Question about Microwave Ovens
I am trying to find the mounting template for mmv5207aas microwave. can anyone either give me the dimensions of the top holes for cord and screws and back mounting plate. thank you.
  • 9098 Answers
SOURCE: ge microwave - uninstall from mounting plate
If you don't have the installation instructions, you can get them here.
They're very helpful when installing OR uninstalling.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 16, 2008
  • 9098 Answers
SOURCE: Microwave
You can download Kitchenaid/Whirlpool owner's manuals and installation instructions here.
They're very handy when uninstalling them too.
If you have a problem with your microwave, we may be able to guide you to an affordable repair.
If you're interested, please reply back with your brand and model number as well as your symptoms so we can help you.
Posted on Dec 15, 2008
  • 5 Answers
SOURCE: How do I remove Frigidaire FMV156DCC under cabinet microwave?
Underneath the microwave, on the right & left hand corner sides at the back, there are levers that you pull down & it releases the mounting bracket.
Posted on Sep 12, 2009
  • 9098 Answers
SOURCE: wall template mount for ge profile microwave
You can may be able to order that by looking up parts by your full model number here.
Posted on Jan 11, 2010
  • 142 Answers
SOURCE: Hi there, I'm installing an LG LMV205SW OTR
It does not really matter where you can get a lag screw into a stud as long as you can get at least two screws in place holding the mounting plate. Don't forget there are two screws in the front you have to put in.
Posted on Sep 27, 2011
Over range microwave doesn't fit in the space outlined by the installation template
You missed something while reading the installation directions but that won't fix it. since you already drilled holes in the wall lower the mount down as needed then drill new holes in the mount to match the holes you drilled in the wall. The problem would have been worse if you were off left or right... up and down is easier. Remember you maybe just not dropping the microwave low enough to fit in the slot at the bottom of the wall mount before you tilt the micro up.. check it one more time...including the directions before you re-drill
Sep 26, 2015 | Bosch 30" 500 Series Over-The-Range...
I want to install a new microwave over the counter microwave that uses the existing mounting screws, vents, template and whatever. I don't want to have to do anything but disconnect and remove the old
you must ask to the supplier for the dimension and based in the models specifications. Contact them via ONLINE chat and get the support for better performance.
God bless you
Nov 18, 2013 | Microwave Ovens
Need Installation 'Paper' Template for MMV4184AAW Maytag Microwave
see the video
and proceed according. God bless you
Apr 02, 2013 | Microwave Ovens
Can you provide guidance on how to install this microwave? Trying to decide if I should pay $120 for the store to install.
Installation of an over the range microwave is not a very difficult task as long as electrical work to provide power is not needed. If no outlet exists then an electrician will be required.
Tools that may be needed for the installation include a cordless drill, drill bit, measuring tape, masking tape, stud finder, razor knife, pencil.
A template is commonly provided for mounting hole locations that need to be drilled in the cabinet. These holes are the top mounts.
An additional template for the wall bracket is normally supplied as well. Here you will need the stud finder, it is important to locate the studs and mount the wall bracket to them.
The wall bracket serves as the bottom mount and aids in the final mounting of the microwave.
Depending on the oven's size and weight a helper may be needed to complete the installation.
Remember to be safe first and seek advice/help with any step you are unsure about.
Good luck.
Jun 27, 2010 | Whirlpool WMH1162XVS Microwave Oven
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
Jun 16, 2010 | Frigidaire Microwave Ovens
Hi there, I'm installing an LG LMV205SW OTR Microwave and the four holes for the mounting plate do not coincide with the two wall studs that are behind the microwave location. Can I sink a couple of extra...
Consider the studs as I I add 2 2x4's like in an H with second 2x4 below the cenre bar in the H adjust both to the spaces needed for your mounting crews if it came with a template use it....I am not a carpenter but It Is what I would do
Dec 29, 2009 | LG LMV2083SW Microwave Oven
I am seeking a template for re-installing my 2 year old microwave. Jenn-aire has none of the templates in stock and can't send me a pdf or file so I can print the template myself. I have tried 2 parts...
Since you can't get a paper template for remounting your microwave, I can offer you my tips for doing this, as I've had to reinstall many of my customers microwaves, after they've done a kitchen remodel.
You can use the metal mounting bracket as your "new" template. Just unmount the micro and remove the metal bracket and you can then position it on the wall or under the cabinet where you are looking to mount the microwave. However, before you remove it from the wall, simply measure the distance from the edges at the top and both sides of the bracket, where it is presently mounted and you'll be able to easily remount it in a new location.
If you've already removed it from the wall, not to worry, simply place it on the back of the microwave and measure the distance from the edges of the bracket to the top and both sides of the microwave's canbinet edges. Allow for 3/16" additional distance and you should be able to then remount the bracket at the new location with ease.
Please remember that you want to get the bracket secured into a wall stud so it can hold the weight of the microwave once it's installed and fastened to the bracket. I also recommend that you use wall anchors at the side edges at both the top and bottom corners to help secure the bracket IF there are no wall studs behind the predrilled holes for mounting the bracket to the wall.
If you have trouble using the metal mounting bracket, you can always trace the entire bracket onto a piece of heavy paper or cardboard, but frankly, I find this unecessary and time consuming, since you've already got the mounting bracket right there with all the holes and such.
Also, don't forget to measure the location of the power cord at the top or back of the microwave and remember you'll need to drill a hole in order to be able to pass the cord thru the cabinet. If your microwave has screws at the top front edge that help secure it to the cabinent above it, again, simply measure the distance of these mounting locations from the sides and back of the microwave cabinet and drill holes thru the cabinet, using a drill bit that is twice the diameter of the mounting bolts. You should add washers to these bolts to help prevent the bolts from pulling thru the cabinet bottom.
Mounting a microwave is best done with at least two people, as holding it in place while someone else puts the bolts in it isn't easy to do by yourself. Also, it is much easier to do, when installing it over an existing range, if you move the range out of the way first, so you can stand under the microwave, instead of having to lean over the range while trying to install it. Not to mention the fact that should you drop the microwave, you'll not only damage it, but could destroy your range at the same time.
Hope you find this Very Helpful and best regards!
Oct 23, 2009 | Jenn-Air JMC9158AAS Convection/Microwave...
LG LMV1680BB top mount not usable
They simply need to drill new holes, I'd say.
The installation instructions will have a template.
Jun 05, 2009 | Microwave Ovens
Installation of undercabinet microwave
If the OTR is the same model, the mounts should be the same. As long as you use the same bolts/screws from the old one, or the same length new bolts/screws, it should be a fairly simple exchange.
Mar 24, 2017 | GE JVM1440 Microwave Oven
I'm trying to remove a Hotpoint RVM58003. I removed four long bolts from the top but it does not move. Any help on what I need to do to remove it? Dan
The Hotpoint RVM58003 (circa 1984) cannot be lifted off a hanger after the four top screws are removed because it doesn't have a separate pre-installed hanger like newer units do. The rear mounting screw holes are part of the outer frame of the unit, which requires removal of the Microwave sub-assembly of the Hotpoint RVM58003 to expose the outer metal frame and the array of pre-drilled rear mounting holes before the rear mounting screw(s) can be accessed and removed. Based on my recent experience removing a Hotpoint RVM58003 Microwave Hood from 1984 it appears the unit was originally installed this way too. Please note that this is a very involved process. Basic steps are: 1) Unplug AC power to the unit, or turn off the circuit breaker. 2) Remove the top plastic grill over the door and control panel (2 screws). 3) Next to the grill screws remove the larger left/right screws holding the Microwave sub-assembly in. 4) Drop down the hinged light bulb/air filter cover panel (mine had 7 screws). 5) Remove the small metal cover plate on the right under the control panel. This exposes the Microwave sub-assembly electrical connector. 6) Disconnect the Microwave sub- assembly connector. 7) Carefully pull the Microwave sub-assembly out of the frame and set aside. You may need to fish the power cord through the cabinet or unscrew the power cord terminals. NOTE: this is best done with a helper because this sub-assembly is about 25-30 pounds. 8) Once the sub-assembly is out the rear plate is exposed and the rear mounting screws can be removed. I found that the GE/Hotpoint Owner's Manual does not have installation instructions. Neither does the GE web site, they only have the Owner's Manual. For more specific help and instructions I suggest calling The GE Answer Center at 800-626-2000 or hiring a professional installer experienced with this older style Microwave Hood.
Jan 23, 2009 | Hotpoint JE740WY/GY Microwave Oven
Microwave Ovens Logo
19 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
