Question about Frigidaire Refrigerators
I have code the sycf on my frigidaire refrigerator
2 Suggested Answers
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Model LGHC2342LE1 Frigidaire refrigerator fault code SYCF. What does it mean?
    It is a communication failure. Check wiring between MainControl Board and User Interface Board. Replace User Interface Board. Ifproblem still exist, replace Main Control Board.
    Posted on Jul 30, 2012
    How to fix error code H1
    Frigidaire Refrigerator Error Code = SY CE
    Condition = Communications error at power up
    Repair or Check = Check wiring between control board and user interface
    Parts Needed = Control board or User interface
    Frigidaire Refrigerator Error Code = 4
    Condition = Fridge and the control board goes through cycles but does not detect a damper connection
    Repair or Check = Check air damper
    Parts Needed = Air damper
    Frigidaire Refrigerator Error Code = 5Y EF
    Condition = Evaporator fan circuit failure
    Repair or Check = Check wiring between evaporator fan and control board
    Parts Needed = Evaporator fan or control board
    Frigidaire Refrigerator Error Code = EF
    Frigidaire Refrigerator Error Code = dF
    Condition = No defrost circuit
    Repair or Check = Check wiring between defrost circuit and control board
    Parts Needed = Main control board or Wiring harness
    Frigidaire Refrigerator Error Code = H1
    Condition = Freezer sensor shorted in freezer display
    Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
    Parts Needed = Thermistor (temp sensor)
    Frigidaire Refrigerator Error Code = 5y CF
    Condition = Communications failure at power up
    Parts Needed = Control board or user interface
    Sep 28, 2016 | Refrigerators
    Why does the fridge side of my fridgidare side by side keep flashing on 4
    FFHS2622MB3 FRIGIDAIRE REFRIGERATOR Manual ...
    www.searspartsdirect.com > Kitchen Appliance Parts > Frigidaire Parts
    Download Manual for Model FFHS2622MB3 FRIGIDAIRE REFRIGERATOR. ... ShopFor Parts. Click a model number to find parts at Sears PartsDirect.
    Jul 28, 2015 | Frigidaire Refrigerators
    How do I fix code SYCF on my Frigidaire refrigerator
    You didn't give the model number to identify what the code means, so I'll assume the problem is related to the white wire or cable.
    Unplug the refrigerator, remove the ice bin and investigate where the cable came from. It should not be hanging down in the ice bin. If there is a connector on it, find where it plugs in. Perhaps it goes behind a panel in the wall of the ice bin compartment, and was sticking out where it could get snagged (assembly error). If the cable is damaged (e. g., a short length of bare wire on the end where it was pulled apart or cracked or abraded insulation), or there is no connector on it, contact Frigidaire and arrange for a warranty repair. If it is out of warranty, insist they do something about it anyway - cables are not supposed to be exposed to damage in customer-accessible sections of the refrigerator. (If the refrigerator was previously serviced, your complaint is probably with the firm that did the service.)
    If you can find where the cable goes and how it's supposed to be routed, just clean and dry it and plug it in. That would be simpler than arguing about an out-of-warranty defect issue.
    Feb 11, 2015 | Frigidaire Refrigerators
    My frigidaire refrigerator reading cf and water and ice maker do not work.
    Good Morning jesse, I appreciate your post!
    I see that your Frigidaire refrigerator is displaying an error code of "CF". Normally, "CF" stands for communication failure upon start up. I would recommend performing a reset on your refrigerator and you can do that by disconnecting power from it for ten minutes. If you continue to experience this error code it could be a possible problem with your user interface board or main control panel and I would suggest contacting a technician for proper diagnosis and repair. I hope this information is helpful. -Matt
    Nov 23, 2014 | Frigidaire Refrigerators
    What does the error code 5y EF mean on my Frigidaire refrigerator
    Good Morning Friend,
    I understand you are receiving an "SY EF" code on your Frigidaire refrigerator, model# FRS3R5EMB. The "SY EF" code stands for system error with the evaporator fan. This possibly means that there is something going on with your evaporator fan or it could possibly be a false error code. . I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
    Jun 21, 2014 | Frigidaire FRS3R5EMB Side by Side...
    What is error code 1 on a Frigidaire FFHS 2622 MBE?
    Good Afternoon Laura,
    I see that you are inquiring as to what an error code 1 is on your Frigidaire refrigerator, model# FFHS2622MBE. Error code 1 could possibly have something to do with the software that controls your refrigerator. I suggest resetting your appliance by either unplugging it or shutting the power off at your home's circuit breaker for 2-3 minutes. Restore power to your refrigerator, and if you are still receiving an error code 1, I suggest contacting your local authorized technician. They will be able to diagnose your appliance and determine what is going on with your refrigerator. Hope this helps.
    -Best Regards-
    WP
    Apr 28, 2014 | Frigidaire FSC23F7DSB Stainless Steel Side...
    SYCF Error Code
    This was posted previously by someone else here:
    http://www.fixya.com/support/t13794980-model_lghc2342le1_frigidaire
    Jan 10, 2014 | Frigidaire Refrigerators
    Jul 28, 2012 | Frigidaire Refrigerators
    Frigidaire side by side error code 4
    I have Fridaire refrigerator model PLHS67EGSB5 and have electronic control flashing code 4 at the right side (Refrigerator side) . What that means and how can solve it.
    Thanks, Anibal
    Oct 30, 2008 | Frigidaire FSC23F7DSB Stainless Steel Side...
    Refrigerators Logo
    16 people viewed this question
    Top Frigidaire Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
