Question about Kitchen Ranges
What is the program code for my exp room temperature control?
I just replaced the control board and now it won't reset
Hi try this. 1 press & hold the door alarm keypad. .2 press & hold freezer temperature down keyboard within 3 seconds. .3 release the door alarm alarm keypad and wait 3 seconds. 4.the control will DISPLAY PE to indicate the programming mode 5.entry is confirmed by pressing the freezer temperature down keypad once more. .6 the control will display the current program CODE this program should be validated with the program CODE printed on the unit serieal plate ..NOTE.IF THE PROGRAM code is correct the programming mode is excited by pressing door alarm keypad for 3 seconds. .7.press the refrigerator temperature up keypad or refrigerator down keypad to change the digit value with each key press. 8,. the decimal point indicates the selected digit press the freezer temperature Up keypad to select next digit. . 9.. Once the desired program code is entered press & hold the freezer temperature down keypad until the program CODE begins flashing indicating it has been saved.Note.if u attempt to enter an invalid code the control will not save the new code ...but will beep ,,(the unit will not run with a program code of 0000 ,). Once the program CODE has been saved the programming mode is excited by pressing any key.if the new code is incorrect this process should be repeated.the programming mode can be excited at any time by pressing door alarm key for 3 seconds or will exit if unattended for 4 minutes..good luck
Jun 16, 2016 | Maytag Refrigerators
How to program a w10319823 Kenmore refrigerator control board
Yes, here are the instructions to program:
Programming Mode:
NOTE: The Program Code is located on the Serial Plate on this unit after the word Code.
1. Press and hold the Door Alarm Keypad.
2. Press and hold Freezer Temperature DOWN /- Keypad within 3 seconds.
3. Release the Door Alarm Keypad and wait 3 seconds.
4. The control will display PE to indicate the programming mode.
5. Entry is confirmed by pressing the Freezer Temperature DOWN /- Keypad once more.
6. The control will display the current Program CODE. This value should be validated with theProgram CODE printed on the unit serial plate.
NOTE: If the Program CODE is correct, the Programming Mode is exited by pressing Door Alarm Keypad for 3 seconds.
7. Press the Refrigerator Temperature UP /+ Keypad or Refrigerator Temperature DOWN /- Keypad to change the digit value with each key press.
8. The decimal point indicates the selected digit. Press the Freezer Temperature UP /+ Keypad to select the next digit.
9. Once the desired Program CODE is entered, press and hold the Freezer Temperature DOWN /- Keypad until the Program CODE begins flashing
NOTE: If you attempt to enter an invalid Program CODE the control will not save the new code, but will beep. (The unit will NOT run with a Program
CODE of 0000).Once the Program CODE has been saved the Programming Mode is exited by pressing any key. If the new code is incorrect this
The Programming mode can be exited at any time by pressing Door Alarm key for 3 seconds or will exit if unattended for four minutes
Feb 05, 2016 | Kenmore Refrigerators
Midea floor standing air conditioner displaying error code E6.Please what does it mean and possible solutions.
Google says:
E6 Room temperature or evaporator temperature sensor open or short circuit
The prescribed cure:
Check to make sure the room temperature sensor is connected and reads the correct resistance value. If the sensor operates correctly, replace the control board.
This unit most likely employs a NTC thermistor as a thermometer sensor. Common resistance values are 1k ohms and 10k ohms at room temperature. As the temperature goes up, the sensor decreases in resistance.
The sensing element could look like any of the above, but with portable comfort units, they usually look like the bottom row of encapsulated and cabled assemblies.
Feb 09, 2015 | Midea Heating & Cooling
It is increasing temp 2 hours before scheduled
Most programmable thermostats are "smart stats" which use a programmed algorithm base on a preprogrammed P (proportional) I (Integral) D (derivative) Loop. To make a long story short, the programmed temperature will make the room that temperature by the programmed time. This is based on how long it has taken it in the past to bring the room up or down to temperature. So if your setpoint is 70, and your set time is 7 AM, then the furnace or AC will bring the room to that temperature by the set time...not start at the set time.
Dec 04, 2013 | Heating & Cooling
Cant program remote
I'm going to assume you are meaning that you are unable to set the "target temperature" for the thermostat?
This remote control system can be thermostatically controlled when the transmitter is in the THERMO mode (THERMO must be displayed on the screen). To set the DESIRED room temperature, press the MODE button to place the transmitter into THERMO mode, then press the UP or DOWN button to select the desired
room temperature. The highest SET temperature is 99 degrees Fahrenheit (32 degrees Celsius).
The complete owner's manual can be downloaded from the product page below, just scroll down to the bottom and click the link.
Skytech 3002 Thermostat Fireplace Remote
Sep 23, 2012 | Skytech 3002 Fireplace Remote Control with...
Hi i own a tappan tgf328 gas range and I'm trying to heat up the oven and its beeping and giving me an F31 code. Can you help me?
Tamppan Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
Apr 07, 2011 | Tappan TGF320 Gas Kitchen Range
F3 code
F3 E0 5 Top oven sensor open Check for open circuit. Sensor resistance should be 1K to 1.1K @ room temperature. If not, replace the sensor. F3 E1 6 Top oven shorted Check for shorted sensor circuit, otherwise replace sensor F3 E2 9 Bake range over temperature At room temperature, sensor resistance should be 1K to 1.1K. If not, replace the sensor. If the sensor checks okay, replace the control. F3 E3 8 Clean range over temperature At room temperature, sensor resistance should be 1K to 1.1K. If not, replace the sensor. If the sensor checks okay, replace the control. F3 E4 10 Bottom oven sensor open Check for open circuit. Sensor resistance should be 1K to 1.1K @ room temperature. If not, replace the sensor. F3 E5 15 Bottom oven sensor shorted Check for shorted sensor circuit, otherwise replace senso
Feb 24, 2010 | Whirlpool GS460 Gas Kitchen Range
I have a code f24 on display screen the I have to hit stop start over, what is f24?
The F-24 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F). This is usually caused by a failed temperature sensor (Key 24 in the image below). A wiring failure or a failed electronic control board could also cause this fault code.If you are able to unplug the washer and safely remove the bottom front service panel, then you can check the resistance of this temperature sensor using a volt/ohm meter. To remove the bottom front service panel, take out the screws at the very bottom of the panel and then pull it out and down to remove it from the washer. With the panel removed, you should be able to pull the wires off of the temperature sensor at the bottom front of the washer tub. Measure the resistance across the leads of the temperature sensor. You should measure about 10K ohms (10,000 ohms) of resistance at room temperature. A reading that is more than 30% off would verify a failure in this component. Replacing the temperature sensor would fix this type of problem.
If the resistance reading of the temperature sensor is okay at room temperature, you could have a wiring failure or a bad control board. There is also a slight possibility that you could still have a bad temperature sensor even though it measures okay at room temperature. A technician would normally be needed to check for this type of failure.
Feb 24, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore built-in oven set at bake tempature does not set just keeps rising got F2 code
HI. This error code will occur when the control board senses an oven temperature above 915F-935F
Once this type of temperatures occur, this will generally weld the relay contacts on the main board. This will damage the board, and it will require you to have it replaced, asap. If these temperatures never reached the sated thresholds, i would advise to Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace the sensor if found to be defective. Check door lock switches for damage, as well.
In most cases, this will be a failed control board. To confirm, simply preform a resistance test on the sensor. The normal ohm readings should be 1100 ohms at room temperature.
If the oven temp sensor dose not test out at 1100 ohms at room temp, replace the sensor.
Jan 06, 2010 | Kenmore Ovens
F3 code and beeping
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace.
If all above is ok replace control.
Nov 17, 2007 | GE Profile Advantium SCB2001KSS Stainless...
Kitchen Ranges Logo
21 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
