Question about Measuring Tools & Sensors
Bunker hill driveway alarm quit..replaced batteries and it will not reset and red light on inside unit stays on
I changed batteries on outside unit too
  • 3 Answers
SOURCE: bunker hill safe
i had the same problem this is what i did. i took the lil leg off the bottem it held on by a srew take a cloths hanger put it in the hole and now u can hit the lil button that is for makin a new code it is on the hing side of the door the yellow light will come on and stay on now put ur new code in then hit a or b i used 1111a then changed it once i got in o by the way ''the factory code is 159a try this first" and the cloths hanger i shoved a ear plug on the end of it so that way it could grip the button hope this helps somebody
Posted on Nov 29, 2008
  • 3 Answers
SOURCE: Changing Combination of Bunker Hill digital floor safe
there is a button on the inside of the safe. press it and enter new combination on keypad. Easy enough
Posted on Aug 19, 2009
jyackle5
  • 8197 Answers
SOURCE: I own a Bunker Hill digital floor safe sku #need code change data
To change the code: Your safe comes
preset with the default code of “159-A”.
To change the code, first open the safe.
On the inside of the door near the hinge,
there is a small red “reset” button. Press
this button until the Yellow LED on the
front panel lights up. Now, input your new
code up to 8 characters, followed by
either “A” or “B”. The Yellow LED will flash
to indicate that your new code has been
accepted. Warning: If the Yellow LED
does not flash, the code has not been
accepted, and you must start over.
NOTE: Be sure to test your new
combination before closing the door.
NOTE: Be sure to have the Override Key
available when setting a new
combination or changing batteries, in
case the door doesn’t open.
Good Luck
Posted on Nov 15, 2009
SOURCE: have a bunker hill safe. battery died. lost
Remove the sticker on the front panel with the SKU number, behind it will be a small hole, use a small screwdriver to remove the screw, then carefully remove the number pad. You will see the place to use your key.
Posted on Dec 25, 2010
sbmg1
  • 3 Answers
SOURCE: bunker hill digital safe
CHANGING CODE ON MODEL # 45891:
On the inside of the door toward the hinge, you will see a small red button. Press this button until the yellow light on the front control panel lights up. Now you can imput the new code (1 to 8 digits) into the front control panel, followed by either the "A" or "B" key. The safe will beep twice (2 times) to confirm the code has been changed. Important: If the safe beeps 3 times, then the code has not been accepted and you must repeat the above steps.
DO NOT LET THE BATTERIES RUN OUT BECAUSE YOU WILL NOT BE ABLE TO OPEN THE SAFE OR CHANGE BATTERIES.
Posted on Aug 30, 2012
Bunker Hill security 8-Channel Surveillance DVR item#61229 keeps rebooting itself. "system initializing"
Rotorway Bunker Hill never lasts and it's the cheapest one with the worst resolution you just don't want to operate and put your life on the line with this unit
Jan 18, 2016 | Home Security
I have a chamberlain driveway alarm,changed the battery and will not sound off inside ,,,,it will flash at the driveway
May be reception problem. Move receiver to window facing where the outside sensor is mounted and see if it works then. Ultimate test, move receiver outside and have someone drive past sensor. If it doesn't work then, receiver may be dead. If there are more than one receive channel on the receiver, make sure outdoor sensor and receiver are set to the same channel number.
Jun 15, 2015 | Chamberlain Wireless Driveway Alarm Alert...
Do you have to change batteries on clock inside house along with outside batteries to get correct outside temperature
My most consistent (best, repeatable) results with this process are to replace both sets of batteries, both in the clock and in the outside temperature sensing unit. Start by removing all batteries out of everything. Now replace the batteries in the outdoor unit, then (within 30 seconds) replace the clock batteries. The temp unit should begin communicating normally within 5 minutes (or less) and yes, you will have to reset the clock,
Nov 01, 2014 | Lacrosse La Crosse Technology Wt-5220u-it...
Was wondering if there is a way to mute the chime on Bunker Hill Driveway Alert System
No, you can't turn off the sound, but you can make it higher and lower, using the switch on the left side of the Receiver
Product Manual
Oct 04, 2012 | Alert Wireless Alarm Alert System Motion...
Good Luck
Nov 15, 2009 | Sentry Fireproof Safe
I have a model 45891 Bunker Digital Safe. Battery
how do i change combination on bunker hill 45891 safe, i have tried every way i can think of.
Oct 05, 2009 | Check Point Network Adapter
Aug 06, 2009 | Check Point Network Adapter
I have a bunker hill safe digital, and battery is too low to open the safe and cant find my key, probably inside, any suggestions
If you have the small electronic Bunker Hill safe with lost keys and dead batteries, this is a potential solution... Take a hammer and strike the top of the safe while attempting to open at the same time. You may need to place on object on top of the safe such as a flip flop shoe to strike with hammer to smooth out the pressure when striking. It should pop open after several attempts.
Jan 25, 2009 | Check Point Network Adapter
Bunker hill digital safe
Dec 19, 2008 | Check Point Network Adapter
Bunker hill safe
Sep 20, 2008 | Check Point Network Adapter
Measuring Tools & Sensors Logo
32 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
