I have extra view on second decoder although all connected program says otherwise
Dish connection is not working
Check:
coax connection is tight at LNB and decoder,
coax cable is not damaged,
decoder is working,
account is valid & up to date,
dish is aligned correctly.
Otherwise get somebody with a SATFINDER or similar signal strength meter to confirm there is a signal.
Nov 20, 2017 | Televison & Video
Connecting JVC television set model AV29LX2 / JVC home theatre system/satellite decoder / Sony DVD recorder
You need to buy a splitter in order to put one to the DVD recorder and one to the tv from the decoder. You should be able to get one at the Local Radio Shack or other electronics store.
If you need help locating a store, please let me know
Otherwise Thank you for using Fixya and Have a Good Day!
and Good Luck...
Apr 19, 2008 | Televison & Video
When I cancelled my extra view do I lost the option of record and play back on my PVR
probably will . we here at FIXYA have no idea what that company does
Aug 12, 2016 | Televison & Video
Hi fixya I don't have card in PCMCIA slot am told it is not important, I am only watching free view channels not subscription channels all the channels are programmed onto the TV. When TV is connected to...
You don't mention the make or model of your TV, so I am having to take a few educated guesses here: I think you need the common interface module on the TV if it's not going through another receiver. The CIM basically is the thing that allows the broadcast signal to be decoded (free or not). The SkyBox has it's own card and is already doing the descrambling first and then just sends the signal on to your TV.
I am not sure what the "free view box" is that you are using, but it sounds like it doesn't have a decoder.
May 28, 2014 | Televison & Video
My tv is plug into the cable box and wont pick up any channels when i auto program???
Do you subscribe to cable television? If you do, you will need a cable box to decode the signal, otherwise unless your local provider offers a free to air service, your TV will not be able to decode the cable signal. It is important to know wether you are connecting your TV to a cable socket, or aerial or satellite, as these are all very different signals which your TV may not decode.
Jan 03, 2011 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
No image at menu 'digital'
you connected the converter to AV1 that is the ONLY place you will recieve any signal leave the tv in av1 and run setup on the converter ONLY you should be all set
Nov 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have dish network sat tv and can not program my sony 32v35 to recieve any channels. It is connected by cable as the secondary tv. How do I program it to get channels?
Hi, You will need a second Sat decoder or a A/V wireless sender but with this second option you will have to listen to the same channel on both tv.
Best is to get an other decoder.
Good evening!
Nov 04, 2009 | Sony Televison & Video
GD-V425PZW Going in Standby Mode after few seconds. doesn't cm bk
Hi, basically it needs to be receiving a signal for it to operate.
eg. with my one i connect my decoder into it and once the decoder is on the tv turns on. good thing with this monitor is that i just need to turn the decoder off and the screen turns off shortly after. hope this helps.
Jun 30, 2009 | JVC GD-V425PZW Television
No OTA channels
This television has an extremely weak tuner. It is very sensitive to both ghosting (multipath) and weak signal conditions, which cause it's digital decoder to "error out". Coupled with this is the decoder's long set-up time (time to actually begin a decoded video stream after signal is selected)and you find that every time the decoder loses sync it takes several seconds to reestablish normal decoding. The net result is the possiblity that the tuner will be continually restarting and never display anything. An extremely directional antenna may help. Otherwise, find a good external tuner box and use that.
Oct 03, 2007 | JVC HD-52G886 52" Rear Projection HDTV
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
