Question about Intex Pool & Spa
We set up our intex pure spa up today - this is the second year we have had it. All works well, but the heat. I press the heat and it begins beeping and the light goes off, the rest works.
    Top Expert:
  • Intex Master
  • 7,374 Answers
Bad heater element
Posted on Sep 13, 2017
  • 9098 Answers
SOURCE: buzz, plastic smell and no heat
Chances are you have a magnetron that's failing. GE had a rash of "underperforming" magnetrons on these units. They replace the magnetron, stirrer and high-voltage diode at no charge for parts as long as a GE-authorized service center does the work. Sometimes the unit gets run too long in a failing state and the waveguide and chassis of the oven get damaged. The bulletin shows you where tyo check. To see if yours is covered, see this bulletin: Otherwise, you need to contact GE Customer Relations at 1-800-386-1215 as soon as possible and tell them your problem and they will put you in touch with a local authorized servicer.
Posted on Apr 11, 2007
SOURCE: Dishwasher starts then stops
My (KUDI01TJ)Dishwasher did the same thing.
I Pressed start, it acted like it was starting and then turned off.
I started the rapid advance service diagnostic feature:
1.Close dishwasher door "Hi-Temp Wash" "Energy Saver Dry" "Hi-Temp Wash" "Energy Saver Dry"
This started the diagnostics and the dishwasher went through each cycle.
After this, my dishwasher worked fine.
I think the controller must have got in some wierd mode and unpluging the washer would not clear it out but running the
diagnostics cleared it.
Hope this works for you
-Steve Payne
Posted on Aug 19, 2008
  • 323 Answers
SOURCE: The blower on my spa will not turn on
If you've made no changes to the wiring from when it worked correctly, then it can only be the switch. Get a new one, switch off the breakers, and wire it in according to the instruction that come with it.
Posted on May 28, 2009
  • 9098 Answers
SOURCE: heating ceases after one second
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
If yours is not a Panasonic, please reply back with your brand and model number so we can help you.
Posted on May 31, 2010
Testimonial: "Thanks for the good response ... and warnings! Looks like we are shopping for a new microwave."
  • 1631 Answers
SOURCE: Please help I have a intex pure spa and it has
According to Intex - E96 is a "System Error", and the most common problem associated with that fault code is a failed GFCI Cord End.
Look here for replacement;
Leviton 16693 15 Amp 120 Volt Grounded Compact Automatic Reset Right Angle...
Posted on Apr 11, 2015
I have a new intex hexagon pure spa but it won't heat
check recirculation pump if ok heating element and temp sensor
Jul 08, 2017 | Intex Pool & Spa
I have an "Intex Pure Spa" inflatable spa. It shut itself off. when I push restart it starts up then in about 10 sec an "E" comes up on the screen and it beeps. What can I do to reset and fix the err
Has your problem been resolved?
Please use 'Comment', and inform the forum here of your experience.
What did you do? Did Intex help?
If you are still dealing with this problem, let us know.
If so, and for anyone else with a problem ...
Support Intex
Jan 30, 2015 | Intex Pool & Spa
I have an Intex Pure Bubble Intex Pure Bubble Spa. The filters do not have any suction. Are they supposed to? If so how much? I do not feel anything.
For a test only, remove filters and see if you feel anything against the fitting?
If nothing either 'Air Lock', keeping it from priming the pump.
Or, bad pump!
Secondly, are you still dealing with a problem?
Use the comment link on this thread, and let the forum know if you are, if repaired, what did you do?
Intex link...
Support Intex
Jan 22, 2015 | Intex Pool & Spa
Saltware system from intex won't unlock
I'm not sure exactly what buttons you're pushing but you push the down button until it beeps, then the up button until it beeps. Then you set it. To lock it you push the down button until it beeps, then the up button until it beeps. Hope that helps and I apologize if those are the steps you're already taking.
May 27, 2010 | Intex Automatic Salt Water System for ...
After going thru the Start up set up our Intex
After setting the time did you remember to re-lock the keypad by pressing and holding the "down arrow" for 5-seconds until you hear a long beep and then the "up arrow" for 5-seconds until you hear a long beep? Several minutes later the Green LED should come on indicating the cycle has started.
Jul 03, 2009 | Intex Automatic Salt Water System for ...
Pool & Spa Logo
85 people viewed this question
Top Intex Pool & Spa Experts
Level 1 Expert
Jay Finke
Jay Finke
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
