Question about LG Washing Machines
LG front loader Will wash not spin and makes a funny noise
  • LG Master
  • 2,252 Answers
Any error codes? Model no.?
Posted on May 21, 2017
BIKER T
  • 909 Answers
SOURCE: LG Washing machine - Front Loader
simply look at manual and see what SE represents. if not available i suggest you phone nearest lg branch and ask for service dept. enquire what SE STANDS FOR THEN RECTIFY PROBLEM.
Posted on Sep 21, 2007
SOURCE: Clunking during spin
I had the same problem.It turned out that the pump was clogged with coins and the pump was working way to hard to suck the water out with all those coins plugging up the pump causing the clunking sound and vibration during the spin cycles
Posted on Feb 02, 2008
SOURCE: Washer LG Model WD-8013F Noisy & vibrates badfly when spinning
I had same problem, the bowl is supported by (2) large springs from the top & two telescoping shock absorbers underneath.
I inverted the machine, found a large hollow retaining plastic bolt had falled out of the shock absorber,causing the bowl to be out of balance & the drive belt to be missaligned.
I reinstated the plastic retaining pin/bolt then tried the machine again.
Now the damn thing refuses to wash or spin.
I'm not happy.
Posted on Nov 06, 2008
SOURCE: LG WD-8050FH LOUD noice when spinning & 'funny' burning smell!!
I had the same symptoms and almost dismantled the whole machine to locate the root of the cause. The issue was one of the 3 arms of the spider (like a 3 spoked wheel that connects to the rear of the drum and holds it in place and provides the drive shaft to through to the motor at the rear), had snapped after weakening from corrosion due to undissolved washing powder building up in the grooves.
To prevent this, do a hot wash every few weeks to dissolve the powder, don't think your saving the environment by using only cold washes, this should be in every washing machine manual to save the environment from waste from un-economically repairable appliances.
The burning smell was the unbalanced drum leaning heavily on the rubber shroud on the front between the drum and the outer casing. The replacement spider part was only about AU$60-80.
To check if this is the problem you may be able to tell by opening the door, and reaching in from the front with your palm up about a hand distance till you go past the rubber shroud and just touch the stainless steel drum. Grip it gently with your four fingers and pull towards the front (to you) about 1cm or two, with about as much force you would need to open the machine's door. Rotate the drum approx one third of a rotation and repeat, do this 3 times and you should feel one point give more than the others.
If no luck try again in sixths of a rotation, you can gauge the distance by the 3 plastic agitators attached on the inside wall of the drum.
Note: get a price on labour first to replace the spider, as this will be probably more than half way to a new machine, and then the cost of the part, and the call-out fee if you can't get it into a service centre.
What's the point of having a long lasting stainless steel drum when the key part that connects the drum to the motor is a weak cast iron / alloy part.
Ask your local service person what units have quality parts before buying a new machine.
ps: the loud noise is probably the cracked arm rubbing or the unbalanced drum hitting the sides and making the machine jump.
Hope this all helps!
Posted on Apr 06, 2010
SOURCE: lg-wm1832cw front loader washer won't spin and drain
did anyone solve this problem? Mine is doing the same thing... uggh!
Posted on Aug 03, 2010
When I Fill my washing machine (Top loader Lg Wf-T7015tp), it Makes a Funny Noise and die when I start the program.Is it the Capasitor or is it the v-belt tension?
If the noise is only when this function of filling, and if you are only using one of the two fill valves, may be due to the magnets of the inlet valves of the water, which are activated in filling and are disabled when you start the program. that noise is normal unless it is very strong and is the preamble to the damage of the two valves.
Nov 10, 2014 | LG Washing Machines
Front loader machine stuck before spin cycle
This is an issue with the pressure switch, it is having issues detecting the water level.
Mar 11, 2012 | LG Washing Machines
Front loader excessive vibration and walks.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
May 31, 2011 | LG WM2301HW Front Load Washer
Lg-wm1832cw front loader washer won't spin and drain
Apr 12, 2010 | LG WM-1832C Front Load Washer
Front loader is making funny noises. It was
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
May 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front loader problems
call repair before warranty runs out...possible door switch if it's a loud humming noise ..try pressing in on door latch side to see it hum changes
Sep 06, 2008 | Frigidaire GLTF2940ES Front Load Washer
LOCK AND LOAD ISSUE
can you be more specific about the funny noise. When does it occur, during agitation or during spin? something might me stuck in the drain area of the tub and as the tub rotates it rubs against it.
Jun 28, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
20 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
