Question about Samsung Televison & Video
Samsung UN60EH6003FXZA has no picture and no sound. Everything I read says for no picture to replace the T-Con board, but with also having no sound is this a different issue?
TV powers on and I have back panel lights. Just cant see anything no matter what I press and also cant hear anything.
  • 8457 Answers
SOURCE: No sound/picture and red power light always on (Hitachi 43FDX15B)
When u turn the tv on,u hear alot of clicking?That mean the Ballast that help the projection bulb to work is dead.Change the Ballast,might as well change the bulb too.U don't know what is the condition of the projection bulb in.
Posted on May 29, 2010
  • 2432 Answers
SOURCE: Samsung TV goes Black but keeps sound
you will need to check weather the 24vdc supply for the inverter board is good no drop voltage. if no supply check the power supply board. then you should check if their is a inv_on signal at the power inverter board around 3v-4.4vdc . if goes out during power on tried to disconnect the supply going to the inverter board to ensure if their is a shorted parts in the inverter board. if the inverter_on signal also goes out even with out inverter board connected that was mean you have problem in the processor board.
Posted on Nov 02, 2012
  • 373 Answers
SOURCE: have a 39lb5600 lg that power on n then back off have light in back panel but screen is black.have sound
The TV you have uses LED backlighting, and it is unlikely that they have failed. It is more likely that it is not receiving power. Check to ensure that all your internal wiring connectors are properly connected and seated.
Posted on Dec 08, 2014
  • 61 Answers
SOURCE: Why did it work before installation, now flashes numerous different colors?
Before installing replacement parts???
I can assume that the t-con board or the video board had terminal connectors or ribbon connectors. What is often overlooked is a misaligned connector or worse, a broken or bent pin. Try examining these connection points. You may have to use a magnifying glass. A defective screen usually goes black or produces broken images and/or color points.
I hope this helps.
Posted on May 30, 2015
Testimonial: "No I meant I had the tv lying on the ground and it was working, but when I hung it on the wall the picture went and the sound started crackling. I don't know why the moderation team changed my title."
  • 10045 Answers
SOURCE: Jimmy shop.ccom has T-con board part #T500HVD0.0 500t10-C02 at the bottom in the description it list model PLDED5030A CRk my model is PLDED5066A-E since the parts # the same will it work in my tv?
If you see an image with a flashlight the T con board and power supply board are good. The back light controller board is the culprit.
Posted on Dec 18, 2015
Picture went out on 2-year-old Samsung TV model UN50EH5000F. I have sound and full backlight but no video.
You have replaced everything that could have gone wrong - except for the video Screen itself. Check the connections (ribbon) to the screen for oxidation - use eraser to clean.
Jun 20, 2017 | Samsung Televison & Video
I have No Picture on a Samsung Model UN60EH6003FXZA HH01 TV.
TCON board or the LCD panel is faulty. Can confirm by replacing the TCON board. In some models TCON board is integrated to the panel, In such cases you have to replace the panel.
If you wish to get some details; visit the site linked here. Pull up older posts.
Feb 07, 2017 | Samsung Televison & Video
Samsung TV, UN60EH6003FXZA, Black screen, has audio. Replaced t-con board and TV worked fine for 5 minutes, then black wave came across screen. Can replace main board, is the new t-con board ruined?
If the new T'Con too have damaged, surely its main power supply regulator board is faulty. Over voltage to T'Con board. Replace it and the T'Con board. Never switch on the set, without proper fittings to T'Con board. Its protective cover should be fitted before you switch On the set. It acts as a shield as well as a heat-sink to the IC at the T'Con. If you switch On without properly fitted, the IC will overheat within minutes and will be damaged. Keep this in mind next time.
Oct 26, 2016 | Samsung Televison & Video
Samsung TV
If you see a picture with the flashlight you can rule out the T-Con board. It's working. So the led driver board is the problem. TV Parts Universal TV Stands DLP Chips ShopJimmy Go here for replacement parts.
Aug 07, 2016 | Samsung Televison & Video
I have a Samsung TV model UN50H6350AFXZA which has sound but no picture. Backlights work. Replaced t-con board with new one, but not fixed. What next?
Main board. T con board is only involved with video issues. Main board goes both ways and since you already replaced the T con board that is your only alternative. U got backlite so inverter board is good.
Nov 13, 2015 | Samsung Televison & Video
Vertical colored lines on entire screen, sound ok
Probably the t con board of your TV is faulty. T con board is the one which drive the lcd pixels. You have to replace the T con board to get it work properly.
Here i have added the picture of the T con board of your tv for reference.also added the video to know how to replace the T con broad.
RCA L32WD22 T-CON BOARD UT-5531T03088-76J
Samsung TV Repair How to Replace Con Board in LJ94 02 705E Model How to...
Sep 09, 2015 | RCA L32WD22 32 in. LCD HDTV
Samsung 50in Plasma tv picture issues.
buffer board needs replaced need to replace both
Feb 04, 2010 | Samsung PN-50A450P Plasma TV
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
