Question about Samsung Refrigerators
Samsung refrigerator RF4287hawp - water in middle drawer and ice under the drawer
  • 112 Answers
SOURCE: ice acculation under crisper drawers
No. There is, however, a drain hole in the back center that tends to get plugged. Remove the lower two drawers and see if it is plugged. It drains to a pan under the unitand behind the kickpanel
Posted on Oct 18, 2008
  • 82 Answers
SOURCE: Refrigerator has water under the crisper drawers
There is most likely a plugged drain in the freezer section. The easist solution can be to empty the refrigerator and unplug it over night. If this is not possible then the back or bottom should be removed to allow access to the drain and a hair dryer can be used to make defrosting go faster. still takes a while, if there is access in the back of the unit that can be the cause of the plug.
Posted on Jun 19, 2009
SOURCE: samsung refrigerator freezer not freezing
I just returned the same fridge to Lowe's where I bought it using the warranty for the same problem. The temperature sensors went out, and everyone said the computer board needed to be replaced but no one could seem to get it together enough to order us one. Month later we are getting a new fridge.
Posted on Jul 28, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: My Kenmore Elite bottom freezer
rewrwer
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
Here is a list of some things that can go wrong.
In addition, your drain tube maybe clogged
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Posted on Dec 27, 2010
  • 66 Answers
SOURCE: Water Leaking From Under LG LRFD21855 Refrigerator
yep, it looks like a frozen drain pipe. to solve it , defrost your frig for 24 hours. if that doesn't help, see the following page for details how to fix it. http://www.schneordesign.com/Avi/LG/LG819_fix.htm good luck Avi
Posted on Jan 21, 2011
Water is collecting under the deli draw of my french door samsung refrdgerator
Is this the Samsung 4-door fridge/freezer with a round water-filter between the two drawers in the Refrigerator? a) Is your water-filter correctly installed in it's place? b) check where the water-drops are coming from: it could be the ice-maker - need to call Samsung service.
Sep 28, 2014 | Samsung Refrigerators
I have samsung french door refrigerator 2 door 2 drawer with vibrating a noise. I have removed the back panel and the noise does not seem to be cominng from this area. any suggestions.
We have a different model Samsung, and I've heard a vibrating or buzzing noise twice. First, if the water filter isn't an exact fit (even Samsung's filters rattle), it will rattle. Second, if either of the ice makers gets stuck or jammed, it can make a vibrating noise. If our freezer drawer isn't making a good seal, ice will build up under the drawer or in the slides. Ours makes more of a humming noise, when this happens. Other areas to check: something stuck in the runner of your drawers or shelves (if yours pull out). There are also vents that draw air in and out of the cooling unit, and things in front of them may vibrate or rattle, too.
Jul 19, 2014 | Samsung RF265AA Bottom Freezer French Door...
Water under produce section
In addition to water under the crisper drawers, you might be getting water in the drawers too, look for any ice/frost in any of the air vent holes just above the drawers on the rear fan cover. This unit was made by Samsung for GE, these are notorious for this issue as the defrost drain tube wick heater is not long enough to work. You will need to turn the unit off for 24 hours, unplugged, doors open to ensure it's completely thawed both behind the cover and drain tube. Part# WR13X10573 (cover assembly complete) gets replaced, and part# 819043 will need to take the place of the existing Samsung one. Pleazer Appliance...
Apr 08, 2014 | GE Profile Pfsf6pkw 25.8 Cu. Ft....
Samsung rf265 series french door with freezer drawer on the bottom: Water collects under the veg drawers in the refrigerator part. What might be wrong?
I have the same problem!!! We need a class action lawsuit against Samsung for this problem on their French Door fridge. Instead of fixing it they want the consumer to pay for repair. NO MORE SAMSUNG PRODUCTS FOR ME!!!!!
Sep 04, 2011 | Samsung RF265AA Bottom Freezer French Door...
Water under vegetable drawers
Look on the top back of ur fridge. in the middle of it u should see a resetacaple. if it is full of water and over flowing there is ur problem. then u have to check about ur cooling unith if not change the setting of u fridge let the frizzer frezze and the fridge stay a bit warmer
Nov 19, 2009 | Bosch KGU32124 Bottom Freezer Refrigerator
Small amount of water leaks from the front of my Samsung R2630SH.
I found out that there is a plastic panel that cools three draws inside the refrigerator. Behind the plastic panel there is an evaporator (coolant childer) that catches the condensation of repeatedly opening and closing the refrigerator door that turns into thick ice. Because of condensation, ice buildup in such a way that the ice pushes the middle draw out causing the door to open. In turn depending on how long the door stays open, melts the ice and the water leaks under the bottom draw out on either side of the front refrigerator door. Also, there is a drain plug that is also iced closed. To solve that problems, the unplug the refrig, put towel under the refrig, removed the panel (unplugging the wires and removing screws) and took a hair blow dryer to melt the ice. Oh, by the way, I used to blow dryer to melt the ice from the panel before I could remove the panel. That job took all day. I removed all the ice and reassembled the panel and replace the drawers. To my amazing, no more leaks and the water dispenser worked for two days and quit. I believed the water tank (plastic container in front of the panel has frooze again. By the way the ice maker did not work after removing the ice.
Aug 16, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung RFG297AA Thin Film of Ice Forming Under Deli Drawer
My be an air leak,wipe/check all seals on doors and make sure doors are closing tight on seals.
Jul 24, 2017 | Samsung RF265AA Bottom Freezer French Door...
Samsung RS253BASB leak at bottom veggie drawer
I had the same problem. I called tech support and they were no help. Being a handy man I dove into the problem myself and discovered the problem. If you want this solution, I have pictures and information. Simply email patmcclain@charter.net and I will send you this infomation.
Jun 07, 2008 | Frigidaire FRT15G4B Top Freezer...
Refrigerators Logo
155 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
