At power-on, light in record button blinks for a few seconds, then all goes off/dead.
Slinteriors
  • 8617 Answers
SOURCE: Powers off
do you hear any sounds what so ever? Clicks or anything when you press power.
Posted on Jun 06, 2008
  • 848 Answers
SOURCE: red light blinking on power
this all problem may exist in your tv
1. High voltage problem/ deflection circuit problem.
2. Shorted picture tubes.
3. Problem in the vertical deflection circuit.
4. Problem in the audio ouput circuit.
5. Problem in the convergence circuit.
6. Problem in the power supply regulation.
7. Problem in the portect circuit.
8. The common high voltage arcing that Toshiba sets do at the picture tube.
so for getting pictures gently tap on the side of tv if it works then there may be some loose connection you can fix it by soldering
Posted on Jun 22, 2008
  • 23 Answers
SOURCE: 4 blinking red lights in power/standby
I would recommend replacing the fan, cleaning it doesn't solve the problem...If it does, it's only a temporary fix. Replacement fan is around $30 and easy enough to do yourself...
Posted on Oct 01, 2008
freetek
  • 5568 Answers
SOURCE: Lamp light blinking, Power Light blinking, TV off
Your description of the problem points to a power supply in the process of failing.
If it was mine, I would leave the set unplugged overnight, remove the back panel of the set, locate the power supply (likely on a separate board related to the incoming AC cable and will have larger components on it), look for an assembly number (often on a printed label), contact the manufacturer's service company and inquire about replacement or repair cost.
When you plug it back in, note whether it behaves normally at first turn-on. If is does, this tends to support the suspicion of a failing power supply since some of the passive components in it have had a chance to recover before weakening again.
Modern supplies are a good bit more efficient than 'linear' supplies of yore but are far more complex and much more dependent on quality of components.
Posted on Jul 28, 2009
dsacco86
  • 1077 Answers
SOURCE: Set will not power on.. Blinks red LED 8 times
It's a power supply related problem.
The flashing 8 times is a trouble code. A Service Manual for your TV model will have the info on the codes. It could be a bad capacitor or a transformer on the power supply board.If you have some electronic experience, you can find a Service Manual for your TV over the internet. Cost about under $20.
Posted on Jul 31, 2009
Blinking light on laptop?
From Hp the blinking light indicates sleeping mode. Suggest you push the power button for 20 to 30 seconds. The light should go out. Repower on the computer. If it goes back to blinking mode then there is a hardware issue.
Aug 27, 2014 | HEWLETT-PACKARD HP ProBook 6550b Notebook
WHAT IS WRONG WITH MITSUBISHI TV MODEL WS65819 THAT POPS ON AND OFF?
shutdown is happening= If set has been unplugged plug it back in and turn set on--when green power light goes off in a few seconds:
On front of set (not the remote) press and hold both the Menu and Input (Device) buttons at same time and hold for at least 5 seconds---then release both.
Power light will blink an error code like 2 blinks, 2 blinks pause and repeat it for a total of 5 times.
Let me know what error code is and I will tell you what it means.
SD TECH
Apr 26, 2012 | Mitsubishi WS-65819 TV
Kdl-40w3000, when power button pushed, tv comes on for a few seconds then shuts off then standby blinking light comes on 13 blinks, pause,13 blinks pause, etc
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where, if otherwise,
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this will to fix the fault......
May 29, 2011 | Sony BRAVIA KDL-40W3000 40 in. LCD HDTV
Tv automatically powers off by itself within seconds.
This model has a self check: with the set plugged in turn it on--green power light comes on and a few seconds later goes off.
On front of set press and hold BOTH the menu and input buttons at the same time for at least 5 seconds and release both buttons.
Power light will blink a 2 digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Apr 11, 2011 | Mitsubishi WS-65809 65" Rear Projection...
I have no power, i called a repair man, he said unplug it then push the reset button...i get a blinking green light for a few seconds...now what?
The set if it has a DM unit when unplugged should blink for 70 seconds and allow you to turn on.
If it does not, if when you try to turn on green light comes on and goes off---do the self check:
Press and hold both the menu and input buttons for 5 seconds and release both; power light should blink a two digit error code at least 5 times. 2 blinks, pause and 2 blinks is the most common.
If the set has a reset button on the front it has a DM unit---built in receiver--even if it fails the green power light will blink nonstop.
Again, if you try to turn on and green power light comes on and then goes off---do the self check and let me know what you find.
If this information was helpful rate this solution as "very helpful" as I do this here for free.
Also let me know what you do or do not find as I am here to help you.
REGARDS, SD TECH
Aug 11, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Flip Hd stopped working. USB light blinking, but red light not on. Cannot start, record seems "dead". How do I restart?
Im guessing press the reset button the bottom, with a paperclip and hold it for 3-5 seconds and try it again, it night take a few trys but it has worked for me a few times... worth a shot ?
Dec 25, 2009 | Pure Digital Flip Mino Digital Camera
Our tv comes on and then the picture goes dead
WS-65807 has a self check feature. If the power light comes on and goes out after a few seconds engage the self check:
On the front of the set press and hold BOTH the Menu and Input(or Device) buttons at the same time and hold them for at least 5 seconds and then release both buttons.
The power light should then blink a two digit error code--the most common is 2 blinks, a pause and 2 blinks--this is the most easy to fix. The set will repeat the error code several times.....
Let me know what error code you find and I will tell you what it means and what may be wrong.
If this information has helped you rate this solution as I do this here for FREE.
SD TECH
Nov 29, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
