Question about Garden
/ Hello, Have a KBL26A trimmer that stalls out due to lack of maintaining prime. Replaced carb. carb gasket, and breather in gas cap. Still stalls when fuel level gets to about 1/2 tank. Any ideas?
  • 1118 Answers
SOURCE: cannot get 1987 chevy van 20 to keep running... stalls out
Best do a fuel pressure test. Should have chg. fuel filter from the get go. The only other filter is on the end of the fuel pump in tank. Bad gas and dirty gas will plug up fuel filter, hense burn pump up.
Posted on Apr 11, 2009
usmc69
  • 16 Answers
SOURCE: My tractor stalls like it is starved for gas
I had a similar problem with a sears tractor. close to the carbarator is a rectangle box with a rubber hose going to the engine block - remove the hose and spray carb cleaner in the hose wait a few mins and try again - its a vacuum for the carb
Posted on Jun 04, 2009
  • 10865 Answers
SOURCE: 6hp Johnson outboard stalls & quits
go to an auto parts store and get a can of gasoline additive called seafoam. Read the label so you know how much to add to your 6 gallon tank. This stuff works wonders on outboard motors.
Posted on Sep 16, 2009
SOURCE: 1992 f-150 dual gas tanks tank closest to cab of truck pumps gas out the fuel cap
A FORD EQUIPED WITH DUAL TANKS THIS YEAR MODEL HAS CHECK VALVES IN THE FUEL PUMPS .THE FUEL RUNS FROM THE REAR TANK WHEN IT IS POWERED ON TO A TEE AND INTO THE SAME LINE AS THE FRONT PUMP . THE PROBLEM IS AT THE BOTTOM OF THE FRONT FUEL PUMP THERE IS A CHECK VALVE ON THE FOOT AND IT IS NOT WORKING.WHILE THE TRUCK IS RUNNING WITH THE REAR FUEL PUMP ON IT IS PUMPING FUEL INTO THE FRONT TANK . IT WILL RUN OUT OF THE NECK WHEN IT IS FULL.THE FIX IS SIMPLE REPLACE THE FRONT FUEL PUMP. THEY DONT MAKE A CHECK VALVE REPLACEMENT I CHECKED I HAD THE SAME PROBLEM AS YOU.
Posted on Oct 13, 2009
panilling9
  • 284 Answers
SOURCE: Ryobi Gas trimmer fuel line routing
The fuel fillter line goes directly to the carb.inlet first
the outlet on carb.
goes to suction side of primer and outlet side of primer back to tank
primer draws fuel through carb. to prime
Posted on May 09, 2010
Testimonial: "Thank you"
Weed eater runs but wont take fuel acts like running out of gas
Hello David,
You most likely have 1 or 2 problems causing this problem, both which have to do with the carburetor reservoir bowl.
1. The bowl is contaminated with dirt in with the gas causing the port to be clogged and won't allow gas to be siphoned into the carb /engine.
2. The rubber gasket on the top of the bowl is cracked due to the alcohol in the gas and needs to be replaced!
Rich Lilja
Sep 04, 2016 | Stihl FS 85 Weed Eater
My PE550 weedeater edger that won't stay running. I have new carb, new fuel lines, new starter coil. any idea what could be the problem? I am now checking the gas cap, breather is good
check your fuel lines ensure you have them on correctly also check spark plug clean if necessary also when you change out fuel lines and carb it may take quite a few pulls to crank cause the little fuel system has to get primed up!
Aug 09, 2013 | Poulan Pe550 Gas Edger
Engine runs great for 10 minutes and then stalls. Won't start until is sits 3-5 minutes. Replaced fuel lines, filter, cleaned carb., replaced spark plug. What else could be causing this?
Believe it or not, your gas cap is clogged up with dirt and debris. When a carburetor is unable to get a constant flow of air from outside, pressure builds up on the fuel tank. The fastest way to determine whether or not this is the problem is as follows.
As you are using your Mower, at that point when it begins to stall out, loosen the gas cap so that you release the pressure that is built up in the gas tank. If the engine begins to regain power, then you know it is a clogged gas cap. (Simply get a small wire and clear the breathe holes in the cap.) If the engine dies even after loosening the gas cap, then you may want to check to make sure the air breather is clean. ( A dirty air breather can cause the engine to over heat and stall out.)
If none of this seems to help, then it is probably a bad Ignition Coil.
Good Luck!
Jim
Jul 29, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Hi,i have a stihl 026 chainsaw with a bad flooding problem.I have checked the inlet needle in the carb and it is not stuck.I replaced the diaphrams and double checked that i installed them properly.After...
hi please check the tank breather it maybe allowing to build up pressure and unsseating the needle valve
try another breather or tank cap if it uses cap with breather
check that the main check valve / nozzle is working correctly
you mentioned carb has been re-kited
did you fit the pump diaphram on carb then the pump gasket ?
also the metering diaphram has the gasket 1st then diaphram then the cover ( make sure vent hole is clear on cover )
but sounds like a faulty breather
cheers
Aug 20, 2010 | Garden
Ryobi 775r gas trimmer stalling when tilted
You have a air leak between to tank and motor. Could be carb gasket. When using in tilted position you dont have gravity feeded carb anymore, causing air to be sucked into carb. Take off carb and spray with crb cleaner, then blow out with air gun. Replace gasket, make sure all new lines and bulb connections are connected securely.
Jul 17, 2009 | Garden
Engine Stalls out
The gas cap may be clogged.
The next time you run the trimmer and it starts to die, loosen the gas cap. If it starts running again, then you know that it's a clogged gas cap.
You may also check the air breather, it may be dirty as well.
If you need further assistance, just let me know.
Jim
Jun 27, 2009 | Poulan Pe550 Gas Edger
Primer bulb on weedeater won't prime
when you prime the bulb it sucks gas from the tank with the small tube, any excess gassed pumped will be fed back to the carb via the big tube leading to the tank. If you prime it and the bulb stays pushed down, then you have a clog or kink. To fix , pull the small tube out of the tank through the fill hole. Pull off the filter on the end and put the tube back in the tank. If it primes, your fuel filter was clogged. If it still wont prime check the hose going to the carb and make sure isnt clogged or kinked.(take of carb and blow in it). If that doesnt fix it take off the bulb from the carb with two screws. The bulb assembly will come off too(rectange metal thing) Take off the two black gaskets, be carefull with them. Take off hoses from carb and bulb asembly. Blow carb cleaner in all holes and over surface. Put back together.
If the carb wont prime and the bulb isnt staying depressed. then you might have a bad bulb or carb gaskets. Make sure hoses are not cracked, cloged, or pinched.
Jun 17, 2009 | Troy Bilt Tb70ss Gas Trimmer
Husqvarna 324LDx 4 cycle string trimmer. Have
Probably needs a carb kit, check main jet and main fuel inlet jet, is the spark crisp, fat and powerful, try running it with a borrowed coil as this may have an intermittent fault. Is fuel cap breather working or blocked, these small carbs are very sensitive. Make sure all is well with gaskets and diagrahms. Good luck the Yeti
May 17, 2009 | Husqvarna 28cc Gas Line Trimmer
I have a Poulan PRO PP446T that Starts and runs great for about 10-15 minutes then is hard to start and won't idle without stalling, seems after is runs hot. has been tuned up by professional but still has...
Hey Don, I understand your frustration! Had the same problem years ago. Sounds like your gas tank is not breathing.Try this: Run the trimmer until it begins to stall out, then loosen the gas cap slightly. The trimmer should begin to run again. If it begins to run, then the gas cap is clogged. Clear the breather hole or purchase new gas cap. This should solve the problem.
Jim
May 01, 2009 | Garden
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
