I can't use th f1and all of those keys I need help
How do i reset my phone when i cant get past the samsung account i forgot the id and password
There is actually two ways of doing it if it's a smart phn thn all u have to do is connect th phn to th wall charger let it charge for five mins let it be connected to charge turn off ur phn once u have done the Nd after th phn is completely switched of u will a battery symbol as loading if u see tht ur doing it correctly thn disconnect ur phn frm th wall charger thn hold power key Nd th down volume key Nd home button if it's old Samsung device for th new one it's power key Nd down arrow key hold it together until u see Android logo man follow th instructions of resetting frm there but be advised remove th memory card frm th phn or else th data will be gone also non of ur phn data will be there left once u perform these step Nd one more thing Samsung account are nothing but email address used by u so check ur email id tht u use to get th password to rest Nd access it jst like tht
Oct 12, 2016 | Samsung Cell Phones
How do I reset my Samsung account due to abnormal factory reset and processed failed
U have to connect ur phn to th wall charger let it charge for five mins thn let it be connected to th wall charger swtich it of completely thn hold power thn volume down key a new screen will come with Android logo navigation to tht screen is done through volume up/down key beadvised th data of th phn will lost completely secondly remove th memory card if u have any
How do i go about changing my fuel filter i got a new fuel filter for my 1995 dodge stealth SOHC 6cylnder basic model i know where its located n how to change it over but i heard that i need to find th...
The easiest way to relieve the fuel pressure is to start your engine and pull the Fuel Pump Relay - car should die. Now there is no fuel pressure. Turn the key to the off position and change out the fuel filter. Once the filter is changed, put the relay back in and prime the system - turn the key on (don't start) for a few seconds. Turn off, turn key on for a few seconds then start the car. Check for leaks by filter. Easy peasy. Hope this was helpful :-)
Feb 14, 2015 | 1995 Dodge Stealth
Reattach keyboard key
If the tiny plastic hinges are still attached to the keyboard then place th W key over these hinges align it with the other keys and press down on the W key until it clicks onto these hinges.
Jan 09, 2013 | ASUS K73SV-DH51 Laptop
Cannot unlock and open rear cargo door with key or electric lock
U will have to open th door from th in side. To unlock it. Remove the inside panel. And where th key go, u can unlocked from th inside. But firs try to lock and unlock th door whit th electric control while u try to open th door. Because sometimes they are just stock and need lubrication. Good lock
Nov 27, 2011 | 2004 Hyundai Santa Fe
My IBM netvista pc is not loading BIOS
press F1and keep tapping it till you hear a beep soon as the computer comes on!!!
Dec 14, 2010 | IBM NetVista PC Desktop
License key for smartmovie 4.10. my serial no is 356994019540693
hi dude ,, i had downloaded th key maker for smartmovie player to my nokia 5320.....& its a succes on registration.but we cant use it without verifying the player registered by lonelycat games.when we open th player they will ask to gat connect 2 the internet through mob.
May 01, 2009 | Nokia 5320 XpressMusic Cellular Phone
Dell sk-8115 not recognized on boot up. After soft boot it works
hi im Dyanne.. on th 1st screen at bootup press th desired key to display th BIOS setup. on some machines you will see a brief notice on th screen as it comes to life stating which key to press. (ie. delete, F2 or esc etc) if not consult your instruction manual. you will get to a blue screen headed CMOS. now you need to setup th BIOS to recognize th presence of th new h/d. this will enable you to auto detect th h/d. go to th 1st in th list (cmos settings) and where it says PRIMARY MASTER click on it and enter and this will auto detect it. press F10 then Y and enter. this will now access your h/d and boot normally. good luck and merry christmas .. Dyanne xx
Dec 25, 2008 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Purchase Order
you follow these steps
Display--statement of inventory--purchase order summary
then click Alt+F1and print it.
Feb 05, 2008 | Computers & Internet
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
