on 76 when doing a "normal wash" . last night I hit cancel and drain, then went to "time saver" and ran the wash and it seemed to work fine. Funny that both of our amchines stop at 76. Any ideas?
Nov 18, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
When doing quick wash "25 minutes" why does it take an hour?
one think comes to mind if you have extra rinse selected un select it all preset cycle times arent based on extra rinse
Sep 05, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
