Code cl showing on digital display? - Washing Machines
I have a CL blinking in the display. How do I reset?
LG Washer Error Code Cl Fix -
Jan 19, 2011 - CL means that your washing machine's CHILD LOCK is ON. You canfind ... CL popped up on my display had no idea what it was because the manual didn't say. ... I have the touch screen panel and it does not have temp or option buttons ... I've had tried to reset but won't do do I press temp and what else
How does Child Lock work on my washing machine?
Samsung ElectronicsOct 23, 2015 - If the Child-Lock function is activated, the Child-Lock icon will blink. ...If 30 seconds have passed after opening the cover when the Child-Lock ... Step 5: To clear "CL" error on the display, close the door of the washer after ...
[PDF]Washing Machine - Home Depot
The Home DepotJan 3, 2015 - Warnings and Important Safety Instructions in this manual do not ... Donot wash or dry articles that have been previously cleaned in, washed in, soaked ......the Reset water level, "CL" is displayed on the LED display without.
Jan 19, 2016 | Washing Machines
I have a Frigidaire dishwasher it is showing a code cl which means its not closed. I just replaced the latch with a bran new one and still is reading the code. any suggestions
Good Afternoon friend, I appreciate your post!
From what you have described your Frigidaire dishwasher is displaying an error code of "CL" and you have replaced the latch. Since the latch has been replaced it could be a problem with the wiring harness or main control. I would recommend having a professional out to perform a diagnosis and this will help you to avoid any unnecessary part purchases. Best of luck! -Matt
Mar 10, 2015 | Frigidaire Dishwashers
CL flashing even though the coils have been cleaned. unable to reset wine fridge
To clear the alarm:
1) Press and release the "SET button four times. "cnd" will be displayed on the screen.
2) While "cnd" is displayed, press and hold the "SET" button. The display will show the number of weeks the refrigerator has been running.
3) While holding the "SET" button, press and release the ON/OFF button. The number shown on the display will reset to 0.
4) Release the "SET" key.
Jan 12, 2014 | Marvel 30WCM Wine Cooler
'CL' for LG washers stands for 'Child Lock'.
To release hold down 'temp' and 'eco/rapid' together, then release!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 16, 2011 | LG Washing Machines
The display screen is showing CL. Nothing is
CL is child lock. See your users manual for unlocking the child lock procedure. Usually it involves pressing 1 or 2 buttons for 3 to 5 seconds. Many machines actually have a lock button you press for 3 - 5 seonds. Others use the stop pause button.
Aug 30, 2010 | LG WD-1280FHD Front Load Washer
Cl is showing on display and machine wont work
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
Feb 26, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
Jan 29, 2009 | LG WM-2277HW Front Load Washer
Lg direct drive 6kg, not switcing on properly,
I am not showing a error code for CL, there is one for CE that relates to the main board or the stator motor being faulty.
Dec 07, 2008 | Washing Machines
Radio not playing or coming on.
the radio has to go to the shop to get fix dont pull it or you will set a code on the radio
Oct 13, 2008 | 1998 Acura CL
"CL" blinking on the display of my answering machine
CL is the clock. Set the time and date on the lower right hand side of answering machine.
Nov 30, 2007 | Vtech 5.8 Ghz Handset Cordless Phone...
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
